[GRASS-SVN] r55338 - in grass/branches/develbranch_6/lib: gis init
svn_grass at osgeo.org
Tue Mar 12 12:47:34 PDT 2013
Author: martinl
Date: 2013-03-12 12:47:34 -0700 (Tue, 12 Mar 2013)
New Revision: 55338
grass/branches/develbranch_6/lib/gis/mapset_msc.c
grass/branches/develbranch_6/lib/init/variables.html
backport GRASS_SKIP_MAPSET_OWNER_CHECK from trunk
Modified: grass/branches/develbranch_6/lib/gis/mapset_msc.c
--- grass/branches/develbranch_6/lib/gis/mapset_msc.c 2013-03-12 18:19:40 UTC (rev 55337)
+++ grass/branches/develbranch_6/lib/gis/mapset_msc.c 2013-03-12 19:47:34 UTC (rev 55338)
@@ -87,6 +87,22 @@
return G__make_mapset_element(buf);
+static int check_owner(const struct stat *info)
+#if defined(__MINGW32__) || defined(SKIP_MAPSET_OWN_CHK)
+ return 1;
+#else
+ const char *check = getenv("GRASS_SKIP_MAPSET_OWNER_CHECK");
+ if (check && *check)
+ return 1;
+ if (info->st_uid != getuid())
+ return 0;
+ if (info->st_uid != geteuid())
+ return 0;
+ return 1;
+#endif
\brief Check for user mapset permission
@@ -108,12 +124,8 @@
if (!S_ISDIR(info.st_mode))
return -1;
-#ifndef __MINGW32__
- if (info.st_uid != getuid())
+ if (!check_owner(&info))
return 0;
- if (info.st_uid != geteuid())
- return 0;
-#endif
return 1;
@@ -142,12 +154,8 @@
return -1;
return 0;
- return 0;
-#endif
return 1;
Modified: grass/branches/develbranch_6/lib/init/variables.html
--- grass/branches/develbranch_6/lib/init/variables.html 2013-03-12 18:19:40 UTC (rev 55337)
+++ grass/branches/develbranch_6/lib/init/variables.html 2013-03-12 19:47:34 UTC (rev 55338)
@@ -239,6 +239,11 @@
<br> set to any value to prevent user mail on error
+ <dt>GRASS_SKIP_MAPSET_OWNER_CHECK</dt>
+ <dd>By default it is not possible to work with MAPSETs that are
+ not owned by current user. Setting this variable to any non-empty value
+ allows the check to be skipped.</dd>
<dt>GRASS_SH</dt>
<dd>[shell scripts on Windows]<br>
path to bourne shell interpreter used to run shell scripts.</dd>
