[GRASS-SVN] r55401 - in grass/trunk: include/defs lib/vector/Vlib lib/vector/diglib
svn_grass at osgeo.org
Sat Mar 16 07:40:42 PDT 2013
Author: martinl
Date: 2013-03-16 07:40:42 -0700 (Sat, 16 Mar 2013)
New Revision: 55401
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/cindex.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/field.c
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/init_head.c
grass/trunk/lib/vector/Vlib/local_proto.h
grass/trunk/lib/vector/Vlib/map.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_nat.c
grass/trunk/lib/vector/diglib/head.c
vlib: Vect_open_tmp_new() implemented
basic support for temporary vector maps (work in progress)
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/include/defs/vector.h 2013-03-16 14:40:42 UTC (rev 55401)
@@ -223,6 +223,7 @@
int Vect_open_old_head(struct Map_info *, const char *, const char *);
int Vect_open_old_head2(struct Map_info *, const char *, const char *, const char *);
int Vect_open_new(struct Map_info *, const char *, int);
+int Vect_open_tmp_new(struct Map_info *, const char *, int);
int Vect_open_update(struct Map_info *, const char *, const char *);
int Vect_open_update2(struct Map_info *, const char *, const char *, const char *);
int Vect_open_update_head(struct Map_info *, const char *, const char *);
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/build.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -23,6 +23,8 @@
#include <grass/vector.h>
#include <grass/glocale.h>
+#include "local_proto.h"
#define SEP "-----------------------------------\n"
#if !defined HAVE_OGR || !defined HAVE_POSTGRES
@@ -987,17 +989,18 @@
int Vect_save_topo(struct Map_info *Map)
struct Plus_head *plus;
- char buf[GPATH_MAX];
+ char *path;
struct gvfile fp;
G_debug(1, "Vect_save_topo()");
+ /* write out all the accumulated info to the plus file */
plus = &(Map->plus);
+ dig_file_init(&fp);
- /* write out all the accumulated info to the plus file */
- sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
- dig_file_init(&fp);
- fp.file = G_fopen_new(buf, GV_TOPO_ELEMENT);
+ path = Vect__get_path(Map);
+ fp.file = G_fopen_new(path, GV_TOPO_ELEMENT);
+ G_free(path);
if (fp.file == NULL) {
G_warning(_("Unable to create topo file for vector map <%s>"), Map->name);
return 0;
@@ -1224,7 +1227,7 @@
int Vect_save_sidx(struct Map_info *Map)
- char fname[GPATH_MAX], buf[GPATH_MAX];
+ char *file_path;
G_debug(1, "Vect_save_spatial_index()");
@@ -1238,14 +1241,14 @@
/* new or update mode ? */
if (plus->Spidx_new == TRUE) {
/* write out rtrees to sidx file */
- G_file_name(fname, buf, GV_SIDX_ELEMENT, Map->mapset);
- G_debug(1, "Open sidx: %s", fname);
+ file_path = Vect__get_element_path(Map, GV_SIDX_ELEMENT);
+ G_debug(1, "Open sidx: %s", file_path);
dig_file_init(&(plus->spidx_fp));
- plus->spidx_fp.file = fopen(fname, "w+");
+ plus->spidx_fp.file = fopen(file_path, "w+");
+ G_free(file_path);
if (plus->spidx_fp.file == NULL) {
- G_warning(_("Unable open spatial index file for write <%s>"),
- fname);
+ G_warning(_("Unable to create spatial index file for vector map <%s>"),
+ Vect_get_name(Map));
return 0;
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -21,6 +21,8 @@
static int cmp_cat(const void *pa, const void *pb);
static void check_status(const struct Map_info *Map)
@@ -443,21 +445,22 @@
int Vect_cidx_save(struct Map_info *Map)
- char fname[1024], buf[1024];
+ char *path;
struct gvfile fp;
G_debug(2, "Vect_cidx_save()");
check_status(Map);
- G_file_name(fname, buf, GV_CIDX_ELEMENT, Map->mapset);
- G_debug(2, "Open cidx: %s", fname);
dig_file_init(&fp);
- fp.file = fopen(fname, "w");
+ fp.file = G_fopen_new(path, GV_CIDX_ELEMENT);
+ G_free(path);
- G_warning(_("Unable to open cidx file <%s> for write"), fname);
+ G_warning(_("Unable to create category index file for vector map <%s>"),
return 1;
@@ -465,7 +468,7 @@
dig_init_portable(&(plus->cidx_port), dig__byte_order_out());
if (0 > dig_write_cidx(&fp, plus)) {
- G_warning(_("Error writing out category index file <%s>"), fname);
+ G_warning(_("Error writing out category index file"));
return 1;
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/close.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -24,6 +24,8 @@
static int clo_dummy()
return -1;
@@ -75,8 +77,8 @@
int create_link; /* used for external formats only */
struct Coor_info CInfo;
- G_debug(1, "Vect_close(): name = %s, mapset = %s, format = %d, level = %d",
- Map->name, Map->mapset, Map->format, Map->level);
+ G_debug(1, "Vect_close(): name = %s, mapset = %s, format = %d, level = %d, is_tmp = %d",
+ Map->name, Map->mapset, Map->format, Map->level, Map->temporary);
/* check for external formats whether to create a link */
create_link = TRUE;
@@ -190,6 +192,10 @@
+ if (Map->temporary) {
+ Vect__delete(Map->name, TRUE);
G_free(Map->name);
G_free(Map->mapset);
G_free(Map->location);
@@ -257,13 +263,14 @@
void unlink_file(const struct Map_info *Map, const char *name)
- char file_path[GPATH_MAX];
+ char *path;
/* delete old support files if available */
+ path = Vect__get_element_path(Map, name);
+ if (access(path, F_OK) == 0) { /* file exists? */
+ G_debug(2, "\t%s: unlink", path);
+ unlink(path);
- G_file_name(file_path, buf, name, G_mapset());
- if (access(file_path, F_OK) == 0) /* file exists? */
- unlink(file_path);
+ G_free(path);
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/field.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -27,6 +27,8 @@
#include <grass/dbmi.h>
#ifdef HAVE_GDAL
#include <gdal_version.h> /* needed for FID detection */
#endif /* HAVE_GDAL */
@@ -558,7 +560,7 @@
char file[1024], buf[2001];
char tab[1024], col[1024], db[1024], drv[1024], fldstr[1024], *fldname;
int fld;
- char *c;
+ char *c, *path;
int row, rule;
struct dblinks *dbl;
char **tokens;
@@ -567,15 +569,12 @@
dbl = Map->dblnk;
/* Read dblink for native format */
- sprintf(file, "%s/%s/%s/%s/%s/%s", Map->gisdbase, Map->location,
- Map->mapset, GV_DIRECTORY, Map->name,
- GV_DBLN_ELEMENT);
- G_debug(1, "dbln file: %s", file);
- fd = fopen(file, "r");
+ fd = G_fopen_old(path, GV_DBLN_ELEMENT, Map->mapset);
+ G_free(path);
if (fd == NULL) { /* This may be correct, no tables defined */
G_debug(1, "Cannot open vector database definition file");
- return (-1);
+ return -1;
row = 0;
@@ -889,7 +888,7 @@
int i;
FILE *fd;
- char file[GPATH_MAX], buf[GPATH_MAX];
+ char *path, buf[1024];
if (Map->format != GV_FORMAT_NATIVE)
@@ -901,16 +900,13 @@
dbl = Map->dblnk;
- GV_DBLN_ELEMENT);
- fd = fopen(file, "w");
+ fd = G_fopen_new(path, GV_DBLN_ELEMENT);
+ G_free(path);
- G_warning(_("Unable to open vector database definition file '%s'"),
- file);
- return (-1);
+ G_warning(_("Unable to create database definition file for vector map <%s>"),
+ return -1;
for (i = 0; i < dbl->n_fields; i++) {
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/header.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -20,7 +20,7 @@
-static int lookup(const char *file, const char *key, char *value, size_t len);
\brief Print vector map header to stdout
@@ -77,12 +77,12 @@
int Vect__write_head(const struct Map_info *Map)
+ char *path;
FILE *head_fp;
- head_fp = G_fopen_new(buf, GV_HEAD_ELEMENT);
+ head_fp = G_fopen_new(path, GV_HEAD_ELEMENT);
+ G_free(path);
if (head_fp == NULL) {
G_warning(_("Unable to create header file for vector map <%s>"),
Vect_get_full_name(Map));
@@ -117,23 +117,16 @@
int Vect__read_head(struct Map_info *Map)
FILE *head_fp;
- char buff[GPATH_MAX];
- char *ptr;
+ char buff[2000];
+ char *path, *ptr;
/* Reset / init */
- Vect_set_organization(Map, "");
- Vect_set_date(Map, "");
- Vect_set_person(Map, "");
- Vect_set_map_name(Map, "");
- Vect_set_map_date(Map, "");
- Vect_set_scale(Map, 1);
- Vect_set_comment(Map, "");
- Vect_set_zone(Map, -1);
- Vect_set_thresh(Map, 0.);
+ Vect__init_head(Map);
G_debug(1, "Vect__read_head(): vector = %s@%s", Map->name, Map->mapset);
- sprintf(buff, "%s/%s", GV_DIRECTORY, Map->name);
- head_fp = G_fopen_old(buff, GV_HEAD_ELEMENT, Map->mapset);
+ head_fp = G_fopen_old(path, GV_HEAD_ELEMENT, Map->mapset);
+ G_free(path);
G_warning(_("Unable to open header file of vector <%s>"),
@@ -589,6 +582,5 @@
double Vect_get_thresh(const struct Map_info *Map)
- G_debug(1, "Vect_get_thresh(): thresh = %f", Map->head.digit_thresh);
return Map->head.digit_thresh;
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/init_head.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -30,30 +30,26 @@
char buf[64];
+ G_zero(&(Map->head), sizeof(struct dig_head *));
/* organization */
- Map->head.organization = NULL;
/* date */
- Map->head.date = NULL;
/* user name */
- Map->head.user_name = NULL;
sprintf(buf, "%s", G_whoami());
Vect_set_person(Map, buf);
/* map name */
- Map->head.map_name = NULL;
/* source date */
- Map->head.source_date = NULL;
sprintf(buf, "%s", G_date());
Vect_set_map_date(Map, buf);
/* comments */
- Map->head.comment = NULL;
/* scale, threshold */
Modified: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/local_proto.h 2013-03-16 14:40:42 UTC (rev 55401)
@@ -7,4 +7,13 @@
const struct line_pnts *, const struct line_cats *,
int (*external_routine) (const struct Map_info *, int));
+/* map.c */
+int Vect__delete(const char *, int);
+/* open.c */
+int Vect__open_old(struct Map_info *, const char *, const char *,
+ const char *, int, int, int);
+char *Vect__get_path(const struct Map_info *);
+char *Vect__get_element_path(const struct Map_info *, const char *);
#endif /* PG_LOCAL_PROTO_H__ */
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/map.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -28,6 +28,8 @@
\brief Copy file
@@ -371,19 +373,38 @@
int Vect_delete(const char *map)
- int i, n, ret;
+ return Vect__delete(map, FALSE);
+ \brief Delete vector map (internal use only)
+ \param map name of vector map to be delete
+ \param is_tmp TRUE for temporary maps
+ \return -1 error
+ \return 0 success
+int Vect__delete(const char *map, int is_tmp)
+ int ret;
+ char *path, path_buf[GPATH_MAX];
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+ const char *tmp, *mapset;
struct Map_info Map;
- struct field_info *Fi;
DIR *dir;
struct dirent *ent;
- const char *tmp;
- char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- G_debug(3, "Delete vector '%s'", map);
+ G_debug(3, "Delete vector '%s' (is_tmp = %d)", map, is_tmp);
+ mapset = G_mapset();
/* remove mapset from fully qualified name */
if (G_name_is_fully_qualified(map, xname, xmapset)) {
+ if (strcmp(mapset, xmapset) != 0)
+ G_warning(_("Ignoring invalid mapset: %s"), xmapset);
map = xname;
@@ -392,24 +413,27 @@
return -1;
- sprintf(buf, "%s/%s/%s/%s/%s/%s", G_gisdbase(), G_location(),
- G_mapset(), GV_DIRECTORY, map, GV_DBLN_ELEMENT);
- G_debug(1, "dbln file: %s", buf);
- if (access(buf, F_OK) == 0) {
- /* Open input */
- Vect_set_open_level(1); /* Topo not needed */
- ret = Vect_open_old_head(&Map, map, G_mapset());
- if (ret < 1) {
+ Vect_set_open_level(1); /* Topo not needed */
+ ret = Vect__open_old(&Map, map, mapset, NULL, FALSE, TRUE, is_tmp);
+ if (ret < 1) {
+ if (is_tmp)
+ return 0; /* temporary vector map doesn't exist */
+ else {
G_warning(_("Unable to open header file for vector map <%s>"),
map);
return -1;
+ path = Vect__get_element_path(&Map, GV_DBLN_ELEMENT);
+ G_debug(1, "dbln file: %s", path);
+ int i, n;
+ struct field_info *Fi;
/* Delete all tables, NOT external (OGR) */
if (Map.format == GV_FORMAT_NATIVE) {
n = Vect_get_num_dblinks(&Map);
for (i = 0; i < n; i++) {
Fi = Vect_get_dblink(&Map, i);
@@ -446,15 +470,15 @@
- Vect_close(&Map);
+ G_free(path);
/* Delete all files from vector/name directory */
- sprintf(buf, "%s/%s/vector/%s", G_location_path(), G_mapset(), map);
- G_debug(3, "opendir '%s'", buf);
- dir = opendir(buf);
+ path = Vect__get_element_path(&Map, NULL);
+ G_debug(3, "opendir '%s'", path);
+ dir = opendir(path);
if (dir == NULL) {
- G_warning(_("Unable to open directory '%s'"), buf);
+ G_warning(_("Unable to open directory '%s'"), path);
return -1;
@@ -463,29 +487,28 @@
if ((strcmp(ent->d_name, ".") == 0) ||
(strcmp(ent->d_name, "..") == 0))
continue;
- sprintf(buf, "%s/%s/vector/%s/%s", G_location_path(), G_mapset(), map,
- ent->d_name);
- G_debug(3, "delete file '%s'", buf);
- ret = unlink(buf);
+ sprintf(path_buf, "%s/%s", path, ent->d_name);
+ G_debug(3, "delete file '%s'", path_buf);
+ ret = unlink(path_buf);
if (ret == -1) {
- G_warning(_("Unable to delete file '%s'"), buf);
+ G_warning(_("Unable to delete file '%s'"), path_buf);
closedir(dir);
return -1;
closedir(dir);
+ G_free(path);
/* NFS can create .nfsxxxxxxxx files for those deleted
* -> we have to move the directory to ./tmp before it is deleted */
tmp = G_tempfile();
- G_debug(3, "rename '%s' to '%s'", buf, tmp);
- ret = rename(buf, tmp);
+ G_debug(3, "rename '%s' to '%s'", path, tmp);
+ ret = rename(path, tmp);
if (ret == -1) {
- G_warning(_("Unable to rename directory '%s' to '%s'"), buf, tmp);
+ G_warning(_("Unable to rename directory '%s' to '%s'"), path, tmp);
return -1;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/open.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -6,7 +6,7 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009, 2012 by the GRASS Development Team
+ (C) 2001-2009, 2012-2013 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -26,6 +26,8 @@
#ifdef HAVE_POSTGRES
#include "pg_local_proto.h"
#endif
@@ -107,8 +109,7 @@
#endif
-static int open_old(struct Map_info *, const char *, const char *,
- const char *, int, int);
+static int open_new(struct Map_info *, const char *, int, int);
static int map_format(struct Map_info *);
@@ -153,23 +154,25 @@
\param update non-zero to open for update otherwise read-only mode
\param head_only read only header info from 'head', 'dbln', 'topo',
'cidx' is not opened. The header may be opened on level 2 only.
\return level of openness (1, 2)
\return -1 in error
-int open_old(struct Map_info *Map, const char *name, const char *mapset,
- const char *layer, int update, int head_only)
+int Vect__open_old(struct Map_info *Map, const char *name, const char *mapset,
+ const char *layer, int update, int head_only, int is_tmp)
- char buf[GNAME_MAX + 10], buf2[GMAPSET_MAX + 10], xname[GNAME_MAX],
- xmapset[GMAPSET_MAX];
+ char *path;
FILE *fp;
int level, level_request;
int format, ret;
int ogr_mapset;
const char *fmapset;
- G_debug(1, "Vect__open_old(): name='%s' mapset='%s' layer='%s' update=%d",
- name, mapset, layer, update);
+ G_debug(1, "Vect__open_old(): name = %s, mapset = %s, layer = %s, update = %d, "
+ "head_only = %d, is_tmp = %d", name, mapset, layer ? layer : "", update, head_only,
+ is_tmp);
/* zero Map_info structure */
G_zero(Map, sizeof(struct Map_info));
@@ -199,37 +202,48 @@
Map->fInfo.ogr.layer_name = G_store(layer); /* no layer to be open */
- else {
- sprintf(buf, "%s/%s", GV_DIRECTORY, xname);
- sprintf(buf2, "%s@%s", GV_COOR_ELEMENT, xmapset);
Map->name = G_store(xname);
Map->mapset = G_store(xmapset);
else {
- sprintf(buf, "%s/%s", GV_DIRECTORY, name);
- sprintf(buf2, "%s", GV_COOR_ELEMENT);
Map->name = G_store(name);
+ Map->temporary = is_tmp;
+ /* temporary maps can be accessed only in the current mapset */
if (mapset)
Map->mapset = G_store(mapset);
else
Map->mapset = G_store("");
if (!ogr_mapset) {
/* try to find vector map (not for OGR mapset) */
- fmapset = G_find_vector2(Map->name, Map->mapset);
- if (fmapset == NULL) {
- if (mapset && strcmp(mapset, G_mapset()) == 0)
- G_fatal_error(_("Vector map <%s> not found in current mapset"),
+ if (!Map->temporary) {
+ fmapset = G_find_vector2(Map->name, Map->mapset);
+ if (fmapset == NULL) {
+ if (mapset && strcmp(mapset, G_mapset()) == 0)
+ G_warning(_("Vector map <%s> not found in current mapset"),
- else
- G_fatal_error(_("Vector map <%s> not found"),
+ else
+ G_warning(_("Vector map <%s> not found"),
- return -1;
+ return -1;
+ Map->mapset = G_store(fmapset);
- Map->mapset = G_store(fmapset);
+ else {
+ char file_path[GPATH_MAX];
+ if (strcmp(Map->mapset, G_mapset()) != 0) {
+ G_warning(_("Temporary vector maps can be accessed only in the current mapset"));
+ return -1;
+ G_file_name(file_path, path, GV_HEAD_ELEMENT, Map->mapset);
+ if (access(file_path, F_OK) != 0)
+ return -1;
Map->location = G_store(G_location());
@@ -240,8 +254,8 @@
return -1;
- G_debug(1, "Map name: %s", Map->name);
- G_debug(1, "Map mapset: %s", Map->mapset);
+ G_debug(1, "Map: name = %s, mapset = %s, temporary = %d", Map->name, Map->mapset,
+ Map->temporary);
/* read vector format information */
if (ogr_mapset) {
@@ -249,10 +263,7 @@
else {
format = 0;
- G_debug(1, "open format file: '%s/%s/%s'", Map->mapset, buf,
- GV_FRMT_ELEMENT);
- fp = G_fopen_old(buf, GV_FRMT_ELEMENT, Map->mapset);
+ fp = G_fopen_old(path, GV_FRMT_ELEMENT, Map->mapset);
if (fp == NULL) {
G_debug(1, "Vector format: %d (native)", format);
format = GV_FORMAT_NATIVE;
@@ -451,7 +462,7 @@
Map->head_only = FALSE;
- G_debug(1, "Vect_open_old(): vector opened on level %d", level);
+ G_debug(1, "Vect__open_old(): vector opened on level %d", level);
if (level == 1) { /* without topology */
Map->plus.built = GV_BUILD_NONE;
@@ -467,9 +478,8 @@
Vect_read_dblinks(Map);
/* open history file */
if (update && !ogr_mapset) { /* native only */
- Map->hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
+ Map->hist_fp = G_fopen_modify(path, GV_HIST_ELEMENT);
if (Map->hist_fp == NULL) {
G_warning(_("Unable to open history file for vector map <%s>"),
@@ -483,7 +493,7 @@
else {
if (Map->format == GV_FORMAT_NATIVE || Map->format == GV_FORMAT_OGR ||
Map->format == GV_FORMAT_POSTGIS) {
- Map->hist_fp = G_fopen_old(buf, GV_HIST_ELEMENT, Map->mapset);
+ Map->hist_fp = G_fopen_old(path, GV_HIST_ELEMENT, Map->mapset);
/* If NULL (does not exist) then Vect_hist_read() handle that */
else {
@@ -499,27 +509,26 @@
if (update && !head_only) {
- G_file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
+ G_file_name(file_path, path, GV_TOPO_ELEMENT, G_mapset());
if (access(file_path, F_OK) == 0) /* topo file exists? */
unlink(file_path);
- G_file_name(file_path, buf, GV_SIDX_ELEMENT, G_mapset());
+ G_file_name(file_path, path, GV_SIDX_ELEMENT, G_mapset());
if (access(file_path, F_OK) == 0) /* sidx file exists? */
unlink(file_path);
- G_file_name(file_path, buf, GV_CIDX_ELEMENT, G_mapset());
+ G_file_name(file_path, path, GV_CIDX_ELEMENT, G_mapset());
if (access(file_path, F_OK) == 0) /* cidx file exists? */
unlink(file_path);
if (format == GV_FORMAT_OGR || format == GV_FORMAT_POSTGIS) {
- G_file_name(file_path, buf, GV_FIDX_ELEMENT, G_mapset());
+ G_file_name(file_path, path, GV_FIDX_ELEMENT, G_mapset());
if (access(file_path, F_OK) == 0) /* fidx file exists? */
unlink(file_path);
+ G_free(path);
return level;
@@ -541,7 +550,7 @@
int Vect_open_old(struct Map_info *Map, const char *name, const char *mapset)
- return open_old(Map, name, mapset, NULL, 0, 0);
+ return Vect__open_old(Map, name, mapset, NULL, FALSE, FALSE, FALSE);
@@ -561,7 +570,7 @@
int Vect_open_old2(struct Map_info *Map, const char *name, const char *mapset,
const char *layer)
- return open_old(Map, name, mapset, layer, 0, 0);
+ return Vect__open_old(Map, name, mapset, layer, FALSE, FALSE, FALSE);
@@ -585,7 +594,7 @@
int Vect_open_update(struct Map_info *Map, const char *name, const char *mapset)
- return open_old(Map, name, mapset, NULL, 1, 0);
+ return Vect__open_old(Map, name, mapset, NULL, TRUE, FALSE, FALSE);
@@ -607,7 +616,7 @@
int Vect_open_update2(struct Map_info *Map, const char *name, const char *mapset, const char *layer)
- return open_old(Map, name, mapset, layer, 1, 0);
+ return Vect__open_old(Map, name, mapset, layer, TRUE, FALSE, FALSE);
@@ -630,7 +639,7 @@
int Vect_open_old_head(struct Map_info *Map, const char *name, const char *mapset)
- return open_old(Map, name, mapset, NULL, 0, 1);
+ return Vect__open_old(Map, name, mapset, NULL, FALSE, TRUE, FALSE);
@@ -657,7 +666,7 @@
int Vect_open_old_head2(struct Map_info *Map, const char *name, const char *mapset,
const char *layer)
- return open_old(Map, name, mapset, layer, 0, 1);
+ return Vect__open_old(Map, name, mapset, layer, FALSE, TRUE, FALSE);
/*! \brief Open header file of existing vector map for updating
@@ -674,34 +683,16 @@
int Vect_open_update_head(struct Map_info *Map, const char *name,
const char *mapset)
- return open_old(Map, name, mapset, NULL, 1, 1);
+ return Vect__open_old(Map, name, mapset, NULL, TRUE, TRUE, FALSE);
- \brief Create new vector map for reading/writing
- By default list of updated features is not maintained, see
- Vect_set_updated() for details.
- By default map format is native (GV_FORMAT_NATIVE). If OGR file is
- found in the current mapset then the map (ie. OGR layer) is created
- in given OGR datasource (GV_FORMAT_OGR). Similarly if PG file exists
- then the map (ie. PostGIS table) is created using PostGIS interface
- (GV_FORMAT_POSTGIS). The format of map is stored in Map->format.
- \param[out] Map pointer to Map_info structure
- \param name name of vector map to be created
- \param with_z WITH_Z for 3D vector data otherwise WITHOUT_Z
- \return 1 on success
- \return -1 on error
-int Vect_open_new(struct Map_info *Map, const char *name, int with_z)
+int open_new(struct Map_info *Map, const char *name, int with_z, int is_tmp)
int ret;
- char xname[GNAME_MAX], xmapset[GMAPSET_MAX], buf[GPATH_MAX];
- G_debug(2, "Vect_open_new(): name = %s with_z = %d", name, with_z);
+ G_debug(1, "Vect_open_new(): name = %s with_z = %d is_tmp = %d",
+ name, with_z, is_tmp);
@@ -712,8 +703,8 @@
/* check for fully-qualified map name */
if (G_name_is_fully_qualified(name, xname, xmapset)) {
if (strcmp(xmapset, G_mapset()) != 0) {
- G_fatal_error(_("<%s> is not the current mapset (%s)"), name,
- G_mapset());
+ G_warning(_("Unable to create new vector map: <%s> is not the current mapset (%s)"),
+ name, G_mapset());
return -1;
name = xname;
@@ -721,15 +712,17 @@
/* check for [A-Za-z][A-Za-z0-9_]* in name */
if (Vect_legal_filename(name) < 0) {
- G_fatal_error(_("Vector map name is not SQL compliant"));
+ G_warning(_("Unable to create vector map <%s>: name is not SQL compliant"),
+ name);
return -1;
- /* store basic info (map at mapset) */
- Map->name = G_store(name);
- Map->mapset = G_store(G_mapset());
- Map->location = G_store(G_location());
- Map->gisdbase = G_store(G_gisdbase());
+ /* store basic info */
+ Map->name = G_store(name);
+ Map->mapset = G_store(G_mapset());
+ Map->location = G_store(G_location());
+ Map->gisdbase = G_store(G_gisdbase());
/* determine output format */
if (strcmp(G_program_name(), "v.external") != 0)
@@ -739,19 +732,31 @@
if (Map->format != GV_FORMAT_OGR_DIRECT &&
getenv("GRASS_VECTOR_PGFILE") == NULL) { /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
+ char *path;
G_debug(2, " using non-direct format");
- /* check if map already exists */
- if (G_find_vector2(name, G_mapset()) != NULL) {
- G_warning(_("Vector map <%s> already exists and will be overwritten"),
- name);
- ret = Vect_delete(name);
- if (ret == -1) {
+ /* check if map already exists
+ temporary maps are automatically overwritten
+ if (-1 == Vect__delete(name, Map->temporary)) {
G_warning(_("Unable to delete vector map <%s>"), name);
return -1;
+ else {
+ if (G_find_vector2(name, G_mapset()) != NULL) {
+ G_warning(_("Vector map <%s> already exists and will be overwritten"),
+ name);
+ ret = Vect_delete(name);
+ if (ret == -1) {
+ G_warning(_("Unable to delete vector map <%s>"), name);
+ return -1;
/* write header file
@@ -764,8 +769,9 @@
Vect__write_head(Map);
/* create history file */
- Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
+ Map->hist_fp = G_fopen_new(path, GV_HIST_ELEMENT);
+ G_free(path);
G_warning(_("Unable to open history file of vector map <%s>"),
name);
@@ -808,6 +814,63 @@
+ \brief Create new vector map for reading/writing
+ By default list of updated features is not maintained, see
+ Vect_set_updated() for details.
+ By default map format is native (GV_FORMAT_NATIVE). If OGR file is
+ found in the current mapset then the map (ie. OGR layer) is created
+ in given OGR datasource (GV_FORMAT_OGR). Similarly if PG file exists
+ then the map (ie. PostGIS table) is created using PostGIS interface
+ (GV_FORMAT_POSTGIS). The format of map is stored in Map->format.
+ \param[out] Map pointer to Map_info structure
+ \param name name of vector map to be created
+ \param with_z WITH_Z for 3D vector data otherwise WITHOUT_Z
+ \return 1 on success
+ \return -1 on error
+int Vect_open_new(struct Map_info *Map, const char *name, int with_z)
+ return open_new(Map, name, with_z, FALSE);
+ \brief Create new temporary vector map
+ Temporary vector maps are stored in the current mapset (directory
+ <tt>.tmp/<hostname>/vector</tt>).
+ Temporary vector maps are automatically deleted when closing the map
+ (see Vect_close() for details).
+ If <em>name</em> is not given (is NULL), then the name is determined
+ by process id (<tt>tmp_<pid></tt>).
+ \param[out] Map pointer to output Map_info struct
+ \param name name for new vector map (or NULL)
+int Vect_open_tmp_new(struct Map_info *Map, const char *name, int with_z)
+ char tmp_name[GNAME_MAX];
+ if (!name) {
+ sprintf(tmp_name, "tmp_%d", getpid());
+ else {
+ sprintf(tmp_name, "%s", name);
+ return open_new(Map, tmp_name, with_z, TRUE); /* temporary map */
\brief Update Coor_info structure
\param Map pointer to Map_info structure
@@ -818,16 +881,17 @@
int Vect_coor_info(const struct Map_info *Map, struct Coor_info *Info)
- char buf[GPATH_MAX], path[GPATH_MAX];
+ char *path, file_path[GPATH_MAX];
STRUCT_STAT stat_buf;
switch (Map->format) {
case GV_FORMAT_NATIVE:
- G_file_name(path, buf, GV_COOR_ELEMENT, Map->mapset);
- G_debug(1, "get coor info: %s", path);
- if (0 != stat(path, &stat_buf)) {
- G_warning(_("Unable to stat file <%s>"), path);
+ G_file_name(file_path, path, GV_COOR_ELEMENT, Map->mapset);
+ G_free(path);
+ G_debug(1, "get coor info: %s", file_path);
+ if (0 != stat(file_path, &stat_buf)) {
+ G_warning(_("Unable to stat file <%s>"), file_path);
Info->size = -1L;
Info->mtime = -1L;
@@ -853,7 +917,7 @@
Info->mtime = 0L;
break;
- G_debug(1, "Info->size = %lu, Info->mtime = %ld",
+ G_debug(1, "Vect_coor_info(): Info->size = %lu, Info->mtime = %ld",
(unsigned long)Info->size, Info->mtime);
return 1;
@@ -1007,7 +1071,6 @@
int Vect_open_sidx(struct Map_info *Map, int mode)
- char buf[GPATH_MAX], file_path[GPATH_MAX];
int err;
struct Plus_head *Plus;
@@ -1025,15 +1088,17 @@
dig_file_init(&(Plus->spidx_fp));
if (mode < 2) {
- G_file_name(file_path, buf, GV_SIDX_ELEMENT, Map->mapset);
+ G_file_name(file_path, path, GV_SIDX_ELEMENT, Map->mapset);
if (access(file_path, F_OK) != 0) /* does not exist */
return 1;
- Plus->spidx_fp.file =
- G_fopen_old(buf, GV_SIDX_ELEMENT, Map->mapset);
+ Plus->spidx_fp.file = G_fopen_old(path, GV_SIDX_ELEMENT, Map->mapset);
+ G_free(path);
if (Plus->spidx_fp.file == NULL) { /* sidx file is not available */
G_debug(1, "Cannot open spatial index file for vector '%s@%s'.",
@@ -1222,5 +1287,52 @@
+ G_debug(2, "map_format = %d", Map->format);
return Map->format;
+ \brief Get map directory name (internal use only)
+ Allocate string should be freed by G_free().
+ \param Map pointer to Map_info struct
+ \return allocated buffer containing path
+char *Vect__get_path(const struct Map_info *Map)
+ char path[GPATH_MAX];
+ char path_tmp[GPATH_MAX];
+ G__temp_element(path_tmp);
+ sprintf(path, "%s/%s/%s", path_tmp, GV_DIRECTORY, Map->name);
+ else {
+ sprintf(path, "%s/%s", GV_DIRECTORY, Map->name);
+ return G_store(path);
+ \brief Get map element full path (internal use only)
+ \param element element name, eg. GV_TOPO_ELEMENT
+char *Vect__get_element_path(const struct Map_info *Map, const char *element)
+ char file_path[GPATH_MAX], *path;
+ G_file_name(file_path, path, element, Map->mapset);
+ G_free(path);
+ return G_store(file_path);
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/Vlib/open_nat.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -21,7 +21,8 @@
-static char name_buf[GPATH_MAX];
static int check_coor(struct Map_info *Map);
@@ -90,44 +91,45 @@
int V1_open_new_nat(struct Map_info *Map, const char *name, int with_z)
- G_debug(1, "V1_open_new_nat(): name = %s", name);
+ G_debug(1, "V1_open_new_nat(): name = %s with_z = %d is_tmp = %d",
+ name, with_z, Map->temporary);
/* Set the 'coor' file version */
Map->head.Version_Major = GV_COOR_VER_MAJOR;
Map->head.Version_Minor = GV_COOR_VER_MINOR;
- Map->head.Back_Major = GV_COOR_EARLIEST_MAJOR;
- Map->head.Back_Minor = GV_COOR_EARLIEST_MINOR;
+ Map->head.Back_Major = GV_COOR_EARLIEST_MAJOR;
+ Map->head.Back_Minor = GV_COOR_EARLIEST_MINOR;
/* TODO: open better */
dig_file_init(&(Map->dig_fp));
- Map->dig_fp.file = G_fopen_new(buf, GV_COOR_ELEMENT);
+ Map->dig_fp.file = G_fopen_new(path, GV_COOR_ELEMENT);
if (Map->dig_fp.file == NULL)
- return (-1);
+ return -1;
fclose(Map->dig_fp.file);
- Map->dig_fp.file = G_fopen_modify(buf, GV_COOR_ELEMENT);
+ Map->dig_fp.file = G_fopen_modify(path, GV_COOR_ELEMENT);
- return (-1);
+ return -1;
/* if overwrite OK, any existing files have already been deleted by
* Vect_open_new(): remove this check ? */
/* check to see if dig_plus file exists and if so, remove it */
- G_file_name(name_buf, buf, GV_TOPO_ELEMENT, G_mapset());
- if (access(name_buf, F_OK) == 0) /* file exists? */
- unlink(name_buf);
- G_file_name(name_buf, buf, GV_COOR_ELEMENT, G_mapset());
+ G_free(path);
+ if (access(file_path, F_OK) == 0)
+ unlink(file_path); /* remove topo file if exists */
/* set conversion matrices */
dig_init_portable(&(Map->head.port), dig__byte_order_out());
+ /* write coor header */
if (!(dig__write_head(Map)))
- return (-1);
+ return -1;
return 0;
Modified: grass/trunk/lib/vector/diglib/head.c
--- grass/trunk/lib/vector/diglib/head.c 2013-03-16 14:20:57 UTC (rev 55400)
+++ grass/trunk/lib/vector/diglib/head.c 2013-03-16 14:40:42 UTC (rev 55401)
@@ -75,7 +75,7 @@
G_debug(2, "coor body offset %"PRI_OFF_T, dig_ftell(&(Map->dig_fp)));
- return (1);
+ return 1;
