[GRASS-SVN] r55383 - in grass/trunk/gui/wxpython: gui_core lmgr web_services
svn_grass at osgeo.org
Thu Mar 14 12:45:32 PDT 2013
Author: annakrat
Date: 2013-03-14 12:45:32 -0700 (Thu, 14 Mar 2013)
New Revision: 55383
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/web_services/dialogs.py
wxGUI: continue replacing events
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2013-03-14 19:40:54 UTC (rev 55382)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2013-03-14 19:45:32 UTC (rev 55383)
@@ -54,7 +54,7 @@
import grass.temporal as tgis
from grass.script import task as gtask
-from gui_core.widgets import ManageSettingsWidget, EVT_SETTINGS_CHANGED, EVT_SETTINGS_SAVING
+from gui_core.widgets import ManageSettingsWidget
from core.gcmd import RunCommand, GError, GMessage
from core.utils import GetListOfLocations, GetListOfMapsets, GetFormats
@@ -1174,8 +1174,8 @@
self.settsManager = ManageSettingsWidget(parent = self,
id = wx.ID_ANY,
settingsFile = settingsFile)
- self.settsManager.Bind(EVT_SETTINGS_CHANGED, self.OnSettingsChanged)
- self.settsManager.Bind(EVT_SETTINGS_SAVING, self.OnSettingsSaving)
+ self.settsManager.settingsChanged.connect(self.OnSettingsChanged)
+ self.settsManager.settingsSaving.connect(self.OnSettingsSaving)
self.inputBox = wx.StaticBox(parent = self, id = wx.ID_ANY)
if dest:
@@ -1408,10 +1408,8 @@
self.SetSizer(mainSizer)
mainSizer.Fit(self)
- def OnSettingsChanged(self, event):
+ def OnSettingsChanged(self, data):
"""!User changed setting"""
- data = event.data
# data list: [type, dsn, format, options]
if len(data) == 3:
data.append('')
@@ -1423,7 +1421,7 @@
self.OnSetDsn(event = None, path = data[1])
self.creationOpt.SetValue(data[3])
- def OnSettingsSaving(self, event):
+ def OnSettingsSaving(self, name):
"""!Saving data"""
if not self.GetDsn():
GMessage(parent = self,
@@ -1433,7 +1431,7 @@
self.settsManager.SetDataToSave((self.dsnType, self.GetDsn(),
self.format.GetStringSelection(),
self.creationOpt.GetValue()))
- event.Skip()
+ self.settsManager.SaveSettings(name)
def _getExtPatternGlob(self, ext):
"""!Get pattern for case-insensitive globing"""
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2013-03-14 19:40:54 UTC (rev 55382)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2013-03-14 19:45:32 UTC (rev 55383)
@@ -40,7 +40,7 @@
import wx.lib.mixins.listctrl as listmix
import wx.lib.scrolledpanel as SP
-from wx.lib.newevent import NewEvent
+from grass.pydispatch.signal import Signal
from grass.script import core as grass
@@ -50,8 +50,6 @@
from core.settings import UserSettings
from gui_core.dialogs import SymbolDialog
-wxSettingsChanged, EVT_SETTINGS_CHANGED = NewEvent()
class PreferencesBaseDialog(wx.Dialog):
"""!Base preferences dialog"""
def __init__(self, parent, giface, settings, title = _("User settings"),
@@ -66,6 +64,8 @@
wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title,
style = style)
+ self.settingsChanged = Signal('PreferencesBaseDialog.settingsChanged')
# notebook
self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
@@ -145,12 +145,11 @@
def OnApply(self, event):
"""!Button 'Apply' pressed
- Posts event EVT_SETTINGS_CHANGED.
+ Emits signal settingsChanged.
if self._updateSettings():
self._giface.WriteLog(_('Settings applied to current session but not saved'))
- event = wxSettingsChanged()
- wx.PostEvent(self, event)
+ self.settingsChanged.emit()
self.Close()
def OnCloseWindow(self, event):
@@ -162,7 +161,7 @@
def OnSave(self, event):
"""!Button 'Save' pressed
lang = self.settings.Get(group = 'language', key = 'locale', subkey = 'lc_all')
@@ -180,8 +179,7 @@
StoreEnvVariable(key = 'LANG', value = lang)
else:
StoreEnvVariable(key = 'LANG')
self.Close()
def _updateSettings(self):
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2013-03-14 19:40:54 UTC (rev 55382)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2013-03-14 19:45:32 UTC (rev 55383)
@@ -52,16 +52,12 @@
from core import globalvar
-from core.gcmd import GMessage
+from core.gcmd import GMessage, GError
from core.debug import Debug
wxSymbolSelectionChanged, EVT_SYMBOL_SELECTION_CHANGED = NewEvent()
-# ManageSettingsWidget
-wxOnSettingsLoaded, EVT_SETTINGS_LOADED = NewEvent()
-wxOnSettingsChanged, EVT_SETTINGS_CHANGED = NewEvent()
-wxOnSettingsSaving, EVT_SETTINGS_SAVING = NewEvent()
class NotebookController:
"""!Provides handling of notebook page names.
@@ -979,22 +975,23 @@
"""!Widget which allows loading and saving settings into file."""
def __init__(self, parent, settingsFile, id = wx.ID_ANY):
- Events:
- EVT_SETTINGS_CHANGED - called when users changes setting
- - event object has attribute 'data', with chosen setting data
- EVT_SETTINGS_SAVING - called when settings are saving
- - If you bind instance of ManageSettingsWidget with this event,
- you can use SetDataToSave method to set data for save and then call
- Skip() to save the data.
- If you do not call Skip(), the data will not be saved.
- EVT_SETTINGS_LOADED - called when settings are loaded
- - event object has attribute 'settings', which is dict with loaded settings
- {nameofsetting : settingdata, ....}
+ Signals:
+ settingsChanged - called when users changes setting
+ - attribute 'data' with chosen setting data
+ settingsSaving - called when settings are saving
+ - attribute 'name' with chosen settings name
+ settingsLoaded - called when settings are loaded
+ - attribute 'settings' is dict with loaded settings
+ {nameofsetting : settingdata, ....}
@param settingsFile - path to file, where settings will be saved and loaded from
self.settingsFile = settingsFile
+ self.settingsChanged = Signal('ManageSettingsWidget.settingsChanged')
+ self.settingsSaving = Signal('ManageSettingsWidget.settingsSaving')
+ self.settingsLoaded = Signal('ManageSettingsWidget.settingsLoaded')
wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
self.settingsBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
@@ -1009,15 +1006,12 @@
self.btnSettingsDel.Bind(wx.EVT_BUTTON, self.OnSettingsDelete)
self.btnSettingsSave.SetToolTipString(_("Delete currently selected settings"))
- self.Bind(EVT_SETTINGS_SAVING, self.OnSettingsSaving)
# escaping with '$' character - index in self.esc_chars
self.e_char_i = 0
self.esc_chars = ['$', ';']
self._settings = self._loadSettings() # -> self.settingsChoice.SetItems()
- event = wxOnSettingsLoaded(settings = self._settings)
+ self.settingsLoaded.emit(settings=self._settings)
self.data_to_save = []
@@ -1053,50 +1047,44 @@
return
data = self._settings[name]
- event = wxOnSettingsChanged(data = data)
+ self.settingsChanged.emit(data=data)
def OnSettingsSave(self, event):
"""!Save settings"""
dlg = wx.TextEntryDialog(parent = self,
message = _("Name:"),
caption = _("Save settings"))
- if dlg.ShowModal() != wx.ID_OK:
- return
- # check required params
- if not dlg.GetValue():
- GMessage(parent = self,
- message = _("Name not given, settings is not saved."))
- return
- name = dlg.GetValue()
- event = wxOnSettingsSaving(name = name, dlg = dlg)
+ if dlg.ShowModal() == wx.ID_OK:
+ name = dlg.GetValue()
+ if not name:
+ GMessage(parent = self,
+ message = _("Name not given, settings is not saved."))
+ else:
+ self.settingsSaving.emit(name=name)
+ dlg.Destroy()
+ def SaveSettings(self, name):
# check if settings item already exists
- if event.name in self._settings:
+ if name in self._settings:
dlgOwt = wx.MessageDialog(self, message = _("Settings <%s> already exists. "
- "Do you want to overwrite the settings?") % event.name,
+ "Do you want to overwrite the settings?") % name,
caption = _("Save settings"), style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlgOwt.ShowModal() != wx.ID_YES:
dlgOwt.Destroy()
return
if self.data_to_save:
- self._settings[event.name] = self.data_to_save
+ self._settings[name] = self.data_to_save
- self.SaveSettings()
- self.settingsChoice.SetStringSelection(event.name)
+ self._saveSettings()
+ self.settingsChoice.SetStringSelection(name)
- event.dlg.Destroy()
- def SaveSettings(self):
- """!Save settings"""
- if self._saveSettings() == 0:
+ def _saveSettings(self):
+ """!Save settings and reload if successful"""
+ if self._writeSettings() == 0:
def SetDataToSave(self, data):
@@ -1112,7 +1100,7 @@
@param settings - dict with all settigs {nameofsetting : settingdata, ....}
self._settings = settings
def OnSettingsDelete(self, event):
"""!Save settings
@@ -1124,10 +1112,10 @@
return
self._settings.pop(name)
- def _saveSettings(self):
+ def _writeSettings(self):
"""!Save settings into the file
@return 0 on success
@@ -1192,8 +1180,7 @@
self.settingsChoice.SetItems(sorted(data.keys()))
fd.close()
- event = wxOnSettingsLoaded(settings = data)
+ self.settingsLoaded.emit(settings=data)
return data
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2013-03-14 19:40:54 UTC (rev 55382)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2013-03-14 19:45:32 UTC (rev 55383)
@@ -43,7 +43,7 @@
from core.gcmd import RunCommand, GError, GMessage, GException
from core.settings import UserSettings, GetDisplayVectSettings
from core.utils import SetAddOnPath, GetLayerNameFromCmd, command2ltype
-from gui_core.preferences import MapsetAccess, PreferencesDialog, EVT_SETTINGS_CHANGED
+from gui_core.preferences import MapsetAccess, PreferencesDialog
from lmgr.layertree import LayerTree, LMIcons
from lmgr.menudata import LayerManagerMenuData
from gui_core.widgets import GNotebook
@@ -419,8 +419,9 @@
else:
dlg.Destroy()
- """!Here can be functions which have to be called after EVT_SETTINGS_CHANGED.
+ def OnSettingsChanged(self):
+ """!Here can be functions which have to be called
+ after receiving settingsChanged signal.
Now only set copying of selected text to clipboard (in goutput).
### self._createMenuBar() # bug when menu is re-created on the fly
@@ -1388,7 +1389,7 @@
self.dialogs['preferences'] = dlg
self.dialogs['preferences'].CenterOnScreen()
- dlg.Bind(EVT_SETTINGS_CHANGED, self.OnSettingsChanged)
+ dlg.settingsChanged.connect(self.OnSettingsChanged)
self.dialogs['preferences'].ShowModal()
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py 2013-03-14 19:40:54 UTC (rev 55382)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py 2013-03-14 19:45:32 UTC (rev 55383)
@@ -37,8 +37,7 @@
from core.gconsole import CmdThread, GStderr, EVT_CMD_DONE, EVT_CMD_OUTPUT
from gui_core.gselect import Select
-from gui_core.widgets import ManageSettingsWidget,\
- EVT_SETTINGS_CHANGED, EVT_SETTINGS_SAVING, EVT_SETTINGS_LOADED
from web_services.widgets import WSPanel, EVT_CAP_PARSED
@@ -145,9 +144,9 @@
self.server.Bind(wx.EVT_TEXT, self.OnServer)
self.layerName.Bind(wx.EVT_TEXT, self.OnOutputLayerName)
- self.settsManager.Bind(EVT_SETTINGS_LOADED, self.OnSettingsLoaded)
+ self.settsManager.settingsLoaded.connect(self.OnSettingsLoaded)
self.Bind(EVT_CAP_PARSED, self.OnPanelCapParsed)
@@ -273,7 +272,7 @@
pane.SetSizer(adv_conn_sizer)
adv_conn_sizer.Fit(pane)
"""!Check if required data are filled before setting save is performed.
server = self.server.GetValue().strip()
@@ -285,12 +284,10 @@
self.settsManager.SetDataToSave((server,
self.username.GetValue(),
self.password.GetValue()))
- event.Skip()
"""!Update widgets according to chosen settings"""
- data = event.data
# data list: [server, username, password]
if len < 3:
return
@@ -305,10 +302,10 @@
else:
self.adv_conn.Collapse(True)
- def OnSettingsLoaded(self, event):
+ def OnSettingsLoaded(self, settings):
"""!If settings are empty set default servers
- if not event.settings:
+ if not settings:
self.settsManager.SetSettings(self.default_servers)
def OnClose(self, event):
