[GRASS-SVN] r55454 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Mar 19 08:24:57 PDT 2013
Author: zarch
Date: 2013-03-19 08:24:57 -0700 (Tue, 19 Mar 2013)
New Revision: 55454
Added:
grass/trunk/lib/python/pygrass/vector/find.py
grass/trunk/lib/python/pygrass/vector/Makefile
grass/trunk/lib/python/pygrass/vector/abstract.py
Add the Finder class to the vector map
Modified: grass/trunk/lib/python/pygrass/vector/Makefile
--- grass/trunk/lib/python/pygrass/vector/Makefile 2013-03-19 15:24:47 UTC (rev 55453)
+++ grass/trunk/lib/python/pygrass/vector/Makefile 2013-03-19 15:24:57 UTC (rev 55454)
@@ -9,7 +9,7 @@
PGDIR = $(GDIR)/pygrass
DSTDIR= $(PGDIR)/vector
-MODULES = abstract basic geometry sql table vector_type
+MODULES = abstract basic find geometry sql table vector_type
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
@@ -29,4 +29,4 @@
$(INSTALL_DATA) $< $@
#doxygen:
-DOXNAME = pythonpygrass
\ No newline at end of file
+DOXNAME = pythonpygrass
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2013-03-19 15:24:47 UTC (rev 55453)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2013-03-19 15:24:57 UTC (rev 55454)
@@ -12,6 +12,7 @@
from grass.pygrass import functions
from grass.pygrass.errors import GrassError, OpenError, must_be_open
from table import DBlinks, Link
+from find import Finder
def is_open(c_mapinfo):
@@ -361,6 +362,7 @@
self.table = self.dblinks.by_layer(layer).table()
self.n_lines = self.table.n_rows()
self.writable = self.mapset == functions.getenv("MAPSET")
+ self.find = Finder(self.c_mapinfo, self.table, self.writable)
def close(self):
"""Method to close the Vector"""
Added: grass/trunk/lib/python/pygrass/vector/find.py
--- grass/trunk/lib/python/pygrass/vector/find.py (rev 0)
+++ grass/trunk/lib/python/pygrass/vector/find.py 2013-03-19 15:24:57 UTC (rev 55454)
@@ -0,0 +1,121 @@
+# -*- coding: utf-8 -*-
+Created on Tue Mar 19 11:09:30 2013
+ at author: pietro
+import grass.lib.vector as libvect
+from grass.pygrass.errors import must_be_open
+from basic import Ilist
+from geometry import read_line, Isle, Area
+class Finder(object):
+ """Find the geomtry features of a vector map that are close to a point. ::
+ >>> from grass.pygrass.vector import VectorTopo
+ >>> zipcodes = VectorTopo('zipcodes', 'PERMANENT')
+ >>> schools = VectorTopo('schools', 'PERMANENT')
+ >>> zipcodes.open('r')
+ >>> schools.open('r')
+ >>> result = []
+ >>> for school in schools:
+ ... zipcode = zipcodes.find.area(school)
+ ... result.append((school.attrs['NAMESHORT'],
+ ... zipcode.attrs['ZIPCODE']))
+ >>> result[0]
+ (u'SWIFT CREEK', u'RALEIGH 27606')
+ >>> result[1]
+ (u'BRIARCLIFF', u'CARY 27511')
+ >>> result[2]
+ (u'FARMINGTON WOODS', u'CARY 27511')
+ >>> from grass.pygrass.vector.geometry import Point
+ >>> pnt = Point(631213.349291, 224684.900084)
+ >>> school = schools.find.geo(pnt, maxdist=300.)
+ >>> school.attrs['NAMELONG']
+ u'ADAMS ELEMENTARY'
+ >>> for school in schools.find.geos(pnt, maxdist=1000.):
+ ... print school.attrs['NAMELONG']
+ CARY HIGH
+ EAST CARY MIDDLE SITE
+ ADAMS ELEMENTARY
+ >>> schools.close()
+ >>> zipcodes.close()
+ def __init__(self, c_mapinfo, table=None, writable=False):
+ """Find geometry feature around a point.
+ self.c_mapinfo = c_mapinfo
+ self.table = table
+ self.writable = writable
+ self.vtype = {'point': libvect.GV_POINT, # 1
+ 'line': libvect.GV_LINE, # 2
+ 'boundary': libvect.GV_BOUNDARY, # 3
+ 'centroid': libvect.GV_CENTROID, # 4
+ 'all': -1} # -1
+# TODO: add the Node class and enable this method
+# def node(self, point, maxdist):
+# """Find the nearest node. Vect_find_node"""
+# i = libvect.Vect_find_node(self.c_mapinfo, point.x, point.y, point.z,
+# float(maxdist), int(not point.is2D))
+# return geometry.Node(self.c_mapinfo.contents.plus.contents.Node[i])
+ @must_be_open
+ def geo(self, point, maxdist, type='all', exclude=0):
+ """Find the nearest line. Vect_find_line
+ Valid type are all the keys in find.vtype dictionary
+ feature_id = libvect.Vect_find_line(self.c_mapinfo,
+ point.x, point.y,
+ point.z if point.z else 0,
+ self.vtype[type], float(maxdist),
+ int(not point.is2D), exclude)
+ if feature_id:
+ return read_line(feature_id, self.c_mapinfo,
+ self.table, self.writable)
+ @must_be_open
+ def geos(self, point, maxdist, type='all', exclude=[]):
+ """Find the nearest line. Vect_find_line_list
+ excl = Ilist(exclude)
+ found = Ilist()
+ if libvect.Vect_find_line_list(self.c_mapinfo,
+ point.x, point.y,
+ excl.c_ilist, found.c_ilist):
+ return [read_line(f_id, self.c_mapinfo, self.table, self.writable)
+ for f_id in found]
+ else:
+ return []
+ @must_be_open
+ def area(self, point):
+ """Find the nearest area. Vect_find_area"""
+ area_id = libvect.Vect_find_area(self.c_mapinfo, point.x, point.y)
+ if area_id:
+ return Area(v_id=area_id, c_mapinfo=self.c_mapinfo,
+ table=self.table, writable=self.writable)
+ @must_be_open
+ def island(self, point):
+ """Find the nearest island. Vect_find_island"""
+ isle_id = libvect.Vect_find_island(self.c_mapinfo, point.x, point.y)
+ if isle_id:
+ return Isle(v_id=isle_id, c_mapinfo=self.c_mapinfo,
+ def is_open(self):
+ """Check if the vector map is open or not"""
+ import abstract
+ return abstract.is_open(self.c_mapinfo)
