[GRASS-SVN] r55449 - grass/trunk/lib/python/pygrass/vector
Tue Mar 19 08:24:22 PDT 2013
Author: zarch
Date: 2013-03-19 08:24:21 -0700 (Tue, 19 Mar 2013)
New Revision: 55449
   grass/trunk/lib/python/pygrass/vector/geometry.py
Fix bug using vector category
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py	2013-03-19 15:24:14 UTC (rev 55448)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py	2013-03-19 15:24:21 UTC (rev 55449)
@@ -130,9 +130,19 @@
     def __init__(self, cat, table, writable=False):
         self.cat = cat
         self.table = table
-        self.cond = "%s=%d" % (self.table.key, self.cat)
         self.writable = writable
+    def _get_cat(self):
+        return self._cat
+    def _set_cat(self, value):
+        self._cat = value
+        if value:
+            # update condition
+            self.cond = "%s=%d" % (self.table.key, self.cat)
+    cat = property(fget=_get_cat, fset=_set_cat)
     def __getitem__(self, key):
         """Return the value stored in the attribute table. ::
@@ -236,7 +246,6 @@
     def __init__(self, v_id=None, c_mapinfo=None, c_points=None, c_cats=None,
                  table=None, writable=False, is2D=True):
         self.id = v_id  # vector id
-        self.cat = self.id
         self.c_mapinfo = c_mapinfo
         self.is2D = is2D
         self.gtype = None
@@ -255,9 +264,14 @@
         # set the attributes
         self.attrs = None
-        if table is not None and self.cat:
+        if table is not None:
             self.attrs = Attrs(self.cat, table, writable)
+    @property
+    def cat(self):
+        if self.c_cats.contents.cat:
+            return self.c_cats.contents.cat.contents.value
     def is_with_topology(self):
         if self.c_mapinfo is not None:
             return self.c_mapinfo.contents.level == 2
@@ -1241,7 +1255,6 @@
             self.isles = self.get_isles()
             libvect.Vect_read_line(self.c_mapinfo, None, self.c_cats,
                                    self.centroid.id)
-            self.cat = self.c_cats.contents.cat.contents.value
         elif boundary and centroid:
             self.boundary = boundary
             self.centroid = centroid
@@ -1252,8 +1265,7 @@
         if self.attrs and self.cat:
-            self.attrs = Attrs(self.cat,
-                               self.attrs.table, self.attrs.writable)
+            self.attrs.cat = self.cat
         # geometry type
         self.gtype = libvect.GV_AREA
