[GRASS-SVN] r55423 - grass/branches/develbranch_6/db/base
svn_grass at osgeo.org
Mon Mar 18 10:51:46 PDT 2013
Author: neteler
Date: 2013-03-18 10:51:46 -0700 (Mon, 18 Mar 2013)
New Revision: 55423
grass/branches/develbranch_6/db/base/db.copy.html
docs prettified
Modified: grass/branches/develbranch_6/db/base/db.copy.html
--- grass/branches/develbranch_6/db/base/db.copy.html 2013-03-18 17:51:35 UTC (rev 55422)
+++ grass/branches/develbranch_6/db/base/db.copy.html 2013-03-18 17:51:46 UTC (rev 55423)
@@ -5,9 +5,10 @@
<h2>NOTES</h2>
-Attribute tables can be copied manually using db.copy and
+Attribute tables can be copied using <em>db.copy</em> and, when to be
+associated to a vector map, assigned to the map with
<em><a href="v.db.connect.html">v.db.connect</a></em>. Current connection
-settings are saved in <em>$LOCATION/vector_map/dbln</em>.
+settings are saved in the file <em>$LOCATION/vector_map/dbln</em>.
<h2>EXAMPLES</h2>
