[GRASS-SVN] r55471 - in grass/trunk/temporal: . t.rast.aggregate t.rast.neighbors
Wed Mar 20 11:11:45 PDT 2013
Author: huhabla
Date: 2013-03-20 11:11:45 -0700 (Wed, 20 Mar 2013)
New Revision: 55471
Added:
   grass/trunk/temporal/t.rast.neighbors/
   grass/trunk/temporal/t.rast.neighbors/Makefile
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
   grass/trunk/temporal/Makefile
   grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html
Added new module to perform neighborhood computations on STRDS
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile	2013-03-20 17:53:11 UTC (rev 55470)
+++ grass/trunk/temporal/Makefile	2013-03-20 18:11:45 UTC (rev 55471)
@@ -17,6 +17,7 @@
 	t.rast.univar \
 	t.rast.list \
 	t.rast.mapcalc \
+	t.rast.neighbors \
 	t.rast.series \
 	t.rast.export \
 	t.rast.out.vtk \
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html	2013-03-20 17:53:11 UTC (rev 55470)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html	2013-03-20 18:11:45 UTC (rev 55471)
@@ -59,7 +59,7 @@
          description="Test dataset with daily precipitation"
 t.register -i type=rast input=precipitation_daily \
-           file=map_list.txt start=20-08-2012 increment="1 days"
+           file=map_list.txt start="2012-08-20" increment="1 days"
 t.info type=strds input=precipitation_daily
Added: grass/trunk/temporal/t.rast.neighbors/Makefile
--- grass/trunk/temporal/t.rast.neighbors/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.rast.neighbors/Makefile	2013-03-20 18:11:45 UTC (rev 55471)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.neighbors
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html	                        (rev 0)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html	2013-03-20 18:11:45 UTC (rev 55471)
@@ -0,0 +1,178 @@
+<h2>DESCRIPTION</h2>
+<em>t.rast.neighbors</em> performs <a href="r.neighbors.html">r.neighbors</a> computations
+on the maps of a space time raster dataset (STRDS). This module supports a subset of options
+that are available in <a href="r.neighbors.html">r.neighbors</a>.
+The size of the neighborhood and the aggregation method can be chosen.
+<p>
+The user must provide an input and an output space time raster dataset and the basename
+of the resulting raster maps. The resulting STRDS will have
+the same temporal resolution as the input dataset.
+All maps will be processed using the current region settings.
+<p>
+The user can select a subset of the input space time raster dataset for processing
+using a SQL WHERE statement. The number of CPU's to be used for parallel processing can be specified
+with the <em>nprocs</em> option, to speedup the computation on multicore system.
+<h2>EXAMPLE</h2>
+In this example we create 7 raster maps that will be registered in a single space time
+raster dataset named <em>precipitation_daily</em> using a daily temporal granularity.
+The names of the raster maps are stored in a text file that is used for raster map registration.
+<p>
+A neighborhood average smoothing with a window size of 5 cells will be performed on
+the space time raster dataset <em>precipitation_daily</em> resulting in the output space time raster dataset
+<em>precipitation_daily_smooth</em>. The base name of the new generated raster maps is <em>prec_smooth</em>.
+The temporal resolution of the resulting STRDS is identical to the input STRDS.
+<div class="code"><pre>
+MAPS="map_1 map_2 map_3 map_4 map_5 map_6 map_7"
+count=1
+for map in ${MAPS} ; do
+    export GRASS_RND_SEED=${count}
+    r.mapcalc --o expr="${map} = rand(0, 550)"
+    echo ${map} >> map_list.txt
+    count=$((count+1))
+done
+t.create --o type=strds temporaltype=absolute \
+         output=precipitation_daily \
+         title="Daily precipitation" \
+         description="Test dataset with daily precipitation"
+t.register -i --o type=rast input=precipitation_daily \
+t.info type=strds input=precipitation_daily
+ +-------------------- Space Time Raster Dataset -----------------------------+
+ +-------------------- Basic information -------------------------------------+
+ | Id: ........................ precipitation_daily at PERMANENT
+ | Name: ...................... precipitation_daily
+ | Mapset: .................... PERMANENT
+ | Creator: ................... soeren
+ | Creation time: ............. 2013-03-20 18:47:25.867658
+ | Temporal type: ............. absolute
+ | Semantic type:.............. mean
+ +-------------------- Absolute time -----------------------------------------+
+ | Start time:................. 2012-08-20 00:00:00
+ | End time:................... 2012-08-27 00:00:00
+ | Granularity:................ 1 days
+ | Temporal type of maps:...... interval
+ +-------------------- Spatial extent ----------------------------------------+
+ | North:...................... 80.0
+ | South:...................... 0.0
+ | East:.. .................... 120.0
+ | West:....................... 0.0
+ | Top:........................ 0.0
+ | Bottom:..................... 0.0
+ +-------------------- Metadata information ----------------------------------+
+ | Number of registered maps:.. 7
+ | Title:
+ | Daily precipitation
+ | Description:
+ | Test dataset with daily precipitation
+ | North-South resolution min:. 10.0
+ | North-South resolution max:. 10.0
+ | East-west resolution min:... 10.0
+ | East-west resolution max:... 10.0
+ | Minimum value min:.......... 0.0
+ | Minimum value max:.......... 8.0
+ | Maximum value min:.......... 533.0
+ | Maximum value max:.......... 549.0
+ | Raster register table:...... precipitation_daily_PERMANENT_raster_register
+t.rast.list input=precipitation_daily columns=name,start_time,min,max
+map_1   2012-08-20 00:00:00     2.0     549.0
+map_2   2012-08-21 00:00:00     4.0     549.0
+map_3   2012-08-22 00:00:00     8.0     548.0
+map_4   2012-08-23 00:00:00     3.0     549.0
+map_5   2012-08-24 00:00:00     0.0     533.0
+map_6   2012-08-25 00:00:00     2.0     543.0
+map_7   2012-08-26 00:00:00     1.0     539.0
+t.rast.neighbors --o input=precipitation_daily \
+    output=precipitation_daily_smooth base=prec_smooth \
+    size=5 method=average nprocs=3
+t.info type=strds input=precipitation_daily_smooth
+ | Id: ........................ precipitation_daily_smooth at PERMANENT
+ | Name: ...................... precipitation_daily_smooth
+ | Creation time: ............. 2013-03-20 18:47:28.697990
+ | Title:
+ | Description:
+ | Minimum value min:.......... 140.166667
+ | Minimum value max:.......... 215.166667
+ | Maximum value min:.......... 293.3
+ | Maximum value max:.......... 373.388889
+ | Raster register table:...... precipitation_daily_smooth_PERMANENT_raster_register
+t.rast.list input=precipitation_daily_smooth columns=name,start_time,min,max
+prec_smooth_1   2012-08-20 00:00:00     172.388889      360.566667
+prec_smooth_2   2012-08-21 00:00:00     215.166667      322.833333
+prec_smooth_3   2012-08-22 00:00:00     140.166667      373.388889
+prec_smooth_4   2012-08-23 00:00:00     184.3           356.583333
+prec_smooth_5   2012-08-24 00:00:00     163.966667      293.3
+prec_smooth_6   2012-08-25 00:00:00     204.98          324.611111
+prec_smooth_7   2012-08-26 00:00:00     154.25          340.366667
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.neighbors.html">r.neighbors</a><br>
+<a href="t.rast.aggregate.ds.html">t.rast.aggregate.ds</a><br>
+<a href="t.rast.extract.html">t.rast.extract</a><br>
+<a href="t.info.html">t.info</a><br>
+<a href="g.region.html">g.region</a><br>
+<a href="r.mask.html">r.mask</a><br>
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert
+<p><i>Last changed: $Date: 2012-08-29 14:55:21 +0200 (Mi, 29. Aug 2012) $</i>
Added: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-03-20 18:11:45 UTC (rev 55471)
@@ -0,0 +1,268 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:       t.rast.neighbors
+# AUTHOR(S):    Soeren Gebbert
+# PURPOSE:      Performs a neighborhood analysis for each map in a space time raster dataset.
+# COPYRIGHT:    (C) 2013 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (version 2). Read the file COPYING that comes with GRASS
+#               for details.
+#%module
+#% description: Performs a neighborhood analysis for each map in a space time raster dataset.
+#% keywords: temporal
+#% keywords: aggregation
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: size
+#% type: integer
+#% description: Neighborhood size
+#% required: no
+#% multiple: no
+#% answer: 3
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name of the output space time raster dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Aggregate operation to be performed on the raster maps
+#% required: yes
+#% multiple: no
+#% options: average,median,mode,minimum,maximum,range,stddev,sum,count,variance,diversity,interspersion,quart1,quart3,perc90,quantile
+#% answer: average
+#%end
+#%option G_OPT_R_BASE
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r.neighbor processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Register Null maps
+#%end
+from multiprocessing import Process
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+    # Get the options
+    input = options["input"]
+    output = options["output"]
+    where = options["where"]
+    size = options["size"]
+    base = options["base"]
+    register_null = flags["n"]
+    method = options["method"]
+    nprocs = options["nprocs"]
+    # Make sure the temporal database exists
+    tgis.init()
+    # We need a database interface
+    dbif = tgis.SQLDatabaseInterfaceConnection()
+    dbif.connect()
+    mapset = grass.gisenv()["MAPSET"]
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    sp = tgis.SpaceTimeRasterDataset(id)
+    if sp.is_in_db() == False:
+        dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> not found") % (
+            sp.get_new_map_instance(None).get_type(), id))
+    sp.select(dbif)
+    dummy = sp.get_new_map_instance(None)
+    if output.find("@") >= 0:
+        out_id = output
+    else:
+        out_id = output + "@" + mapset
+    # The new space time raster dataset
+    new_sp = tgis.SpaceTimeRasterDataset(out_id)
+    if new_sp.is_in_db(dbif):
+        if not grass.overwrite():
+            dbif.close()
+            grass.fatal(_("Space time raster dataset <%s> is already in the "
+                          "database, use overwrite flag to overwrite") % out_id)
+    rows = sp.get_registered_maps("id,start_time", where, "start_time", dbif)
+    if not rows:
+        dbif.close()
+        grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
+    count = 0
+    proc_count = 0
+    proc_list = []
+    num_rows = len(rows)
+    new_maps = {}
+    for row in rows:
+        count += 1
+        grass.percent(count, num_rows, 1)
+        map_name = "%s_%i" % (base, count)
+        map_id = dummy.build_id(map_name, mapset)
+        new_map = sp.get_new_map_instance(map_id)
+        # Check if new map is in the temporal database
+        if new_map.is_in_db(dbif):
+            if grass.overwrite():
+                # Remove the existing temporal database entry
+                new_map.delete(dbif)
+            else:
+                grass.error(_("Map <%s> is already in temporal database,"
+                             " use overwrite flag to overwrite") %
+                            (new_map.get_map_id()))
+                continue
+        proc_list.append(Process(target=run_neighbors,
+                                     args=(row["id"],map_name,method,size)))
+        proc_list[proc_count].start()
+        proc_count += 1
+        # Join processes if the maximum number of processes are
+        # reached or the end of the loop is reached
+        if proc_count == nprocs or proc_count == num_rows:
+            proc_count = 0
+            exitcodes = 0
+            for proc in proc_list:
+                proc.join()
+                exitcodes += proc.exitcode
+            if exitcodes != 0:
+                dbif.close()
+                grass.fatal(_("Error while computation"))
+            # Empty process list
+            proc_list = []
+        # Store the new maps
+        new_maps[row["id"]] = new_map
+    grass.percent(0, num_rows, 1)
+    # Insert the new space time dataset
+            new_sp.delete(dbif)
+            new_sp = sp.get_new_instance(out_id)
+    temporal_type, semantic_type, title, description = sp.get_initial_values()
+    new_sp.set_initial_values(
+        temporal_type, semantic_type, title, description)
+    new_sp.insert(dbif)
+    # collect empty maps to remove them
+    empty_maps = []
+    # Register the maps in the database
+    count = 0
+    for row in rows:
+        count += 1
+        # Register the new maps
+        if row["id"] in new_maps:
+            new_map = new_maps[row["id"]]
+            # Read the raster map data
+            new_map.load()
+            # In case of a empty map continue, do not register empty maps
+            if new_map.metadata.get_min() is None and \
+                new_map.metadata.get_max() is None:
+                if not register_null:
+                    empty_maps.append(new_map)
+                    continue
+            old_map = sp.get_new_map_instance(row["id"])
+            old_map.select(dbif)
+            # Set the time stamp
+            if old_map.is_time_absolute():
+                start, end, tz = old_map.get_absolute_time()
+                new_map.set_absolute_time(start, end, tz)
+            else:
+                start, end, unit = old_map.get_relative_time()
+                new_map.set_relative_time(start, end, unit)
+            # Insert map in temporal database
+            new_map.insert(dbif)
+            new_sp.register_map(new_map, dbif)
+    # Update the spatio-temporal extent and the metadata table entries
+    new_sp.update_from_registered_maps(dbif)
+    grass.percent(num_rows, num_rows, 1)
+    # Remove empty maps
+    if len(empty_maps) > 0:
+        names = ""
+        count = 0
+        for map in empty_maps:
+            if count == 0:
+                names += "%s" % (map.get_name())
+            else:
+                names += ",%s" % (map.get_name())
+            count += 1
+        grass.run_command("g.remove", rast=names, quiet=True)
+    dbif.close()
+def run_neighbors(input, output, method, size):
+    """Helper function to run r.neighbors in parallel"""
+    return grass.run_command("r.neighbors", input=input, output=output,
+                            method=method, size=size, overwrite=grass.overwrite(),
+                            quiet=True)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
--- grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh	                        (rev 0)
+++ grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh	2013-03-20 18:11:45 UTC (rev 55471)
@@ -0,0 +1,37 @@
+#!/bin/sh
+# Space time raster dataset neighborhood operations
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 -p
+# Generate data
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i --o type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+# The first @test
+t.rast.neighbors --o input=precip_abs1 output=precip_abs2 base=prec_avg \
+    size=3 method=average nprocs=1
+t.info type=strds input=precip_abs2
+    size=5 method=average nprocs=2
+    size=7 method=average nprocs=3
+    size=7 method=max nprocs=3
+    size=7 method=min nprocs=3
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1,precip_abs2
Property changes on: grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
