[GRASS-SVN] r55420 - grass/trunk/gui/wxpython/lmgr
Mon Mar 18 04:44:32 PDT 2013
Author: zarch
Date: 2013-03-18 04:44:32 -0700 (Mon, 18 Mar 2013)
New Revision: 55420
   grass/trunk/gui/wxpython/lmgr/giface.py
Improve the interaction with Layer and LayerList objects
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py	2013-03-18 10:56:20 UTC (rev 55419)
+++ grass/trunk/gui/wxpython/lmgr/giface.py	2013-03-18 11:44:32 UTC (rev 55420)
@@ -17,6 +17,7 @@
 from grass.pydispatch.signal import Signal
 class Layer(object):
     """!@implements core::giface::Layer
@@ -29,17 +30,31 @@
     def __getattr__(self, name):
         return self._pydata[0][name]
+    def __dir__(self):
+        return self._pydata[0].keys()
+    def __repr__(self):
+        return self.maplayer.name
 class LayerList(object):
     """!@implements core.giface.Layer"""
     def __init__(self, tree):
         self._tree = tree
-#    def __iter__(self):
-#    """!Iterates over the contents of the list."""
-#        for in :
-#            yield
+    def __iter__(self):
+        """!Iterates over the contents of the list."""
+        for item in self._tree.GetSelectedLayer(multi=True):
+            yield Layer(self._tree.GetPyData(item))
+    def __getitem__(self, index):
+        """!Select a layer from the LayerList using the index."""
+        return [l for l in self][index]
+        """!Return a representation of the object."""
+        return "LayerList(%r)" % [layer for layer in self]
     def GetSelectedLayers(self, checkedOnly=True):
         items = self._tree.GetSelectedLayer(multi=True,
                                             checkedOnly=checkedOnly)
