[GRASS-SVN] r55314 - in grass/branches/develbranch_6: gui/wxpython gui/wxpython/gui_core gui/wxpython/location_wizard lib/python
svn_grass at osgeo.org
Mon Mar 11 06:27:21 PDT 2013
Author: annakrat
Date: 2013-03-11 06:27:20 -0700 (Mon, 11 Mar 2013)
New Revision: 55314
grass/branches/develbranch_6/gui/wxpython/gis_set.py
grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_core/widgets.py
grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
grass/branches/develbranch_6/lib/python/core.py
wxGUI/startup: merge changes from #1889
Modified: grass/branches/develbranch_6/gui/wxpython/gis_set.py
--- grass/branches/develbranch_6/gui/wxpython/gis_set.py 2013-03-11 12:43:20 UTC (rev 55313)
+++ grass/branches/develbranch_6/gui/wxpython/gis_set.py 2013-03-11 13:27:20 UTC (rev 55314)
@@ -26,6 +26,7 @@
import copy
import platform
import codecs
+import getpass
### i18N
import gettext
@@ -44,7 +45,11 @@
from core.gcmd import GMessage, GError, DecodeString, RunCommand, GWarning
from core.utils import GetListOfLocations, GetListOfMapsets
from location_wizard.dialogs import RegionDef
+from gui_core.dialogs import TextEntryDialog
+from gui_core.widgets import GenericValidator
+from grass.script import core as grass
sys.stderr = codecs.getwriter('utf8')(sys.stderr)
class GRASSStartup(wx.Frame):
@@ -428,7 +433,17 @@
else:
self.SetDefaultRegion(location = gWizard.location)
- self.ExitSuccessfully()
+ dlg = TextEntryDialog(parent=self,
+ message=_("Do you want to create new mapset?"),
+ caption=_("Create new mapset"),
+ defaultValue=self._getDefaultMapsetName(),
+ validator=GenericValidator(grass.legal_name, self._nameValidationFailed),
+ style=wx.OK | wx.CANCEL | wx.HELP)
+ help = dlg.FindWindowById(wx.ID_HELP)
+ help.Bind(wx.EVT_BUTTON, self.OnHelp)
+ if dlg.ShowModal() == wx.ID_OK:
+ mapsetName = dlg.GetValue()
+ self.CreateNewMapset(mapsetName)
def SetDefaultRegion(self, location):
"""!Asks to set default region."""
@@ -511,9 +526,10 @@
'This mapset cannot be renamed.'))
return
- dlg = wx.TextEntryDialog(parent = self,
- message = _('Current name: %s\n\nEnter new name:') % mapset,
- caption = _('Rename selected mapset'))
+ dlg = TextEntryDialog(parent = self,
+ message = _('Current name: %s\n\nEnter new name:') % mapset,
+ caption = _('Rename selected mapset'),
+ validator = GenericValidator(grass.legal_name, self._nameValidationFailed))
newmapset = dlg.GetValue()
@@ -546,9 +562,10 @@
location = self.listOfLocations[self.lblocations.GetSelection()]
- message = _('Current name: %s\n\nEnter new name:') % location,
- caption = _('Rename selected location'))
+ message = _('Current name: %s\n\nEnter new name:') % location,
+ caption = _('Rename selected location'),
newlocation = dlg.GetValue()
@@ -774,39 +791,44 @@
dlg.Destroy()
- def OnCreateMapset(self,event):
+ def OnCreateMapset(self, event):
"""!Create new mapset"""
- self.gisdbase = self.tgisdbase.GetValue()
- location = self.listOfLocations[self.lblocations.GetSelection()]
message = _('Enter name for new mapset:'),
- caption = _('Create new mapset'))
+ caption = _('Create new mapset'),
+ defaultValue = self._getDefaultMapsetName(),
- if dlg.ShowModal() == wx.ID_OK:
- if mapset in self.listOfMapsets:
- GMessage(parent = self,
- message = _("Mapset <%s> already exists.") % mapset)
- return
- try:
- os.mkdir(os.path.join(self.gisdbase, location, mapset))
- # copy WIND file and its permissions from PERMANENT and set permissions to u+rw,go+r
- shutil.copy(os.path.join(self.gisdbase, location, 'PERMANENT', 'WIND'),
- os.path.join(self.gisdbase, location, mapset))
- # os.chmod(os.path.join(database,location,mapset,'WIND'), 0644)
- self.OnSelectLocation(None)
- self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
- except StandardError, e:
- GError(parent = self,
- message = _("Unable to create new mapset: %s") % e,
- showTraceback = False)
- return False
+ return self.CreateNewMapset(mapset = mapset)
+ else:
+ return False
+ def CreateNewMapset(self, mapset):
+ if mapset in self.listOfMapsets:
+ GMessage(parent = self,
+ message = _("Mapset <%s> already exists.") % mapset)
+ return False
- self.bstart.SetFocus()
- return True
+ try:
+ self.gisdbase = self.tgisdbase.GetValue()
+ location = self.listOfLocations[self.lblocations.GetSelection()]
+ os.mkdir(os.path.join(self.gisdbase, location, mapset))
+ # copy WIND file and its permissions from PERMANENT and set permissions to u+rw,go+r
+ shutil.copy(os.path.join(self.gisdbase, location, 'PERMANENT', 'WIND'),
+ os.path.join(self.gisdbase, location, mapset))
+ # os.chmod(os.path.join(database,location,mapset,'WIND'), 0644)
+ self.OnSelectLocation(None)
+ self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
+ self.bstart.SetFocus()
+ return True
+ except StandardError, e:
+ GError(parent = self,
+ message = _("Unable to create new mapset: %s") % e,
+ showTraceback = False)
+ return False
def OnStart(self, event):
"""'Start GRASS' button clicked"""
@@ -862,8 +884,18 @@
set = "LOCATION_NAME=%s" % location)
RunCommand("g.gisenv",
set = "MAPSET=%s" % mapset)
+ def _getDefaultMapsetName(self):
+ """!Returns default name for mapset."""
+ try:
+ defaultName = getpass.getuser()
+ defaultName.encode('ascii') # raise error if not ascii (not valid mapset name)
+ except: # whatever might go wrong
+ defaultName = 'user'
+ return defaultName
def ExitSuccessfully(self):
self.Destroy()
sys.exit(0)
@@ -885,6 +917,12 @@
event.Skip()
sys.exit(2)
+ def _nameValidationFailed(self, ctrl):
+ message = _("Name <%(name)s> is not a valid name for location or mapset. "
+ "Please use only ASCII characters excluding %(chars)s "
+ "and space.") % {'name': ctrl.GetValue(), 'chars': '/"\'@,=*~'}
+ GError(parent=self, message=message, caption=_("Invalid name"))
class GListBox(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin):
"""!Use wx.ListCtrl instead of wx.ListBox, different style for
non-selectable items (e.g. mapsets with denied permission)"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py 2013-03-11 12:43:20 UTC (rev 55313)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py 2013-03-11 13:27:20 UTC (rev 55314)
@@ -2406,3 +2406,34 @@
"""!Returns currently selected symbol full path.
return os.path.join(self.symbolPath, self.selectedDir, self.selected)
+class TextEntryDialog(wx.Dialog):
+ """!Simple dialog with text field.
+ It differs from wx.TextEntryDialog because it allows adding validator.
+ def __init__(self, parent, message, caption='',
+ defaultValue='', pos=wx.DefaultPosition, validator=wx.DefaultValidator,
+ style=wx.OK | wx.CANCEL):
+ wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=caption, pos=pos)
+ vbox = wx.BoxSizer(wx.VERTICAL)
+ stline = wx.StaticText(self, id=wx.ID_ANY, label=message)
+ vbox.Add(item=stline, proportion=0, flag=wx.EXPAND | wx.ALL, border=10)
+ self._textCtrl = wx.TextCtrl(self, id=wx.ID_ANY, size = (300, -1),
+ value=defaultValue, validator=validator)
+ vbox.Add(item=self._textCtrl, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=10)
+ self._textCtrl.SetFocus()
+ sizer = self.CreateSeparatedButtonSizer(style)
+ vbox.Add(item=sizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=10)
+ self.SetSizerAndFit(vbox)
+ def GetValue(self):
+ return self._textCtrl.GetValue()
+ def SetValue(self, value):
+ self._textCtrl.SetValue(value)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/widgets.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/widgets.py 2013-03-11 12:43:20 UTC (rev 55313)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/widgets.py 2013-03-11 13:27:20 UTC (rev 55314)
@@ -335,7 +335,52 @@
# Returning without calling even.Skip eats the event before it
# gets to the text control
return
+class GenericValidator(wx.PyValidator):
+ """ This validator checks condition and calls callback
+ in case the condition is not fulfilled.
+ def __init__(self, condition, callback):
+ """ Standard constructor.
+ @param condition function which accepts string value and returns T/F
+ @param callback function which is called when condition is not fulfilled
+ wx.PyValidator.__init__(self)
+ self._condition = condition
+ self._callback = callback
+ def Clone(self):
+ """ Standard cloner.
+ Note that every validator must implement the Clone() method.
+ return GenericValidator(self._condition, self._callback)
+ def Validate(self, win):
+ """ Validate the contents of the given text control.
+ ctrl = self.GetWindow()
+ text = ctrl.GetValue()
+ if not self._condition(text):
+ self._callback(ctrl)
+ return False
+ else:
+ return True
+ def TransferToWindow(self):
+ """ Transfer data from validator to window.
+ return True # Prevent wxDialog from complaining.
+ def TransferFromWindow(self):
+ """ Transfer data from window to validator.
class ItemTree(CT.CustomTreeCtrl):
def __init__(self, parent, id = wx.ID_ANY,
ctstyle = CT.TR_HIDE_ROOT | CT.TR_FULL_ROW_HIGHLIGHT | CT.TR_HAS_BUTTONS |
Modified: grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
--- grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py 2013-03-11 12:43:20 UTC (rev 55313)
+++ grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py 2013-03-11 13:27:20 UTC (rev 55314)
@@ -42,6 +42,7 @@
from core import utils
from core.gcmd import RunCommand, GError, GMessage, GWarning
from gui_core.ghelp import HelpFrame
from location_wizard.base import BaseClass
from location_wizard.dialogs import SelectTransformDialog
@@ -102,6 +103,7 @@
# text controls
self.tgisdbase = self.MakeTextCtrl(grassdatabase, size = (300, -1))
self.tlocation = self.MakeTextCtrl("newLocation", size = (300, -1))
+ self.tlocation.SetValidator(GenericValidator(grass.legal_name, self._nameValidationFailed))
self.tlocTitle = self.MakeTextCtrl(size = (400, -1))
# layout
@@ -153,6 +155,12 @@
self.tgisdbase.Bind(wx.EVT_TEXT, self.OnChangeName)
self.tlocation.Bind(wx.EVT_TEXT, self.OnChangeName)
+ message = _("Name <%(name)s> is not a valid name for location. "
+ GError(parent=self, message=message, caption=_("Invalid location name"))
def OnChangeName(self, event):
"""!Name for new location was changed"""
nextButton = wx.FindWindowById(wx.ID_FORWARD)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2013-03-11 12:43:20 UTC (rev 55313)
+++ grass/branches/develbranch_6/lib/python/core.py 2013-03-11 13:27:20 UTC (rev 55314)
@@ -1199,3 +1199,24 @@
# get debug_level
if find_program('g.gisenv', ['--help']):
debug_level = int(gisenv().get('DEBUG', 0))
+def legal_name(s):
+ """!Checks if the string contains only allowed characters.
+ This is the Python implementation of G_legal_filename() function.
+ @note It is not clear when to use this function.
+ if not s or s[0] == '.':
+ warning(_("Illegal filename <%s>. Cannot be empty or start with '.'.") % s)
+ return False
+ illegal = [c
+ for c in s
+ if c in '/"\'@,=*~' or c <= ' ' or c >= '\177']
+ if illegal:
+ illegal = ''.join(sorted(set(illegal)))
+ warning(_("Illegal filename <%s>. <%s> not allowed.\n") % (s, illegal))
+ return False
+ return True
