[GRASS-SVN] r55271 - grass/trunk/vector/v.mkgrid
svn_grass at osgeo.org
Fri Mar 1 06:16:53 PST 2013
Author: mmetz
Date: 2013-03-01 06:16:53 -0800 (Fri, 01 Mar 2013)
New Revision: 55271
grass/trunk/vector/v.mkgrid/main.c
v.mkgrid: speedup and fix r53891
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2013-02-28 19:00:55 UTC (rev 55270)
+++ grass/trunk/vector/v.mkgrid/main.c 2013-03-01 14:16:53 UTC (rev 55271)
@@ -28,9 +28,6 @@
#include "grid_structs.h"
#include "local_proto.h"
-/* Write attribute data in batches per 20 */
-#define BATCH_SIZE 20
int main(int argc, char *argv[])
@@ -41,7 +38,6 @@
char *dig_file;
char buf[2000];
- int batch_fill;
/* Other local variables */
int attCount, nbreaks;
@@ -269,8 +265,8 @@
G_verbose_message(_("Creating centroids..."));
/* Write out centroids and attributes */
+ db_begin_transaction(Driver);
attCount = 0;
- batch_fill = 0;
for (i = 0; i < grid_info.num_rows; ++i) {
for (j = 0; j < grid_info.num_cols; ++j) {
double x, y;
@@ -289,16 +285,10 @@
Vect_cat_set(Cats, 1, attCount + 1);
Vect_write_line(&Map, point_type, Points, Cats);
- if (batch_fill == 0) {
- sprintf(buf, "insert into %s values ", Fi->table);
- if (db_set_string(&sql, buf) != DB_OK)
- G_fatal_error(_("Unable to fill attribute table"));
- if (batch_fill > 0)
- if (db_append_string(&sql, ", ") != DB_OK)
+ sprintf(buf, "insert into %s values ", Fi->table);
+ if (db_set_string(&sql, buf) != DB_OK)
+ G_fatal_error(_("Unable to fill attribute table"));
if (grid_info.num_rows < 27 && grid_info.num_cols < 27) {
sprintf(buf,
"( %d, %d, %d, '%c', '%c' )",
@@ -311,30 +301,18 @@
if (db_append_string(&sql, buf) != DB_OK)
- batch_fill++;
- if (batch_fill == BATCH_SIZE) {
- G_debug(3, "SQL: %s", db_get_string(&sql));
- if (db_execute_immediate(Driver, &sql) != DB_OK) {
- G_fatal_error(_("Unable to insert new record: %s"),
- db_get_string(&sql));
- batch_fill = 0;
+ G_debug(3, "SQL: %s", db_get_string(&sql));
+ if (db_execute_immediate(Driver, &sql) != DB_OK) {
+ G_fatal_error(_("Unable to insert new record: %s"),
+ db_get_string(&sql));
attCount++;
- if (batch_fill > 0) {
+ db_commit_transaction(Driver);
db_close_database_shutdown_driver(Driver);
Vect_build(&Map);
