[GRASS-SVN] r55362 - in grass/trunk: include/defs lib/btree2
Wed Mar 13 07:43:24 PDT 2013
Author: mmetz
Date: 2013-03-13 07:43:24 -0700 (Wed, 13 Mar 2013)
New Revision: 55362
   grass/trunk/include/defs/rbtree.h
   grass/trunk/lib/btree2/rbtree.c
rbtree: add backward traversal
Modified: grass/trunk/include/defs/rbtree.h
--- grass/trunk/include/defs/rbtree.h	2013-03-13 14:40:22 UTC (rev 55361)
+++ grass/trunk/include/defs/rbtree.h	2013-03-13 14:43:24 UTC (rev 55362)
@@ -12,6 +12,7 @@
 /* tree traversal functions */
 int rbtree_init_trav(struct RB_TRAV *, struct RB_TREE *);
 void* rbtree_traverse(struct RB_TRAV *);
+void *rbtree_traverse_backwd(struct RB_TRAV *trav);
 void *rbtree_traverse_start(struct RB_TRAV *, const void *);
 /* debug tree from given node downwards */
Modified: grass/trunk/lib/btree2/rbtree.c
--- grass/trunk/lib/btree2/rbtree.c	2013-03-13 14:40:22 UTC (rev 55361)
+++ grass/trunk/lib/btree2/rbtree.c	2013-03-13 14:43:24 UTC (rev 55362)
@@ -37,7 +37,9 @@
 static struct RB_NODE *rbtree_single(struct RB_NODE *, int);
 static struct RB_NODE *rbtree_double(struct RB_NODE *, int);
 static void *rbtree_first(struct RB_TRAV *);
+static void *rbtree_last(struct RB_TRAV *trav);
 static void *rbtree_next(struct RB_TRAV *);
+static void *rbtree_previous(struct RB_TRAV *);
 static struct RB_NODE *rbtree_make_node(size_t, void *);
 static int is_red(struct RB_NODE *);
@@ -297,6 +299,32 @@
+/* traverse the tree in descending order
+ * useful to get all items in the tree non-recursively
+ * struct RB_TRAV *trav needs to be initialized first
+ * returns pointer to data, NULL when finished
+    assert(trav);
+    if (trav->curr_node == NULL) {
+	if (trav->first)
+	    G_debug(1, "RB tree: empty tree");
+	else
+	    G_debug(1, "RB tree: finished traversing");
+	return NULL;
+    if (!trav->first)
+	return rbtree_previous(trav);
+    else {
+	trav->first = 0;
+	return rbtree_last(trav);
 /* find start point to traverse the tree in ascending order
  * useful to get a selection of items in the tree
  * magnitudes faster than traversing the whole tree
@@ -359,7 +387,7 @@
 /* start traversing the tree
  * returns pointer to smallest data item
-void *rbtree_first(struct RB_TRAV *trav)
+static void *rbtree_first(struct RB_TRAV *trav)
     /* get smallest item */
     while (trav->curr_node->link[0] != NULL) {
@@ -370,6 +398,20 @@
     return trav->curr_node->data;	/* return smallest item */
+/* start traversing the tree
+ * returns pointer to largest data item
+    /* get smallest item */
+    while (trav->curr_node->link[1] != NULL) {
+	trav->up[trav->top++] = trav->curr_node;
+	trav->curr_node = trav->curr_node->link[1];
+    return trav->curr_node->data;	/* return smallest item */
 /* continue traversing the tree in ascending order
  * returns pointer to data item, NULL when finished
@@ -407,6 +449,43 @@
 	return NULL;		/* finished traversing */
+/* continue traversing the tree in descending order
+ * returns pointer to data item, NULL when finished
+void *rbtree_previous(struct RB_TRAV *trav)
+    if (trav->curr_node->link[0] != NULL) {
+	/* something on the left side: smaller item */
+	trav->curr_node = trav->curr_node->link[0];
+	/* go down, find largest item in this branch */
+    else {
+	/* at largest item in this branch, go back up */
+	struct RB_NODE *last;
+	do {
+	    if (trav->top == 0) {
+		trav->curr_node = NULL;
+		break;
+	    last = trav->curr_node;
+	    trav->curr_node = trav->up[--trav->top];
+	} while (last == trav->curr_node->link[0]);
+    if (trav->curr_node != NULL) {
+    else
+	return NULL;		/* finished traversing */
 /* clear the tree, removing all entries */
 void rbtree_clear(struct RB_TREE *tree)
