[GRASS-SVN] r55274 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Mar 1 12:43:28 PST 2013
Author: mmetz
Date: 2013-03-01 12:43:28 -0800 (Fri, 01 Mar 2013)
New Revision: 55274
grass/trunk/lib/vector/Vlib/merge_lines.c
Vlib: simplify code
Modified: grass/trunk/lib/vector/Vlib/merge_lines.c
--- grass/trunk/lib/vector/Vlib/merge_lines.c 2013-03-01 20:40:53 UTC (rev 55273)
+++ grass/trunk/lib/vector/Vlib/merge_lines.c 2013-03-01 20:43:28 UTC (rev 55274)
@@ -124,17 +124,8 @@
/* go backward as long as there is only one other line/boundary at the current node */
G_debug(3, "go backward");
- next_node = 0;
- if (ltype == GV_LINE) {
- struct P_topo_l *topo = (struct P_topo_l *)Line->topo;
+ Vect_get_line_nodes(Map, line, &next_node, NULL);
- next_node = topo->N1;
- else if (ltype == GV_BOUNDARY) {
- struct P_topo_b *topo = (struct P_topo_b *)Line->topo;
first = -line;
while (1) {
node_n_lines = Vect_get_node_n_lines(Map, next_node);
@@ -160,28 +151,10 @@
first = next_line;
if (first < 0) {
- struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[-first]->topo;
- struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[-first]->topo;
+ Vect_get_line_nodes(Map, -first, &next_node, NULL);
else {
- struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[first]->topo;
- next_node = topo->N2;
- struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[first]->topo;
+ Vect_get_line_nodes(Map, first, NULL, &next_node);
else
@@ -195,28 +168,10 @@
last = -first;
if (last < 0) {
- struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[-last]->topo;
- struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[-last]->topo;
+ Vect_get_line_nodes(Map, -last, &next_node, NULL);
else {
- struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[last]->topo;
- struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[last]->topo;
+ Vect_get_line_nodes(Map, last, NULL, &next_node);
Vect_reset_list(List);
@@ -244,28 +199,10 @@
last = next_line;
if (last < 0) {
else {
else
@@ -295,7 +232,7 @@
newl++;
- nlines = Vect_get_num_lines(Map);
+ /* nlines = Vect_get_num_lines(Map); */
G_verbose_message(_("%d boundaries merged"), merged);
