[GRASS-SVN] r55460 - in grass/trunk: . gui/wxpython/core gui/wxpython/dbmgr gui/wxpython/iclass gui/wxpython/lmgr gui/wxpython/web_services lib/display lib/gis lib/ogsf
svn_grass at osgeo.org
Tue Mar 19 14:02:09 PDT 2013
Author: wenzeslaus
Date: 2013-03-19 14:02:09 -0700 (Tue, 19 Mar 2013)
New Revision: 55460
grass/trunk/grasslib.dox
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/web_services/dialogs.py
grass/trunk/lib/display/symbol.c
grass/trunk/lib/gis/gislib.dox
grass/trunk/lib/ogsf/gvl_file.c
dox: syntax errors
Modified: grass/trunk/grasslib.dox
--- grass/trunk/grasslib.dox 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/grasslib.dox 2013-03-19 21:02:09 UTC (rev 55460)
@@ -89,7 +89,7 @@
\subsection vectoribs Vector Libraries
- %vector: \ref vectorlib
- - dglib: \ref dglib
+ - dglib (internal library)
- vedit: \ref veditlib - %vector editing
- neta: \ref netalib
- sites: Old Sites library, now interfaced to \ref vectorlib - \ref sites
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/gui/wxpython/core/utils.py 2013-03-19 21:02:09 UTC (rev 55460)
@@ -848,8 +848,8 @@
def SetAddOnPath(addonPath = None, key = 'PATH'):
"""!Set default AddOn path
- @addonPath path to addons (None for default)
- @key env key - 'PATH' or 'BASE'
+ @param addonPath path to addons (None for default)
+ @param key env key - 'PATH' or 'BASE'
gVersion = grass.version()['version'].split('.', 1)[0]
# update env file
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py 2013-03-19 21:02:09 UTC (rev 55460)
@@ -20,7 +20,7 @@
@author Jachym Cepicky <jachym.cepicky gmail.com> (original author)
@author Martin Landa <landa.martin gmail.com>
- at author Hamish Bowman <hamish_b yahoo com>
+ at author Hamish Bowman <hamish_b yahoo.com>
@author Refactoring, SQLBUilderUpdate by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2013-03-19 21:02:09 UTC (rev 55460)
@@ -1080,7 +1080,7 @@
def OnPointer(self, event):
"""!Set pointer mode.
- @fixme: needs refactoring
+ @todo: pointers need refactoring
toolbar = self.GetMapToolbar()
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2013-03-19 21:02:09 UTC (rev 55460)
@@ -137,8 +137,8 @@
def __init__(self, giface, tree):
- @giface original grass interface
- @tree tree which will be used instead of the tree from giface
+ @param giface original grass interface
+ @param tree tree which will be used instead of the tree from giface
self._giface = giface
self.tree = tree
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py 2013-03-19 21:02:09 UTC (rev 55460)
@@ -644,7 +644,7 @@
def LoadCapFiles(self, ws_cap_files, cmd):
"""!Parse cap files and update dialog.
- @params for description see constructor
+ For parameters description, see the constructor.
self.ch_ws_sizer.Clear(deleteWindows = True)
Modified: grass/trunk/lib/display/symbol.c
--- grass/trunk/lib/display/symbol.c 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/lib/display/symbol.c 2013-03-19 21:02:09 UTC (rev 55460)
@@ -131,13 +131,16 @@
* The symbol must be pre-processed with S_stroke() before being sent
* to this function.
- * example:
+ * \par Example
+ * \code
* #include <grass/display.h>
* #include <grass/symbol.h>
* SYMBOL *Symb;
* Symb = S_read( symbol_name );
* S_stroke( Symb, size, rotation, tolerance );
* D_symbol( Symb, x0, y0, line_color, fill_color );
+ * \endcode
* \param Symb The symbol name (e.g. basic/circle)
* \param x0 The starting x display coordinate (pixel)
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/lib/gis/gislib.dox 2013-03-19 21:02:09 UTC (rev 55460)
@@ -1058,13 +1058,13 @@
- G_plot_where_en()
The pixel coordinates <i>x,y</i> are converted to map coordinates
-east,north</i>. See G_setup_plot() for the required coordinate
+<i>east,north</i>. See G_setup_plot() for the required coordinate
initialization procedure.
- G_plot_where_xy()
The map coordinates <i>east,north</i> are converted to pixel
-coordinates <i>x,y.</i>. See G_setup_plot() for the required
+coordinates <i>x,y</i>. See G_setup_plot() for the required
coordinate initialization procedure.
- G_plot_fx()
Modified: grass/trunk/lib/ogsf/gvl_file.c
--- grass/trunk/lib/ogsf/gvl_file.c 2013-03-19 17:31:21 UTC (rev 55459)
+++ grass/trunk/lib/ogsf/gvl_file.c 2013-03-19 21:02:09 UTC (rev 55460)
@@ -412,7 +412,7 @@
\param[out] min min value
\param[out] max max value
- \pointer to data
+ \returns pointer to data
void *open_g3d_file(const char *filename, IFLAG * type, double *min,
double *max)
