[GRASS-SVN] r55331 - grass/trunk/lib/python/pydispatch
svn_grass at osgeo.org
Mon Mar 11 15:16:58 PDT 2013
Author: wenzeslaus
Date: 2013-03-11 15:16:57 -0700 (Mon, 11 Mar 2013)
New Revision: 55331
grass/trunk/lib/python/pydispatch/signal.py
pythonlib/pydispatch: doc test for signal, fixing disconnect (i.e. g.gui.iclass)
Modified: grass/trunk/lib/python/pydispatch/signal.py
--- grass/trunk/lib/python/pydispatch/signal.py 2013-03-11 20:56:50 UTC (rev 55330)
+++ grass/trunk/lib/python/pydispatch/signal.py 2013-03-11 22:16:57 UTC (rev 55331)
@@ -19,10 +19,66 @@
class Signal(object):
+ >>> signal1 = Signal('signal1')
+ >>> def handler1():
+ ... print "from handler1"
+ >>> signal1.connect(handler1)
+ >>> signal2 = Signal('signal2')
+ >>> def handler2(text):
+ ... print "handler2: %s" % text
+ >>> signal2.connect(handler2)
+ >>> signal1.emit()
+ from handler1
+ >>> signal2.emit(text="Hello")
+ handler2: Hello
+ >>> import sys
+ >>> signal2.connect(lambda text: sys.stdout.write('lambda handler: %s\\n' % text))
+ >>> signal2.emit(text="Hi")
+ handler2: Hi
+ lambda handler: Hi
+ >>> def handler3():
+ ... print "from handler3"
+ >>> signal2.connect(handler3)
+ >>> signal2.emit(text="Ciao")
+ handler2: Ciao
+ lambda handler: Ciao
+ from handler3
+ >>> signal3 = Signal('signal3')
+ >>> signal3.connect(handler3)
+ >>> signal1.connect(signal3)
+ from handler1
+ from handler3
+ >>> signal3.disconnect(handler3)
+ from handler1
+ >>> signal2.disconnect(handler2)
+ >>> signal2.disconnect(handler3)
+ >>> signal2.emit(text='Hello')
+ lambda handler: Hello
def __init__(self, name):
self._name = name
def connect(self, handler, weak=None):
+ >>> import sys
+ >>> signal1.connect(lambda: sys.stdout.write('will print\\n'))
+ >>> signal1.connect(lambda: sys.stdout.write('will print\\n'), weak=False)
+ >>> signal1.connect(lambda: sys.stdout.write('will not print'), weak=True)
+ will print
+ will print
if weak is None:
if _islambda(handler):
weak = False
@@ -30,8 +86,8 @@
weak = True
dispatcher.connect(receiver=handler, signal=self, weak=weak)
- def disconnect(self, handler):
- dispatcher.disconnect(receiver=handler, signal=self, weak=None)
+ def disconnect(self, handler, weak=True):
+ dispatcher.disconnect(receiver=handler, signal=self, weak=weak)
def emit(self, *args, **kwargs):
dispatcher.send(signal=self, *args, **kwargs)
@@ -43,32 +99,5 @@
if __name__ == '__main__':
- def handler1():
- print "handler1"
- def handler2(text):
- print "handler2: %s" % text
- class A(object):
- def showText(self, text):
- print "showing text:", text
- def showMessage(self):
- print "showing message"
- def test():
- import sys
- signal1 = Signal('signal1')
- signal2 = Signal('signal2')
- signal3 = Signal('signal3')
- signal1.connect(handler1)
- signal2.connect(handler2)
- signal2.connect(lambda text: sys.stdout.write('lambda handler 1: %s\n' % text))
- signal2.connect(signal3)
- signal3.connect(handler2)
- a = A()
- signal2.connect(a.showText)
- signal2.connect(a.showMessage)
- signal1.emit()
- signal2.emit(text="Hello")
- test()
\ No newline at end of file
+ import doctest
+ doctest.testmod()
