[GRASS-SVN] r55485 - grass/trunk
svn_grass at osgeo.org
Thu Mar 21 13:33:37 PDT 2013
Author: mmetz
Date: 2013-03-21 13:33:36 -0700 (Thu, 21 Mar 2013)
New Revision: 55485
grass/trunk/aclocal.m4
fix remove unused variable, towards netbsd support
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2013-03-21 19:50:11 UTC (rev 55484)
+++ grass/trunk/aclocal.m4 2013-03-21 20:33:36 UTC (rev 55485)
@@ -479,6 +479,8 @@
SHLIB_LD=""
STLIB_LD='${AR} cr'
STLIB_SUFFIX='.a'
+ GRASS_TRIM_DOTS='`echo ${LIB_VER} | tr -d .`'
+ GRASS_LIB_VERSIONS_OK=ok
LDFLAGS=""
LD_SEARCH_FLAGS=""
LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
@@ -567,6 +569,24 @@
# AC_DEFINE(_REENTRANT)
# AC_DEFINE(_POSIX_PTHREAD_SEMANTICS)
+ *-netbsd*)
+ # NetBSD has ELF.
+ SHLIB_CFLAGS="-fPIC"
+ SHLIB_LD="ld -Bshareable -x"
+ SHLIB_LD_LIBS="${LIBS}"
+ LDFLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -export-dynamic'
+ SHLIB_LD_FLAGS='-rpath ${LIB_RUNTIME_DIR} -export-dynamic'
+ LD_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR} -rpath ${LIB_RUNTIME_DIR}'
+ # NetBSD doesn't handle version numbers with dots.
+ STLIB_SUFFIX='${GRASS_TRIM_DOTS}.a'
+ SHLIB_SUFFIX='${GRASS_TRIM_DOTS}.so',
+ GRASS_LIB_VERSIONS_OK=nodots
+ # TODO: add optional pthread support with any combination of:
+ # CFLAGS="$CFLAGS -pthread"
+ # LDFLAGS="$LDFLAGS -lpthread"
+ # AC_DEFINE(_REENTRANT)
+ # AC_DEFINE(_POSIX_PTHREAD_SEMANTICS)
*aix*)
# NOTE: do we need to support aix < 6 ?
LIBS="$LIBS -lc"
@@ -577,24 +597,6 @@
LD_LIBRARY_PATH_VAR="LIBPATH"
GRASS_NEEDS_EXP_FILE=1
GRASS_EXPORT_FILE_SUFFIX='${LIB_VER}.exp'
- # On AIX <=v4 systems, libbsd.a has to be linked in to support
- # non-blocking file IO. This library has to be linked in after
- # the MATH_LIBS or it breaks the pow() function. The way to
- # insure proper sequencing, is to add it to the tail of MATH_LIBS.
- # This library also supplies gettimeofday.
- # AIX does not have a timezone field in struct tm. When the AIX
- # bsd library is used, the timezone global and the gettimeofday
- # methods are to be avoided for timezone deduction instead, we
- # deduce the timezone by comparing the localtime result on a
- # known GMT value.
- AC_CHECK_LIB(bsd, gettimeofday, libbsd=yes, libbsd=no)
- if test $libbsd = yes; then
- MATH_LIBS="$MATH_LIBS -lbsd"
- AC_DEFINE(USE_DELTA_FOR_TZ)
- fi
AC_MSG_ERROR([***Unknown platform: $host***])
