[GRASS-SVN] r55342 - grass/trunk/lib/python/pydispatch
svn_grass at osgeo.org
Tue Mar 12 16:20:08 PDT 2013
Author: wenzeslaus
Date: 2013-03-12 16:20:08 -0700 (Tue, 12 Mar 2013)
New Revision: 55342
grass/trunk/lib/python/pydispatch/signal.py
pythonlib/pydispatch: more doc test for signal
Modified: grass/trunk/lib/python/pydispatch/signal.py
--- grass/trunk/lib/python/pydispatch/signal.py 2013-03-12 21:49:26 UTC (rev 55341)
+++ grass/trunk/lib/python/pydispatch/signal.py 2013-03-12 23:20:08 UTC (rev 55342)
@@ -14,6 +14,12 @@
Should work on the most of Python implementations where name of lambda
function is not unique.
+ >>> mylambda = lambda x: x*x
+ >>> _islambda(mylambda)
+ True
+ >>> _islambda(_islambda)
+ False
return isinstance(function, type(lambda: None)) and function.__name__== (lambda: None).__name__
@@ -37,7 +43,8 @@
handler2: Hello
>>> import sys
- >>> signal2.connect(lambda text: sys.stdout.write('lambda handler: %s\\n' % text))
+ >>> signal2.connect(lambda text:
+ ... sys.stdout.write('lambda handler: %s\\n' % text))
>>> signal2.emit(text="Hi")
handler2: Hi
lambda handler: Hi
@@ -87,17 +94,81 @@
dispatcher.connect(receiver=handler, signal=self, weak=weak)
def disconnect(self, handler, weak=True):
+ >>> signal1 = Signal('signal1')
+ >>> import sys
+ >>> signal1.connect(sys.stdout.write)
+ >>> signal1.disconnect(sys.stdout.write)
+ >>> signal1.disconnect(sys.stdout.flush) #doctest: +ELLIPSIS
+ Traceback (most recent call last):
+ DispatcherKeyError: 'No receivers found for signal <__main__.Signal object at 0x...> from sender _Any'
+ >>> signal1.disconnect(some_function)
+ NameError: name 'some_function' is not defined
+ >>> signal1.emit()
dispatcher.disconnect(receiver=handler, signal=self, weak=weak)
+ # TODO: remove args?, make it work for args?
def emit(self, *args, **kwargs):
+ >>> def mywrite(text):
+ ... print text
+ >>> signal1.connect(mywrite)
+ >>> signal1.emit(text='Hello')
+ Hello
+ TypeError: mywrite() takes exactly 1 argument (0 given)
+ >>> signal1.emit('Hello')
+ TypeError: send() got multiple values for keyword argument 'signal'
dispatcher.send(signal=self, *args, **kwargs)
- def __call__(self, *arguments, **named):
- if 'signal' in named:
- del named['signal']
- self.emit(*arguments, **named)
+ def __call__(self, *args, **kwargs):
+ """Allows to emit signal with function call syntax.
+ It allows to handle signal as a function or other callable object.
+ So, the signal can be in the list of fuctions or can be connected as
+ a handler for another signal.
+ However, it is strongly recommended to use emit method for direct
+ signal emitting.
+ The use of emit method is more explicit than the function call
+ and thus it it clear that we are using signal.
+ ... print text
+ >>> functions = [signal1, lambda text: mywrite(text + '!')]
+ >>> for function in functions:
+ ... function(text='text')
+ text
+ text!
+ The other reason why the function call should not by used when it is
+ possible to use emit method is that this function does ugly hack to
+ enable calling as a signal handler. The signal parameter is deleted
+ when it is in named keyword arguments. As a consequence, when the
+ signal is emitted with the signal parameter (which is a very bad
+ name for parameter when using signals), the error is much more readable
+ when using emit than function call. Concluding remark is that
+ emit behaves more predictable.
+ >>> signal1.emit(signal='Hello')
+ >>> signal1(signal='Hello')
+ if 'signal' in kwargs:
+ del kwargs['signal']
+ self.emit(*args, **kwargs)
if __name__ == '__main__':
import doctest
doctest.testmod()
