[GRASS-SVN] r56960 - grass/trunk/raster3d/r3.neighbors
Sun Jun 30 15:57:05 PDT 2013
Author: huhabla
Date: 2013-06-30 15:57:05 -0700 (Sun, 30 Jun 2013)
New Revision: 56960
   grass/trunk/raster3d/r3.neighbors/main.c
Corrected indention
Modified: grass/trunk/raster3d/r3.neighbors/main.c
--- grass/trunk/raster3d/r3.neighbors/main.c	2013-06-30 22:26:22 UTC (rev 56959)
+++ grass/trunk/raster3d/r3.neighbors/main.c	2013-06-30 22:57:05 UTC (rev 56960)
@@ -26,72 +26,74 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
-int nx, ny, nz;					/* Number of cells in x, y and z direction */
-int x_dist, y_dist, z_dist;		/* Distance of cells from the center
-								   to the edge of the moving window */
-int x_size, y_size, z_size;		/* The size of the moving window in x,
-								   y and z direction */
-int size;                       /* The maximum size of the value buffer */
+int nx, ny, nz;			/* Number of cells in x, y and z direction */
+int x_dist, y_dist, z_dist;	/* Distance of cells from the center
+				   to the edge of the moving window */
+int x_size, y_size, z_size;	/* The size of the moving window in x,
+				   y and z direction */
+int size;			/* The maximum size of the value buffer */
 struct menu
-	stat_func *method;			/* routine to compute new value */
-	char *name;					/* method name */
-	char *text;					/* menu display - full description */
+    stat_func *method;		/* routine to compute new value */
+    char *name;			/* method name */
+    char *text;			/* menu display - full description */
 } menu[] = {
-        {c_ave, "average", "average value"},
-        {c_median, "median", "median value"},
-        {c_mode, "mode", "most frequently occuring value"},
-        {c_min, "minimum", "lowest value"},
-        {c_max, "maximum", "highest value"},
-        {c_range, "range", "range value"},
-        {c_stddev, "stddev", "standard deviation"},
-        {c_sum, "sum", "sum of values"},
-        {c_count, "count", "count of non-NULL values"},
-        {c_var, "variance", "statistical variance"},
-        {c_divr, "diversity", "number of different values"},
-        {c_intr, "interspersion", "number of values different than center value"},
-        {c_quart1, "quart1", "first quartile"},
-        {c_quart3, "quart3", "third quartile"},
-        {c_perc90, "perc90", "ninetieth percentile"},
-        {c_quant, "quantile", "arbitrary quantile"},
-        {NULL, NULL, NULL}
+    c_ave, "average", "average value"}, {
+    c_median, "median", "median value"}, {
+    c_mode, "mode", "most frequently occuring value"}, {
+    c_min, "minimum", "lowest value"}, {
+    c_max, "maximum", "highest value"}, {
+    c_range, "range", "range value"}, {
+    c_stddev, "stddev", "standard deviation"}, {
+    c_sum, "sum", "sum of values"}, {
+    c_count, "count", "count of non-NULL values"}, {
+    c_var, "variance", "statistical variance"}, {
+    c_divr, "diversity", "number of different values"}, {
+    c_intr, "interspersion", "number of values different than center value"},
+    c_quart1, "quart1", "first quartile"}, {
+    c_quart3, "quart3", "third quartile"}, {
+    c_perc90, "perc90", "ninetieth percentile"}, {
+    c_quant, "quantile", "arbitrary quantile"}, {
+    NULL, NULL, NULL}
 static char *build_method_list(void)
-	char *buf = G_malloc(1024);
-	char *p = buf;
-	int i;
+    char *buf = G_malloc(1024);
+    char *p = buf;
+    int i;
-	for (i = 0; menu[i].name; i++) {
-		char *q;
+    for (i = 0; menu[i].name; i++) {
+	char *q;
-		if (i)
-			*p++ = ',';
-		for (q = menu[i].name; *q; p++, q++)
-			*p = *q;
-	*p = '\0';
+	if (i)
+	    *p++ = ',';
+	for (q = menu[i].name; *q; p++, q++)
+	    *p = *q;
+    *p = '\0';
-	return buf;
+    return buf;
 static int find_method(const char *method_name)
-	int i;
+    int i;
-		if (strcmp(menu[i].name, method_name) == 0)
-			return i;
+	if (strcmp(menu[i].name, method_name) == 0)
+	    return i;
-	G_fatal_error(_("Unknown method <%s>"), method_name);
+    G_fatal_error(_("Unknown method <%s>"), method_name);
-	return -1;
+    return -1;
@@ -105,84 +107,84 @@
 static void set_params()
-	param.input = G_define_standard_option(G_OPT_R3_INPUT);
+    param.input = G_define_standard_option(G_OPT_R3_INPUT);
-	param.output = G_define_standard_option(G_OPT_R3_OUTPUT);
+    param.output = G_define_standard_option(G_OPT_R3_OUTPUT);
-	param.method = G_define_option();
-	param.method->key = "method";
-	param.method->type = TYPE_STRING;
-	param.method->required = YES;
-	param.method->options = build_method_list();
-	param.method->description = _("Aggregate operation");
-	param.method->multiple = NO;
+    param.method = G_define_option();
+    param.method->key = "method";
+    param.method->type = TYPE_STRING;
+    param.method->required = YES;
+    param.method->options = build_method_list();
+    param.method->description = _("Aggregate operation");
+    param.method->multiple = NO;
-	param.quantile = G_define_option();
-	param.quantile->key = "quantile";
-	param.quantile->type = TYPE_DOUBLE;
-	param.quantile->required = NO;
-	param.quantile->description =
-		_("Quantile to calculate for method=quantile");
-	param.quantile->options = "0.0-1.0";
-	param.quantile->multiple = NO;
+    param.quantile = G_define_option();
+    param.quantile->key = "quantile";
+    param.quantile->type = TYPE_DOUBLE;
+    param.quantile->required = NO;
+    param.quantile->description =
+	_("Quantile to calculate for method=quantile");
+    param.quantile->options = "0.0-1.0";
+    param.quantile->multiple = NO;
-	param.window = G_define_option();
-	param.window->key = "window";
-	param.window->type = TYPE_INTEGER;
-	param.window->required = YES;
-	param.window->key_desc = "x,y,z";
-	param.window->description =
-		_("The size of the window in x, y and z direction,"
-		  " values must be odd integer numbers, eg: 3,3,3");
+    param.window = G_define_option();
+    param.window->key = "window";
+    param.window->type = TYPE_INTEGER;
+    param.window->required = YES;
+    param.window->key_desc = "x,y,z";
+    param.window->description =
+	_("The size of the window in x, y and z direction,"
+	  " values must be odd integer numbers, eg: 3,3,3");
 static int gather_values(RASTER3D_Map * map, DCELL * buff, int x,
-                         int y, int z)
+			 int y, int z)
     int i, j, k, l;
     DCELL value;
     int start_z = z - z_dist;
     int start_y = y - y_dist;
     int start_x = x - x_dist;
     int end_z = start_z + z_size;
     int end_y = start_y + y_size;
     int end_x = start_x + x_size;
     if (start_z < 0)
-        start_z = 0;
+	start_z = 0;
     if (start_y < 0)
-        start_y = 0;
+	start_y = 0;
     if (start_x < 0)
-        start_x = 0;
+	start_x = 0;
     if (end_z > nz)
-        end_z = nz;
+	end_z = nz;
     if (end_y > ny)
-        end_y = ny;
+	end_y = ny;
     if (end_x > nx)
-        end_x = nx;
+	end_x = nx;
     l = 0;
     for (i = start_z; i < end_z; i++) {
-        for (j = start_y; j < end_y; j++) {
-            for (k = start_x; k < end_x; k++) {
-                value = (DCELL) Rast3d_get_double(map, k, j, i);
-                if(Rast_is_d_null_value(&value))
-                    continue;
-                buff[l] = value;
-                l++;
+	for (j = start_y; j < end_y; j++) {
+	    for (k = start_x; k < end_x; k++) {
+		value = (DCELL) Rast3d_get_double(map, k, j, i);
+		if (Rast_is_d_null_value(&value))
+		    continue;
+		buff[l] = value;
+		l++;
     return l;
@@ -191,120 +193,122 @@
 int main(int argc, char **argv)
-	RASTER3D_Map *input;
-	RASTER3D_Map *output;
-	RASTER3D_Region region;
-	struct GModule *module;
-	stat_func *method_fn;
-	double quantile;
+    RASTER3D_Map *input;
+    RASTER3D_Map *output;
+    RASTER3D_Region region;
+    struct GModule *module;
+    stat_func *method_fn;
+    double quantile;
     int x, y, z;
-	/* Initialize GRASS */
-	G_gisinit(argv[0]);
+    /* Initialize GRASS */
+    G_gisinit(argv[0]);
-	module = G_define_module();
-	G_add_keyword(_("raster3d"));
-	G_add_keyword(_("neighbor"));
-	G_add_keyword(_("aggregation"));
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("neighbor"));
+    G_add_keyword(_("aggregation"));
     G_add_keyword(_("statistics"));
     G_add_keyword(_("filter"));
     module->description =
-    _("Makes each voxel value a "
-    "function of the values assigned to the voxels "
-    "around it, and stores new voxel values in an output 3D raster map");
+	_("Makes each voxel value a "
+	  "function of the values assigned to the voxels "
+	  "around it, and stores new voxel values in an output 3D raster map");
-	/* Get parameters from user */
-	set_params();
+    /* Get parameters from user */
+    set_params();
-	if (G_parser(argc, argv))
-		exit(EXIT_FAILURE);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-	if (NULL == G_find_raster3d(param.input->answer, ""))
-		Rast3d_fatal_error(_("3D raster map <%s> not found"),
-						   param.input->answer);
+    if (NULL == G_find_raster3d(param.input->answer, ""))
+	Rast3d_fatal_error(_("3D raster map <%s> not found"),
+			   param.input->answer);
-	Rast3d_init_defaults();
-	Rast3d_get_window(&region);
+    Rast3d_init_defaults();
+    Rast3d_get_window(&region);
-	nx = region.cols;
-	ny = region.rows;
-	nz = region.depths;
+    nx = region.cols;
+    ny = region.rows;
+    nz = region.depths;
-	/* Size fo the moving window */
-	x_size = atoi(param.window->answers[0]);
-	y_size = atoi(param.window->answers[1]);
-	z_size = atoi(param.window->answers[2]);
+    /* Size fo the moving window */
+    x_size = atoi(param.window->answers[0]);
+    y_size = atoi(param.window->answers[1]);
+    z_size = atoi(param.window->answers[2]);
     /* Distances in all directions */
     x_dist = x_size / 2;
     y_dist = y_size / 2;
     z_dist = z_size / 2;
     /* Maximum size of the buffer */
-	size = x_size * y_size * z_size;
-	/* Set the computation method */
-	method_fn = menu[find_method(param.method->answer)].method;
-    if(param.quantile->answer)
-        quantile = atof(param.quantile->answer);
+    size = x_size * y_size * z_size;
+    /* Set the computation method */
+    method_fn = menu[find_method(param.method->answer)].method;
+    if (param.quantile->answer)
+	quantile = atof(param.quantile->answer);
     else
-        quantile = 0.0;
+	quantile = 0.0;
-	input = Rast3d_open_cell_old(param.input->answer,
-								 G_find_raster3d(param.input->answer, ""),
-								 &region, RASTER3D_TILE_SAME_AS_FILE,
-								 RASTER3D_USE_CACHE_DEFAULT);
+    input = Rast3d_open_cell_old(param.input->answer,
+				 G_find_raster3d(param.input->answer, ""),
+				 &region, RASTER3D_TILE_SAME_AS_FILE,
+				 RASTER3D_USE_CACHE_DEFAULT);
-	if (input == NULL)
-		Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
+    if (input == NULL)
+	Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
-	output =
-		Rast3d_open_new_opt_tile_size(param.output->answer,
-									  RASTER3D_USE_CACHE_X, &region,
-									  DCELL_TYPE, 32);
+    output =
+	Rast3d_open_new_opt_tile_size(param.output->answer,
+				      RASTER3D_USE_CACHE_X, &region,
+				      DCELL_TYPE, 32);
-	if (output == NULL)
-						   param.output->answer);
+    if (output == NULL)
+			   param.output->answer);
-	Rast3d_min_unlocked(output, RASTER3D_USE_CACHE_X);
-	Rast3d_autolock_on(output);
-	Rast3d_unlock_all(output);
+    Rast3d_min_unlocked(output, RASTER3D_USE_CACHE_X);
+    Rast3d_autolock_on(output);
+    Rast3d_unlock_all(output);
     DCELL *buff = NULL, value;
     buff = (DCELL *) calloc(size, sizeof(DCELL));
     if (buff == NULL)
-        Rast3d_fatal_error(_("Unable to allocate buffer"));
-	for (z = 0; z < nz; z++) {
-		for (y = 0; y < ny; y++) {
-			for (x = 0; x < nx; x++) {
-				/* Gather values in moving window */
-				int num = gather_values(input, buff, x, y, z);
-                /* Compute the resulting value */
-                if(num > 0)
-                    (*method_fn) (&value, buff, num, &quantile);
-                else
-                    Rast_set_d_null_value(&value, 1);
-                /* Write the value */
-				Rast3d_put_double(output, x, y, z, value);
+	Rast3d_fatal_error(_("Unable to allocate buffer"));
+    for (z = 0; z < nz; z++) {
+	for (y = 0; y < ny; y++) {
+	    for (x = 0; x < nx; x++) {
+		/* Gather values in moving window */
+		int num = gather_values(input, buff, x, y, z);
+		/* Compute the resulting value */
+		if (num > 0)
+		    (*method_fn) (&value, buff, num, &quantile);
+		else
+		    Rast_set_d_null_value(&value, 1);
+		/* Write the value */
+		Rast3d_put_double(output, x, y, z, value);
     free(buff);
-	if (!Rast3d_flush_all_tiles(output))
-		G_fatal_error(_("Error flushing tiles"));
+    if (!Rast3d_flush_all_tiles(output))
+	G_fatal_error(_("Error flushing tiles"));
     Rast3d_autolock_off(output);
-	Rast3d_close(input);
-	Rast3d_close(output);
+    Rast3d_close(input);
+    Rast3d_close(output);
-	return 0;
+    return 0;
