[GRASS-SVN] r55396 - in grass/trunk/gui/wxpython: gmodeler gui_core
Fri Mar 15 12:13:57 PDT 2013
Author: annakrat
Date: 2013-03-15 12:13:56 -0700 (Fri, 15 Mar 2013)
New Revision: 55396
   grass/trunk/gui/wxpython/gmodeler/dialogs.py
   grass/trunk/gui/wxpython/gui_core/goutput.py
   grass/trunk/gui/wxpython/gui_core/prompt.py
wxGUI: continue replacing events (promptRunCmd)
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py	2013-03-15 17:53:35 UTC (rev 55395)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py	2013-03-15 19:13:56 UTC (rev 55396)
@@ -35,7 +35,7 @@
 from gui_core.widgets     import SearchModuleWidget, SimpleValidator
 from core.gcmd            import GError, EncodeString
 from gui_core.dialogs     import SimpleDialog, MapLayersDialogForModeler
-from gui_core.prompt      import GPromptSTC, EVT_GPROMPT_RUN_CMD
+from gui_core.prompt      import GPromptSTC
 from gui_core.forms       import CmdPanel
 from gui_core.gselect     import Select, ElementSelect
 from gmodeler.model       import *
@@ -161,7 +161,7 @@
         modulesData = ModulesData()
         self.cmd_prompt = GPromptSTC(parent = self, modulesData = modulesData, updateCmdHistory = False)
-        self.cmd_prompt.Bind(EVT_GPROMPT_RUN_CMD, self.OnCommand)
+        self.cmd_prompt.promptRunCmd.connect(self.OnCommand)
         self.search = SearchModuleWidget(parent = self.panel,
                                          showTip = True)
@@ -239,10 +239,10 @@
             return False
         return True
-    def OnCommand(self, event):
+    def OnCommand(self, cmd):
         """!Command in prompt confirmed"""
-        if self.ValidateCmd(event.cmd):
-            self._command = event.cmd
+        if self.ValidateCmd(cmd):
+            self._command = cmd
             self.EndModal(wx.ID_OK)
     def OnOk(self, event):
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py	2013-03-15 17:53:35 UTC (rev 55395)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py	2013-03-15 19:13:56 UTC (rev 55396)
@@ -35,7 +35,7 @@
 from core.gconsole   import GConsole, \
     EVT_CMD_OUTPUT, EVT_CMD_PROGRESS, EVT_CMD_RUN, EVT_CMD_DONE, \
     EVT_WRITE_LOG, EVT_WRITE_CMD_LOG, EVT_WRITE_WARNING, EVT_WRITE_ERROR
 from core.settings   import UserSettings
 from core.modulesdata import ModulesData
@@ -122,9 +122,8 @@
         # move to the if below
         # search depends on cmd prompt
         self.cmdPrompt = GPromptSTC(parent = self, modulesData = modulesData)
-        self.cmdPrompt.Bind(EVT_GPROMPT_RUN_CMD,
-                            lambda event:
-                                self._gconsole.RunCmd(command = event.cmd))
+        self.cmdPrompt.promptRunCmd.connect(lambda cmd:
+                                            self._gconsole.RunCmd(command=cmd))
         self.cmdPrompt.showNotification.connect(self.showNotification)
         if not self._gcstyle & GC_PROMPT:
Modified: grass/trunk/gui/wxpython/gui_core/prompt.py
--- grass/trunk/gui/wxpython/gui_core/prompt.py	2013-03-15 17:53:35 UTC (rev 55395)
+++ grass/trunk/gui/wxpython/gui_core/prompt.py	2013-03-15 19:13:56 UTC (rev 55396)
@@ -24,8 +24,6 @@
 import wx
 import wx.stc
-from wx.lib.newevent import NewEvent
 from grass.script import core as grass
 from grass.script import task as gtask
@@ -35,10 +33,12 @@
 from core          import utils
 from core.gcmd     import EncodeString, DecodeString, GetRealCmd
-gPromptRunCmd, EVT_GPROMPT_RUN_CMD = NewEvent()
 class GPrompt(object):
     """!Abstract class for interactive wxGUI prompt
+    Signal promptRunCmd - emitted to run command from prompt
+                        - attribute 'cmd'
     See subclass GPromptPopUp and GPromptSTC.
@@ -46,6 +46,8 @@
         self.parent = parent                 # GConsole
         self.panel  = self.parent.GetPanel()
+        self.promptRunCmd = Signal('GPrompt.promptRunCmd')
         # probably only subclasses need this
         self.modulesData = modulesData
@@ -112,7 +114,7 @@
             cmd = utils.split(EncodeString((cmdString)))
         cmd = map(DecodeString, cmd)
-        wx.PostEvent(self, gPromptRunCmd(cmd = cmd))
+        self.promptRunCmd.emit(cmd=cmd)
         # add command to history & clean prompt
         self.UpdateCmdHistory(cmd)
