[GRASS-SVN] r55410 - in grass/trunk/lib: init vector/Vlib
svn_grass at osgeo.org
Sun Mar 17 07:41:14 PDT 2013
Author: martinl
Date: 2013-03-17 07:41:14 -0700 (Sun, 17 Mar 2013)
New Revision: 55410
grass/trunk/lib/init/variables.html
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/open.c
vlib: document GRASS_VECTOR_EXTERNAL_IMMEDIATE variable
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2013-03-17 14:18:28 UTC (rev 55409)
+++ grass/trunk/lib/init/variables.html 2013-03-17 14:41:14 UTC (rev 55410)
@@ -244,6 +244,19 @@
PostgreSQL, vector data is written by OGR data provider even
the native PostGIS data provider is available.</dd>
+ <dt>GRASS_VECTOR_EXTERNAL_IMMEDIATE</dt>
+ <dd>[vectorlib, v.external.out]<br> If the environment variable
+ GRASS_VECTOR_EXTERNAL_IMMEDIATE exists and vector output format
+ defined
+ by <em><a href="v.external.out.html">v.external.out</a></em> is
+ non-native, vector features are written to output external
+ datasource immediately. By default, the vector library writes
+ output data to a temporary vector map in native format and when
+ closing the map, the features are transfered to output external
+ datasource. Note: if output vector format is topological PostGIS
+ format, then the vector library writes features immediately to output
+ database (in this case GRASS_VECTOR_EXTERNAL_IMMEDIATE is ignored).</dd>
<dt>GRASS_WXBUNDLED</dt>
<dd>[wxGUI]<br>
set to tell wxGUI that a bundled wxPython will be used.<br>
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2013-03-17 14:18:28 UTC (rev 55409)
+++ grass/trunk/lib/vector/Vlib/close.c 2013-03-17 14:41:14 UTC (rev 55410)
@@ -85,7 +85,7 @@
/* transfer features for external output format */
struct Map_info Out;
- putenv("GRASS_VECTOR_EXTERNAL_DIRECT=1");
+ putenv("GRASS_VECTOR_EXTERNAL_IMMEDIATE=1");
if (-1 == Vect_open_new(&Out, Vect_get_name(Map), Vect_is_3d(Map))) {
G_warning(_("Unable to create vector map <%s>"),
Vect_get_name(Map));
@@ -103,7 +103,7 @@
Vect_build(&Out);
Vect_close(&Out);
- putenv("GRASS_VECTOR_EXTERNAL_DIRECT="); /* unset variable */
+ putenv("GRASS_VECTOR_EXTERNAL_IMMEDIATE="); /* unset variable */
/* check for external formats whether to create a link */
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2013-03-17 14:18:28 UTC (rev 55409)
+++ grass/trunk/lib/vector/Vlib/open.c 2013-03-17 14:41:14 UTC (rev 55410)
@@ -1200,7 +1200,7 @@
struct Format_info_ogr *ogr_info;
G_debug(2, " using OGR format");
- if (getenv("GRASS_VECTOR_EXTERNAL_DIRECT")) {
+ if (getenv("GRASS_VECTOR_EXTERNAL_IMMEDIATE")) {
/* vector features are written directly to OGR layer */
format = GV_FORMAT_OGR;
@@ -1305,7 +1305,7 @@
p = G_find_key_value("topology", key_val);
topology = p && G_strcasecmp(p, "yes") == 0;
- if (topology || getenv("GRASS_VECTOR_EXTERNAL_DIRECT")) {
+ if (topology || getenv("GRASS_VECTOR_EXTERNAL_IMMEDIATE")) {
/* vector features are written directly to PostGIS layer */
format = GV_FORMAT_POSTGIS;
