[GRASS-SVN] r55391 - grass/trunk
svn_grass at osgeo.org
Fri Mar 15 03:23:40 PDT 2013
Author: neteler
Date: 2013-03-15 03:23:40 -0700 (Fri, 15 Mar 2013)
New Revision: 55391
grass/trunk/config.guess
grass/trunk/config.sub
config.guess: updated
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess 2013-03-14 22:59:48 UTC (rev 55390)
+++ grass/trunk/config.guess 2013-03-15 10:23:40 UTC (rev 55391)
@@ -1,14 +1,12 @@
#! /bin/sh
# Attempt to guess a canonical system name.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
-# 2011, 2012 Free Software Foundation, Inc.
+# Copyright 1992-2013 Free Software Foundation, Inc.
-timestamp='2012-09-25'
+timestamp='2013-02-12'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
+# the Free Software Foundation; either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful, but
@@ -22,20 +20,18 @@
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Originally written by Per Bothner. Please send patches (context
-# diff format) to <config-patches at gnu.org> and include a ChangeLog
-# entry.
+# the same distribution terms that you use for the rest of that
+# program. This Exception is an additional permission under section 7
+# of the GNU General Public License, version 3 ("GPLv3").
-# This script attempts to guess a canonical system name similar to
-# config.sub. If it succeeds, it prints the system name on stdout, and
-# exits with 0. Otherwise, it exits with 1.
+# Originally written by Per Bothner.
# You can get the latest version of this script from:
# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
+# Please send patches with a ChangeLog entry to config-patches at gnu.org.
me=`echo "$0" | sed -e 's,.*/,,'`
usage="\
@@ -54,9 +50,7 @@
GNU config.guess ($timestamp)
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
-2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
-Free Software Foundation, Inc.
+Copyright 1992-2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -959,6 +953,9 @@
eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
+ or1k:Linux:*:*)
+ echo ${UNAME_MACHINE}-unknown-linux-gnu
+ exit ;;
or32:Linux:*:*)
exit ;;
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub 2013-03-14 22:59:48 UTC (rev 55390)
+++ grass/trunk/config.sub 2013-03-15 10:23:40 UTC (rev 55391)
@@ -1,24 +1,18 @@
#! /bin/sh
# Configuration validation subroutine script.
-timestamp='2012-10-10'
-# This file is (in principle) common to ALL GNU software.
-# The presence of a machine in this file suggests that SOME GNU software
-# can handle that machine. It does not imply ALL GNU software can.
-# This file is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
+# This file is free software; you can redistribute it and/or modify it
+# under the terms of the GNU General Public License as published by
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+# General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, see <http://www.gnu.org/licenses/>.
@@ -26,11 +20,12 @@
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted GNU ChangeLog entry.
# Configuration subroutine to validate and canonicalize a configuration type.
# Supply the specified configuration type as an argument.
@@ -73,9 +68,7 @@
version="\
GNU config.sub ($timestamp)
@@ -293,16 +286,17 @@
| mipsisa64r2 | mipsisa64r2el \
| mipsisa64sb1 | mipsisa64sb1el \
| mipsisa64sr71k | mipsisa64sr71kel \
+ | mipsr5900 | mipsr5900el \
| mipstx39 | mipstx39el \
| mn10200 | mn10300 \
| moxie \
| mt \
| msp430 \
| nds32 | nds32le | nds32be \
- | nios | nios2 \
+ | nios | nios2 | nios2eb | nios2el \
| ns16k | ns32k \
| open8 \
- | or32 \
+ | or1k | or32 \
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle \
| pyramid \
@@ -410,12 +404,13 @@
| mipsisa64r2-* | mipsisa64r2el-* \
| mipsisa64sb1-* | mipsisa64sb1el-* \
| mipsisa64sr71k-* | mipsisa64sr71kel-* \
+ | mipsr5900-* | mipsr5900el-* \
| mipstx39-* | mipstx39el-* \
| mmix-* \
| mt-* \
| msp430-* \
| nds32-* | nds32le-* | nds32be-* \
- | nios-* | nios2-* \
+ | nios-* | nios2-* | nios2eb-* | nios2el-* \
| none-* | np1-* | ns16k-* | ns32k-* \
| open8-* \
| orion-* \
@@ -1026,7 +1021,11 @@
basic_machine=i586-unknown
os=-pw32
- rdos)
+ rdos | rdos64)
+ basic_machine=x86_64-pc
+ os=-rdos
+ rdos32)
basic_machine=i386-pc
os=-rdos
@@ -1353,7 +1352,7 @@
-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
| -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
| -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
- | -sym* | -kopensolaris* \
+ | -sym* | -kopensolaris* | -plan9* \
| -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
| -aos* | -aros* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
@@ -1499,9 +1498,6 @@
-aros*)
os=-aros
- -kaos*)
- os=-kaos
-zvmoe)
os=-zvmoe
@@ -1593,6 +1589,9 @@
mips*-*)
os=-elf
+ or1k-*)
+ os=-elf
or32-*)
os=-coff
