[GRASS-SVN] r55278 - in grass/branches/releasebranch_6_4/gui/wxpython: . gui_core location_wizard
svn_grass at osgeo.org
Sun Mar 3 00:43:13 PST 2013
Author: annakrat
Date: 2013-03-03 00:43:13 -0800 (Sun, 03 Mar 2013)
New Revision: 55278
grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_core/dialogs.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_core/widgets.py
grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py
wxGUI: check valid mapset/location name on startup page and in wizard
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2013-03-03 08:41:38 UTC (rev 55277)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2013-03-03 08:43:13 UTC (rev 55278)
@@ -43,7 +43,11 @@
from core.gcmd import GMessage, GError, DecodeString, RunCommand
from core.utils import GetListOfLocations, GetListOfMapsets
from location_wizard.dialogs import RegionDef
+from gui_core.dialogs import TextEntryDialog
+from gui_core.widgets import GenericValidator
+from grass.script import core as grass
sys.stderr = codecs.getwriter('utf8')(sys.stderr)
class GRASSStartup(wx.Frame):
@@ -420,10 +424,12 @@
else:
self.SetDefaultRegion(location = gWizard.location)
- dlg = wx.TextEntryDialog(parent=self,
- message=_("Do you want to create new mapset?"),
- caption=_("Create new mapset"),
- defaultValue=self._getDefaultMapsetName())
+ dlg = TextEntryDialog(parent=self,
+ message=_("Do you want to create new mapset?"),
+ caption=_("Create new mapset"),
+ defaultValue=self._getDefaultMapsetName(),
+ validator=GenericValidator(grass.legal_name, self._nameValidationFailed))
if dlg.ShowModal() == wx.ID_OK:
mapsetName = dlg.GetValue()
self.CreateNewMapset(mapsetName)
@@ -515,9 +521,10 @@
'This mapset cannot be renamed.'))
return
- dlg = wx.TextEntryDialog(parent = self,
- message = _('Current name: %s\n\nEnter new name:') % mapset,
- caption = _('Rename selected mapset'))
+ dlg = TextEntryDialog(parent = self,
+ message = _('Current name: %s\n\nEnter new name:') % mapset,
+ caption = _('Rename selected mapset'),
+ validator = GenericValidator(grass.legal_name, self._nameValidationFailed))
newmapset = dlg.GetValue()
@@ -550,9 +557,10 @@
location = self.listOfLocations[self.lblocations.GetSelection()]
- message = _('Current name: %s\n\nEnter new name:') % location,
- caption = _('Rename selected location'))
+ message = _('Current name: %s\n\nEnter new name:') % location,
+ caption = _('Rename selected location'),
newlocation = dlg.GetValue()
@@ -781,10 +789,11 @@
def OnCreateMapset(self, event):
"""!Create new mapset"""
message = _('Enter name for new mapset:'),
caption = _('Create new mapset'),
- defaultValue = self._getDefaultMapsetName())
+ defaultValue = self._getDefaultMapsetName(),
@@ -903,6 +912,12 @@
event.Skip()
sys.exit(2)
+ def _nameValidationFailed(self, ctrl):
+ message = _("Name <%(name)s> is not a valid name for location or mapset. "
+ "Please use only ASCII characters excluding %(chars)s "
+ "and space.") % {'name': ctrl.GetValue(), 'chars': '/"\'@,=*~'}
+ GError(parent=self, message=message, caption=_("Invalid name"))
class GListBox(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin):
"""!Use wx.ListCtrl instead of wx.ListBox, different style for
non-selectable items (e.g. mapsets with denied permission)"""
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/dialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/dialogs.py 2013-03-03 08:41:38 UTC (rev 55277)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/dialogs.py 2013-03-03 08:43:13 UTC (rev 55278)
@@ -2357,3 +2357,33 @@
"""!Returns currently selected symbol full path.
return os.path.join(self.symbolPath, self.selectedDir, self.selected)
+class TextEntryDialog(wx.Dialog):
+ """!Simple dialog with text field.
+ It differs from wx.TextEntryDialog because it allows adding validator.
+ def __init__(self, parent, message, caption='',
+ defaultValue='', pos=wx.DefaultPosition, validator=wx.DefaultValidator):
+ wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=caption, pos=pos)
+ vbox = wx.BoxSizer(wx.VERTICAL)
+ stline = wx.StaticText(self, id=wx.ID_ANY, label=message)
+ vbox.Add(item=stline, proportion=0, flag=wx.EXPAND | wx.ALL, border=10)
+ self._textCtrl = wx.TextCtrl(self, id=wx.ID_ANY, size = (300, -1),
+ value=defaultValue, validator=validator)
+ vbox.Add(item=self._textCtrl, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=10)
+ self._textCtrl.SetFocus()
+ sizer = self.CreateSeparatedButtonSizer(wx.CANCEL | wx.OK)
+ vbox.Add(item=sizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=10)
+ self.SetSizerAndFit(vbox)
+ def GetValue(self):
+ return self._textCtrl.GetValue()
+ def SetValue(self, value):
+ self._textCtrl.SetValue(value)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/widgets.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/widgets.py 2013-03-03 08:41:38 UTC (rev 55277)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/widgets.py 2013-03-03 08:43:13 UTC (rev 55278)
@@ -335,7 +335,52 @@
# Returning without calling even.Skip eats the event before it
# gets to the text control
return
+class GenericValidator(wx.PyValidator):
+ """ This validator checks condition and calls callback
+ in case the condition is not fulfilled.
+ def __init__(self, condition, callback):
+ """ Standard constructor.
+ @param condition function which accepts string value and returns T/F
+ @param callback function which is called when condition is not fulfilled
+ wx.PyValidator.__init__(self)
+ self._condition = condition
+ self._callback = callback
+ def Clone(self):
+ """ Standard cloner.
+ Note that every validator must implement the Clone() method.
+ return GenericValidator(self._condition, self._callback)
+ def Validate(self, win):
+ """ Validate the contents of the given text control.
+ ctrl = self.GetWindow()
+ text = ctrl.GetValue()
+ if not self._condition(text):
+ self._callback(ctrl)
+ return False
+ else:
+ return True
+ def TransferToWindow(self):
+ """ Transfer data from validator to window.
+ return True # Prevent wxDialog from complaining.
+ def TransferFromWindow(self):
+ """ Transfer data from window to validator.
class ItemTree(CT.CustomTreeCtrl):
def __init__(self, parent, id = wx.ID_ANY,
ctstyle = CT.TR_HIDE_ROOT | CT.TR_FULL_ROW_HIGHLIGHT | CT.TR_HAS_BUTTONS |
Modified: grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py
--- grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py 2013-03-03 08:41:38 UTC (rev 55277)
+++ grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py 2013-03-03 08:43:13 UTC (rev 55278)
@@ -42,6 +42,7 @@
from core import utils
from core.gcmd import RunCommand, GError, GMessage, GWarning
from gui_core.ghelp import HelpFrame
from location_wizard.base import BaseClass
from location_wizard.dialogs import SelectTransformDialog
@@ -102,6 +103,7 @@
# text controls
self.tgisdbase = self.MakeTextCtrl(grassdatabase, size = (300, -1))
self.tlocation = self.MakeTextCtrl("newLocation", size = (300, -1))
+ self.tlocation.SetValidator(GenericValidator(grass.legal_name, self._nameValidationFailed))
self.tlocTitle = self.MakeTextCtrl(size = (400, -1))
# layout
@@ -153,6 +155,12 @@
self.tgisdbase.Bind(wx.EVT_TEXT, self.OnChangeName)
self.tlocation.Bind(wx.EVT_TEXT, self.OnChangeName)
+ message = _("Name <%(name)s> is not a valid name for location. "
+ GError(parent=self, message=message, caption=_("Invalid location name"))
def OnChangeName(self, event):
"""!Name for new location was changed"""
nextButton = wx.FindWindowById(wx.ID_FORWARD)
