[GRASS-SVN] r55387 - grass/trunk/gui/wxpython/gui_core
Thu Mar 14 14:04:51 PDT 2013
Author: annakrat
Date: 2013-03-14 14:04:51 -0700 (Thu, 14 Mar 2013)
New Revision: 55387
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
wxGUI: continue replacing events (symbolSelectionChanged)
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2013-03-14 20:49:32 UTC (rev 55386)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2013-03-14 21:04:51 UTC (rev 55387)
@@ -40,7 +40,6 @@
 import wx
 import wx.lib.filebrowsebutton as filebrowse
 import wx.lib.mixins.listctrl as listmix
-from wx.lib.newevent import NewEvent
 from grass.script import core as grass
 from grass.script import task as gtask
@@ -51,7 +50,7 @@
 from core.gcmd        import GError, RunCommand, GMessage
 from gui_core.gselect import LocationSelect, MapsetSelect, Select, OgrTypeSelect, GdalSelect, MapsetSelect
 from gui_core.forms   import GUI
-from gui_core.widgets import SingleSymbolPanel, EVT_SYMBOL_SELECTION_CHANGED, GListCtrl, SimpleValidator
+from gui_core.widgets import SingleSymbolPanel, GListCtrl, SimpleValidator
 from core.utils       import GetLayerNameFromCmd, GetValidLayerName
 from core.settings    import UserSettings, GetDisplayVectSettings
 from core.debug       import Debug
@@ -2398,7 +2397,6 @@
         self.panels = self._createSymbolPanels(mainPanel)
         for panel in self.panels:
             vSizer.Add(panel, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
-            panel.Bind(EVT_SYMBOL_SELECTION_CHANGED, self.SelectionChanged)
         mainSizer.Add(vSizer, proportion = 1, flag = wx.ALL| wx.EXPAND, border = 5)
         self.btnCancel = wx.Button(parent = mainPanel, id = wx.ID_CANCEL)
@@ -2459,6 +2457,7 @@
             symbolPanels = []
             for img in images:
                 iP = SingleSymbolPanel(parent = panel, symbolPath = img)
+                iP.symbolSelectionChanged.connect(self.SelectionChanged)
                 sizer.Add(item = iP, proportion = 0, flag = wx.ALIGN_CENTER)
                 symbolPanels.append(iP)
@@ -2492,22 +2491,22 @@
             self.btnOK.Disable()
             self.infoLabel.SetLabel('')
-    def SelectionChanged(self, event):
+    def SelectionChanged(self, name, doubleClick):
         """!Selected symbol changed."""
-        if event.doubleClick:
+        if doubleClick:
             self.EndModal(wx.ID_OK)
         # deselect all
         for i in range(len(self.panels)):
             for panel in self.symbolPanels[i]:
-                if panel.GetName() != event.name:
+                if panel.GetName() != name:
                     panel.Deselect()
         self.btnOK.Enable()
-        self.selected = event.name
+        self.selected = name
         self.selectedDir = self.folderChoice.GetStringSelection()
-        self.infoLabel.SetLabel(event.name)
+        self.infoLabel.SetLabel(name)
     def GetSelectedSymbolName(self):
         """!Returns currently selected symbol name (e.g. 'basic/x').
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2013-03-14 20:49:32 UTC (rev 55386)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2013-03-14 21:04:51 UTC (rev 55387)
@@ -56,7 +56,6 @@
-wxSymbolSelectionChanged, EVT_SYMBOL_SELECTION_CHANGED  = NewEvent()
 class NotebookController:
@@ -731,9 +730,15 @@
     def __init__(self, parent, symbolPath):
         """!Panel constructor
+        Signal symbolSelectionChanged - symbol selected
+                                      - attribute 'name' (symbol name)
+                                      - attribute 'doubleClick' (underlying cause)
         @param parent parent (gui_core::dialog::SymbolDialog)
         @param symbolPath absolute path to symbol
+        self.symbolSelectionChanged = Signal('SingleSymbolPanel.symbolSelectionChanged')
         wx.Panel.__init__(self, parent, id = wx.ID_ANY, style = wx.BORDER_RAISED)
         self.SetName(os.path.splitext(os.path.basename(symbolPath))[0])
         self.sBmp = wx.StaticBitmap(self, wx.ID_ANY, wx.Bitmap(symbolPath))
@@ -760,12 +765,10 @@
         self.SetBackgroundColour(self.selectColor)
         event.Skip()
-        event = wxSymbolSelectionChanged(name = self.GetName(), doubleClick = False)
-        wx.PostEvent(self.GetParent(), event)
+        self.symbolSelectionChanged.emit(name=self.GetName(), doubleClick=False)
     def OnDoubleClick(self, event):
-        event = wxSymbolSelectionChanged(name = self.GetName(), doubleClick = True)
+        self.symbolSelectionChanged.emit(name=self.GetName(), doubleClick=True)
     def Deselect(self):
         """!Panel deselected, background changes back to default"""
