[GRASS-SVN] r55428 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Mon Mar 18 11:54:47 PDT 2013
Author: neteler
Date: 2013-03-18 11:54:47 -0700 (Mon, 18 Mar 2013)
New Revision: 55428
grass/branches/develbranch_6/lib/gis/make_loc.c
fix trac #1905 (backport of r55415); doxygen cosmetics
Modified: grass/branches/develbranch_6/lib/gis/make_loc.c
--- grass/branches/develbranch_6/lib/gis/make_loc.c 2013-03-18 18:54:35 UTC (rev 55427)
+++ grass/branches/develbranch_6/lib/gis/make_loc.c 2013-03-18 18:54:47 UTC (rev 55428)
@@ -91,26 +91,26 @@
* This function creates a new location in the current database,
* initializes the projection, default window and current window.
- * \param char * location_name
+ * \param location_name
* The name of the new location. Should not include
* the full path, the location will be created within
* the current database.
- * \param struct Cell_head *wind
+ * \param wind
* Contains the default window setting for the
* new location. All fields should be set in this
* structure, and care should be taken to ensure that
* the proj/zone fields match the definition in the
* proj_info parameter (see G_set_cellhd_from_projinfo()).
- * \param struct Key_Value *proj_info
+ * \param proj_info
* Projection definition suitable to write to the
* PROJ_INFO file, or NULL for PROJECTION_XY.
- * \param struct Key_Value *proj_units
+ * \param proj_units
* Projection units suitable to write to the PROJ_UNITS
* file, or NULL.
- * \param FILE *report_file
+ * \param report_file
* File to which creation information should be written
* (can be stdout). Currently not used.
@@ -155,8 +155,10 @@
* \param proj_info2
* \param proj_units2
* \return -1 if not the same projection, -2 if linear unit translation to
- * meters fails, -4 if not the same ellipsoid, -5 if UTM zone differs
- * else TRUE if projections match.
+ * meters fails, -4 if not the same ellipsoid,
+ * -5 if UTM zone differs, -6 if UTM hemisphere differs,
+ * -7 if false easting differs, -8 if false northing differs,
+ * else TRUE if projections match.
@@ -232,6 +234,14 @@
return -5;
+ /* Hemisphere check specially for UTM */
+ if (!strcmp(proj1, "utm") && !strcmp(proj2, "utm")
+ && !!G_find_key_value("south", proj_info1)
+ != !!G_find_key_value("south", proj_info2))
+ return -6;
/* Do they both have the same false easting? */
@@ -242,7 +252,7 @@
x_0_2 = G_find_key_value("x_0", proj_info2);
if (x_0_1 && x_0_2 && (fabs(atof(x_0_1) - atof(x_0_2)) > 0.000001))
- return -6;
+ return -7;
@@ -256,7 +266,7 @@
y_0_2 = G_find_key_value("y_0", proj_info2);
if (y_0_1 && y_0_2 && (fabs(atof(y_0_1) - atof(y_0_2)) > 0.000001))
- return -7;
+ return -8;
