[GRASS-SVN] r55356 - grass-addons/grass6/raster/r.stream.stats
Wed Mar 13 04:33:23 PDT 2013
Author: martinl
Date: 2013-03-13 04:33:23 -0700 (Wed, 13 Mar 2013)
New Revision: 55356
   grass-addons/grass6/raster/r.stream.stats/global.h
/r.stream.stats: fix compilation issues
Modified: grass-addons/grass6/raster/r.stream.stats/global.h
--- grass-addons/grass6/raster/r.stream.stats/global.h	2013-03-13 11:13:30 UTC (rev 55355)
+++ grass-addons/grass6/raster/r.stream.stats/global.h	2013-03-13 11:33:23 UTC (rev 55356)
@@ -107,15 +107,15 @@
 GLOBAL int nrows, ncols;
-POINT *fifo_outlet;
-int tail, head;
-int fifo_max;
+GLOBAL POINT *fifo_outlet;
+GLOBAL int tail, head;
+GLOBAL int fifo_max;
 GLOBAL int outlets_num; /* number outlets: index for stream statistics*/
-STREAM *stat_streams;
-STATS *ord_stats;
-STATS stats_total;
-int order_max;
+GLOBAL STREAM *stat_streams;
+GLOBAL STATS *ord_stats;
+GLOBAL STATS stats_total;
+GLOBAL int order_max;
 GLOBAL struct History history;	/* holds meta-data (title, comments,..) */
 GLOBAL struct Cell_head window;
