[GRASS-SVN] r55487 - grass/trunk
    svn_grass at osgeo.org
    Fri Mar 22 04:25:46 PDT 2013
Author: mmetz
Date: 2013-03-22 04:25:46 -0700 (Fri, 22 Mar 2013)
New Revision: 55487
   grass/trunk/aclocal.m4
   grass/trunk/configure
add support for netbsd
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2013-03-22 10:27:21 UTC (rev 55486)
+++ grass/trunk/aclocal.m4	2013-03-22 11:25:46 UTC (rev 55487)
@@ -572,15 +572,18 @@
 	*-netbsd*)
 	    # NetBSD has ELF.
 	    SHLIB_CFLAGS="-fPIC"
-	    SHLIB_LD="ld -Bshareable -x"
+	    SHLIB_LD="${CC} -shared"
 	    SHLIB_LD_LIBS="${LIBS}"
 	    LDFLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -export-dynamic'
-	    SHLIB_LD_FLAGS='-rpath ${LIB_RUNTIME_DIR} -export-dynamic'
-	    LD_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR} -rpath ${LIB_RUNTIME_DIR}'
-	    # NetBSD doesn't handle version numbers with dots.
-	    STLIB_SUFFIX='${GRASS_TRIM_DOTS}.a'
-	    SHLIB_SUFFIX='${GRASS_TRIM_DOTS}.so',
-	    GRASS_LIB_VERSIONS_OK=nodots
+	    SHLIB_LD_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -export-dynamic'
+	    LD_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -L${LIB_RUNTIME_DIR}'
+	    # some older NetBSD versions do not handle version numbers with dots.
+	    #STLIB_SUFFIX='${GRASS_TRIM_DOTS}.a'
+	    #SHLIB_SUFFIX='${GRASS_TRIM_DOTS}.so'
+	    #GRASS_LIB_VERSIONS_OK=nodots
+	    # NetBSD 6 does handle version numbers with dots.
+	    STLIB_SUFFIX=".a"
+	    SHLIB_SUFFIX=".so"
 	    # TODO: add optional pthread support with any combination of:
 	    # CFLAGS="$CFLAGS -pthread"
 	    # LDFLAGS="$LDFLAGS -lpthread"
Modified: grass/trunk/configure
--- grass/trunk/configure	2013-03-22 10:27:21 UTC (rev 55486)
+++ grass/trunk/configure	2013-03-22 11:25:46 UTC (rev 55487)
@@ -1477,6 +1477,8 @@
     SHLIB_LD=""
     STLIB_LD='${AR} cr'
     STLIB_SUFFIX='.a'
+    GRASS_TRIM_DOTS='`echo ${LIB_VER} | tr -d .`'
+    GRASS_LIB_VERSIONS_OK=ok
     LDFLAGS=""
     LD_SEARCH_FLAGS=""
     LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
@@ -1577,6 +1579,27 @@
 	    # AC_DEFINE(_REENTRANT)
 	    # AC_DEFINE(_POSIX_PTHREAD_SEMANTICS)
+	*-netbsd*)
+	    # NetBSD has ELF.
+	    SHLIB_CFLAGS="-fPIC"
+	    SHLIB_LD_LIBS="${LIBS}"
+	    LDFLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -export-dynamic'
+	    STLIB_SUFFIX=".a"
+	    # TODO: add optional pthread support with any combination of:
+	    # CFLAGS="$CFLAGS -pthread"
+	    # LDFLAGS="$LDFLAGS -lpthread"
+	    # AC_DEFINE(_REENTRANT)
+	    # AC_DEFINE(_POSIX_PTHREAD_SEMANTICS)
 	*aix*)
 		# NOTE: do we need to support aix < 6 ?
 	    LIBS="$LIBS -lc"
@@ -1587,64 +1610,6 @@
 	    LD_LIBRARY_PATH_VAR="LIBPATH"
 	    GRASS_NEEDS_EXP_FILE=1
 	    GRASS_EXPORT_FILE_SUFFIX='${LIB_VER}.exp'
-	    # On AIX <=v4 systems, libbsd.a has to be linked in to support
-	    # non-blocking file IO.  This library has to be linked in after
-	    # the MATH_LIBS or it breaks the pow() function.  The way to
-	    # insure proper sequencing, is to add it to the tail of MATH_LIBS.
-	    # This library also supplies gettimeofday.
-	    # AIX does not have a timezone field in struct tm. When the AIX
-	    # bsd library is used, the timezone global and the gettimeofday
-	    # methods are to be avoided for timezone deduction instead, we
-	    # deduce the timezone by comparing the localtime result on a
-	    # known GMT value.
-	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1605: checking for gettimeofday in -lbsd" >&5
-ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lbsd  $LIBS"
-cat > conftest.$ac_ext <<EOF
-#line 1611 "configure"
-#include "confdefs.h"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char gettimeofday();
-int main() {
-gettimeofday()
-; return 0; }
-EOF
-if { (eval echo configure:1622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-  libbsd=yes
-else
-  echo "$ac_t""no" 1>&6
-libbsd=no
-fi
-	    if test $libbsd = yes; then
-	    	MATH_LIBS="$MATH_LIBS -lbsd"
-	    	cat >> confdefs.h <<\EOF
-#define USE_DELTA_FOR_TZ 1
-EOF
-	    fi
             { echo "configure: error: ***Unknown platform: $host***" 1>&2; exit 1; }
@@ -2329,7 +2294,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2333: checking for additional include dirs" >&5
+echo "configure:2298: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2352,7 +2317,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2356: checking for additional library dirs" >&5
+echo "configure:2321: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2386,7 +2351,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2390: checking for a BSD compatible install" >&5
+echo "configure:2355: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2439,7 +2404,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2443: checking for $ac_word" >&5
+echo "configure:2408: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2470,13 +2435,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2474: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2439: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 2480 "configure"
+#line 2445 "configure"
@@ -2487,7 +2452,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2512,7 +2477,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2516: checking for $ac_word" >&5
+echo "configure:2481: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2552,7 +2517,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2556: checking for $ac_word" >&5
+echo "configure:2521: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2583,7 +2548,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2587: checking for $ac_word" >&5
+echo "configure:2552: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2621,7 +2586,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2625: checking for $ac_word" >&5
+echo "configure:2590: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2650,7 +2615,7 @@
-echo "configure:2654: checking for $ac_word" >&5
+echo "configure:2619: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2681,7 +2646,7 @@
-echo "configure:2685: checking for $ac_word" >&5
+echo "configure:2650: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2710,7 +2675,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2714: checking for $ac_word" >&5
+echo "configure:2679: checking for $ac_word" >&5
 case "$PERL" in
@@ -2741,7 +2706,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2745: checking how to run the C preprocessor" >&5
+echo "configure:2710: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2754,13 +2719,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2758 "configure"
+#line 2723 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2764: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2729: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2771,13 +2736,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2775 "configure"
+#line 2740 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2781: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2788,13 +2753,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2792 "configure"
+#line 2757 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2818,10 +2783,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2822: checking for ANSI C header files" >&5
+echo "configure:2787: checking for ANSI C header files" >&5
-#line 2825 "configure"
+#line 2790 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2829,7 +2794,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2833: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2846,7 +2811,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2850 "configure"
+#line 2815 "configure"
 #include <string.h>
 EOF
@@ -2864,7 +2829,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2868 "configure"
+#line 2833 "configure"
 #include <stdlib.h>
 EOF
@@ -2885,7 +2850,7 @@
 else
-#line 2889 "configure"
+#line 2854 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2896,7 +2861,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2923,15 +2888,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2927: checking for $ac_hdr" >&5
+echo "configure:2892: checking for $ac_hdr" >&5
-#line 2930 "configure"
+#line 2895 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2960,15 +2925,15 @@
 do
-echo "configure:2964: checking for $ac_hdr" >&5
+echo "configure:2929: checking for $ac_hdr" >&5
-#line 2967 "configure"
+#line 2932 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2997,15 +2962,15 @@
 do
-echo "configure:3001: checking for $ac_hdr" >&5
+echo "configure:2966: checking for $ac_hdr" >&5
-#line 3004 "configure"
+#line 2969 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3034,15 +2999,15 @@
 do
-echo "configure:3038: checking for $ac_hdr" >&5
+echo "configure:3003: checking for $ac_hdr" >&5
-#line 3041 "configure"
+#line 3006 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3071,15 +3036,15 @@
 do
-echo "configure:3075: checking for $ac_hdr" >&5
+echo "configure:3040: checking for $ac_hdr" >&5
-#line 3078 "configure"
+#line 3043 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3105,10 +3070,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3109: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3074: checking whether time.h and sys/time.h may both be included" >&5
-#line 3112 "configure"
+#line 3077 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3117,7 +3082,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3121: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3086: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3137,10 +3102,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3141: checking for off_t" >&5
+echo "configure:3106: checking for off_t" >&5
-#line 3144 "configure"
+#line 3109 "configure"
 #if STDC_HEADERS
@@ -3167,10 +3132,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3171: checking for uid_t in sys/types.h" >&5
+echo "configure:3136: checking for uid_t in sys/types.h" >&5
-#line 3174 "configure"
+#line 3139 "configure"
 EOF
@@ -3198,10 +3163,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3202: checking return type of signal handlers" >&5
+echo "configure:3167: checking return type of signal handlers" >&5
-#line 3205 "configure"
+#line 3170 "configure"
 #include <signal.h>
@@ -3218,7 +3183,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3222: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3187: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3236,10 +3201,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3240: checking for Cygwin environment" >&5
+echo "configure:3205: checking for Cygwin environment" >&5
-#line 3243 "configure"
+#line 3208 "configure"
 int main() {
@@ -3250,7 +3215,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3254: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3219: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3268,10 +3233,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3272: checking for $ac_func" >&5
+echo "configure:3237: checking for $ac_func" >&5
-#line 3275 "configure"
+#line 3240 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3294,7 +3259,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3320,10 +3285,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3324: checking for $ac_func" >&5
+echo "configure:3289: checking for $ac_func" >&5
-#line 3327 "configure"
+#line 3292 "configure"
@@ -3346,7 +3311,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3372,10 +3337,10 @@
 for ac_func in drand48
 do
-echo "configure:3376: checking for $ac_func" >&5
+echo "configure:3341: checking for $ac_func" >&5
-#line 3379 "configure"
+#line 3344 "configure"
@@ -3398,7 +3363,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3424,10 +3389,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3428: checking for $ac_func" >&5
+echo "configure:3393: checking for $ac_func" >&5
-#line 3431 "configure"
+#line 3396 "configure"
@@ -3450,7 +3415,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3476,10 +3441,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3480: checking for $ac_func" >&5
+echo "configure:3445: checking for $ac_func" >&5
-#line 3483 "configure"
+#line 3448 "configure"
@@ -3502,7 +3467,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3527,13 +3492,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3531: checking whether setpgrp takes no argument" >&5
+echo "configure:3496: checking whether setpgrp takes no argument" >&5
 if test "$cross_compiling" = yes; then
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3537 "configure"
+#line 3502 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3553,7 +3518,7 @@
 EOF
-if { (eval echo configure:3557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3581,16 +3546,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3585: checking for long long int" >&5
+echo "configure:3550: checking for long long int" >&5
-#line 3587 "configure"
+#line 3552 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3594: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3559: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -3610,7 +3575,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3614: checking for W11" >&5
+echo "configure:3579: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3638,7 +3603,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3642: checking for X" >&5
+echo "configure:3607: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3698,12 +3663,12 @@
   # First, try using that file with no special directory specified.
-#line 3702 "configure"
+#line 3667 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3772,14 +3737,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3776 "configure"
+#line 3741 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 # We can link X programs with no special library path.
@@ -3884,17 +3849,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3888: checking whether -R must be followed by a space" >&5
+echo "configure:3853: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3891 "configure"
+#line 3856 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3910,14 +3875,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3914 "configure"
+#line 3879 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3949,13 +3914,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3953: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3918: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3959 "configure"
+#line 3924 "configure"
@@ -3966,7 +3931,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3987,13 +3952,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3991: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3956: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3997 "configure"
+#line 3962 "configure"
@@ -4004,7 +3969,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4032,10 +3997,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4036: checking for gethostbyname" >&5
+echo "configure:4001: checking for gethostbyname" >&5
-#line 4039 "configure"
+#line 4004 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -4058,7 +4023,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4078,13 +4043,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4082: checking for gethostbyname in -lnsl" >&5
+echo "configure:4047: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4088 "configure"
+#line 4053 "configure"
@@ -4095,7 +4060,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4124,10 +4089,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4128: checking for connect" >&5
+echo "configure:4093: checking for connect" >&5
-#line 4131 "configure"
+#line 4096 "configure"
     which can conflict with char connect(); below.  */
@@ -4150,7 +4115,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4170,13 +4135,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4174: checking for connect in -lsocket" >&5
+echo "configure:4139: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4180 "configure"
+#line 4145 "configure"
@@ -4187,7 +4152,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4210,10 +4175,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4214: checking for remove" >&5
+echo "configure:4179: checking for remove" >&5
-#line 4217 "configure"
+#line 4182 "configure"
     which can conflict with char remove(); below.  */
@@ -4236,7 +4201,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4256,13 +4221,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4260: checking for remove in -lposix" >&5
+echo "configure:4225: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4266 "configure"
+#line 4231 "configure"
@@ -4273,7 +4238,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4296,10 +4261,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4300: checking for shmat" >&5
+echo "configure:4265: checking for shmat" >&5
-#line 4303 "configure"
+#line 4268 "configure"
     which can conflict with char shmat(); below.  */
@@ -4322,7 +4287,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4342,13 +4307,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4346: checking for shmat in -lipc" >&5
+echo "configure:4311: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4352 "configure"
+#line 4317 "configure"
@@ -4359,7 +4324,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4391,13 +4356,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4395: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4360: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4401 "configure"
+#line 4366 "configure"
@@ -4408,7 +4373,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4448,12 +4413,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4452: checking for library containing cuserid" >&5
+echo "configure:4417: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4457 "configure"
+#line 4422 "configure"
@@ -4464,7 +4429,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4475,7 +4440,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4479 "configure"
+#line 4444 "configure"
@@ -4486,7 +4451,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4512,10 +4477,10 @@
 for ac_func in asprintf
 do
-echo "configure:4516: checking for $ac_func" >&5
+echo "configure:4481: checking for $ac_func" >&5
-#line 4519 "configure"
+#line 4484 "configure"
@@ -4538,7 +4503,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4565,10 +4530,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4569: checking for atan" >&5
+echo "configure:4534: checking for atan" >&5
-#line 4572 "configure"
+#line 4537 "configure"
     which can conflict with char atan(); below.  */
@@ -4591,7 +4556,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4609,13 +4574,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4613: checking for atan in -lm" >&5
+echo "configure:4578: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4619 "configure"
+#line 4584 "configure"
@@ -4626,7 +4591,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4653,10 +4618,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4657: checking for dlsym" >&5
+echo "configure:4622: checking for dlsym" >&5
-#line 4660 "configure"
+#line 4625 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4679,7 +4644,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4697,13 +4662,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4701: checking for dlsym in -ldl" >&5
+echo "configure:4666: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4707 "configure"
+#line 4672 "configure"
@@ -4714,7 +4679,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4741,10 +4706,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4745: checking for iconv" >&5
+echo "configure:4710: checking for iconv" >&5
-#line 4748 "configure"
+#line 4713 "configure"
     which can conflict with char iconv(); below.  */
@@ -4767,7 +4732,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4785,13 +4750,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4789: checking for iconv in -liconv" >&5
+echo "configure:4754: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4795 "configure"
+#line 4760 "configure"
@@ -4802,7 +4767,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4821,13 +4786,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4825: checking for iconv in -lgiconv" >&5
+echo "configure:4790: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4831 "configure"
+#line 4796 "configure"
@@ -4838,7 +4803,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4857,10 +4822,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4861: checking for libiconv" >&5
+echo "configure:4826: checking for libiconv" >&5
-#line 4864 "configure"
+#line 4829 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4883,7 +4848,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4901,13 +4866,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4905: checking for libiconv in -liconv" >&5
+echo "configure:4870: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4911 "configure"
+#line 4876 "configure"
@@ -4918,7 +4883,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4937,13 +4902,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4941: checking for libiconv in -lgiconv" >&5
+echo "configure:4906: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4947 "configure"
+#line 4912 "configure"
@@ -4954,7 +4919,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4991,10 +4956,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4995: checking for socket" >&5
+echo "configure:4960: checking for socket" >&5
-#line 4998 "configure"
+#line 4963 "configure"
     which can conflict with char socket(); below.  */
@@ -5017,7 +4982,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5035,13 +5000,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5039: checking for socket in -lsocket" >&5
+echo "configure:5004: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5045 "configure"
+#line 5010 "configure"
@@ -5052,7 +5017,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5100,7 +5065,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5104: checking for location of zlib includes" >&5
+echo "configure:5069: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5126,15 +5091,15 @@
 do
-echo "configure:5130: checking for $ac_hdr" >&5
+echo "configure:5095: checking for $ac_hdr" >&5
-#line 5133 "configure"
+#line 5098 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5103: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5168,7 +5133,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5172: checking for location of zlib library" >&5
+echo "configure:5137: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5193,13 +5158,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5197: checking for deflate in -lz" >&5
+echo "configure:5162: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5203 "configure"
+#line 5168 "configure"
@@ -5210,7 +5175,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5258,7 +5223,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5262: checking for location of External PROJ.4 includes" >&5
+echo "configure:5227: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5284,15 +5249,15 @@
 do
-echo "configure:5288: checking for $ac_hdr" >&5
+echo "configure:5253: checking for $ac_hdr" >&5
-#line 5291 "configure"
+#line 5256 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5329,7 +5294,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5333: checking External PROJ.4 version" >&5
+echo "configure:5298: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5337,7 +5302,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 5341 "configure"
+#line 5306 "configure"
 #include <stdio.h>
@@ -5349,7 +5314,7 @@
 EOF
-if { (eval echo configure:5353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5374,7 +5339,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5378: checking for location of External PROJ.4 library" >&5
+echo "configure:5343: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5399,13 +5364,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5403: checking for pj_get_def in -lproj" >&5
+echo "configure:5368: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5409 "configure"
+#line 5374 "configure"
@@ -5416,7 +5381,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5450,7 +5415,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5454: checking for location of External PROJ.4 data files" >&5
+echo "configure:5419: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5474,14 +5439,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5478: checking for epsg" >&5
+echo "configure:5443: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5485: checking for $PROJSHARE/epsg" >&5
+echo "configure:5450: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5513,7 +5478,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5517: checking for $ac_word" >&5
+echo "configure:5482: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5553,7 +5518,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5557: checking whether to use regex" >&5
+echo "configure:5522: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5573,7 +5538,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5577: checking for location of regex includes" >&5
+echo "configure:5542: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5599,15 +5564,15 @@
 do
-echo "configure:5603: checking for $ac_hdr" >&5
+echo "configure:5568: checking for $ac_hdr" >&5
-#line 5606 "configure"
+#line 5571 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5611: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5641,7 +5606,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5645: checking for location of regex library" >&5
+echo "configure:5610: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5666,10 +5631,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5670: checking for regcomp" >&5
+echo "configure:5635: checking for regcomp" >&5
-#line 5673 "configure"
+#line 5638 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5692,7 +5657,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5719,13 +5684,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5723: checking for regcomp in -lregex" >&5
+echo "configure:5688: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5729 "configure"
+#line 5694 "configure"
@@ -5736,7 +5701,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5786,7 +5751,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5790: checking whether to use Readline" >&5
+echo "configure:5755: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5807,7 +5772,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5811: checking for location of Readline includes" >&5
+echo "configure:5776: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5833,15 +5798,15 @@
 do
-echo "configure:5837: checking for $ac_hdr" >&5
+echo "configure:5802: checking for $ac_hdr" >&5
-#line 5840 "configure"
+#line 5805 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5845: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5877,15 +5842,15 @@
 do
-echo "configure:5881: checking for $ac_hdr" >&5
+echo "configure:5846: checking for $ac_hdr" >&5
-#line 5884 "configure"
+#line 5849 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5919,7 +5884,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5923: checking for location of Readline library" >&5
+echo "configure:5888: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5944,13 +5909,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5948: checking for readline in -lreadline" >&5
+echo "configure:5913: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 5954 "configure"
+#line 5919 "configure"
@@ -5961,7 +5926,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:5965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5996,13 +5961,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6000: checking for add_history in -lhistory" >&5
+echo "configure:5965: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6006 "configure"
+#line 5971 "configure"
@@ -6013,7 +5978,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6055,7 +6020,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6059: checking whether to use GDAL" >&5
+echo "configure:6024: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6073,7 +6038,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6077: checking for $ac_word" >&5
+echo "configure:6042: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6128,14 +6093,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6132 "configure"
+#line 6097 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6144,14 +6109,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6148 "configure"
+#line 6113 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6183,7 +6148,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6187: checking whether to use libLAS" >&5
+echo "configure:6152: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6200,7 +6165,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6204: checking for $ac_word" >&5
+echo "configure:6169: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6248,14 +6213,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6252 "configure"
+#line 6217 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6263,14 +6228,14 @@
   rm -rf conftest*
-#line 6267 "configure"
+#line 6232 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6302,7 +6267,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6306: checking whether to use NetCDF" >&5
+echo "configure:6271: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6319,7 +6284,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6323: checking for $ac_word" >&5
+echo "configure:6288: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6366,14 +6331,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6370 "configure"
+#line 6335 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6381,14 +6346,14 @@
   rm -rf conftest*
-#line 6385 "configure"
+#line 6350 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6419,7 +6384,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6423: checking whether to use GEOS" >&5
+echo "configure:6388: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6437,7 +6402,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6441: checking for $ac_word" >&5
+echo "configure:6406: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6485,15 +6450,15 @@
 do
-echo "configure:6489: checking for $ac_hdr" >&5
+echo "configure:6454: checking for $ac_hdr" >&5
-#line 6492 "configure"
+#line 6457 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6532,13 +6497,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6536: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6501: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6542 "configure"
+#line 6507 "configure"
@@ -6549,7 +6514,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6593,7 +6558,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6597: checking whether to use TIFF" >&5
+echo "configure:6562: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6613,7 +6578,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6617: checking for location of TIFF includes" >&5
+echo "configure:6582: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6639,15 +6604,15 @@
 do
-echo "configure:6643: checking for $ac_hdr" >&5
+echo "configure:6608: checking for $ac_hdr" >&5
-#line 6646 "configure"
+#line 6611 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6681,7 +6646,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6685: checking for location of TIFF library" >&5
+echo "configure:6650: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6712,13 +6677,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6716: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6681: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6722 "configure"
+#line 6687 "configure"
@@ -6729,7 +6694,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6748,13 +6713,13 @@
-echo "configure:6752: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6717: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6758 "configure"
+#line 6723 "configure"
@@ -6765,7 +6730,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6784,13 +6749,13 @@
-echo "configure:6788: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6753: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6794 "configure"
+#line 6759 "configure"
@@ -6801,7 +6766,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6820,13 +6785,13 @@
-echo "configure:6824: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6789: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6830 "configure"
+#line 6795 "configure"
@@ -6837,7 +6802,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6856,13 +6821,13 @@
-echo "configure:6860: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6825: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6866 "configure"
+#line 6831 "configure"
@@ -6873,7 +6838,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6892,13 +6857,13 @@
-echo "configure:6896: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6861: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6902 "configure"
+#line 6867 "configure"
@@ -6909,7 +6874,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6928,13 +6893,13 @@
-echo "configure:6932: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6897: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6938 "configure"
+#line 6903 "configure"
@@ -6945,7 +6910,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6964,13 +6929,13 @@
-echo "configure:6968: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6933: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6974 "configure"
+#line 6939 "configure"
@@ -6981,7 +6946,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7079,7 +7044,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7083: checking whether to use PNG" >&5
+echo "configure:7048: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7098,7 +7063,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7102: checking for location of PNG includes" >&5
+echo "configure:7067: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7124,15 +7089,15 @@
 do
-echo "configure:7128: checking for $ac_hdr" >&5
+echo "configure:7093: checking for $ac_hdr" >&5
-#line 7131 "configure"
+#line 7096 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7136: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7166,7 +7131,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7170: checking for location of PNG library" >&5
+echo "configure:7135: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7191,13 +7156,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7195: checking for png_read_image in -lpng" >&5
+echo "configure:7160: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7201 "configure"
+#line 7166 "configure"
@@ -7208,7 +7173,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7250,7 +7215,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7254: checking whether to use PostgreSQL" >&5
+echo "configure:7219: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7277,7 +7242,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7281: checking for location of PostgreSQL includes" >&5
+echo "configure:7246: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7303,15 +7268,15 @@
 do
-echo "configure:7307: checking for $ac_hdr" >&5
+echo "configure:7272: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 7310 "configure"
+#line 7275 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7349,7 +7314,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7353: checking for location of PostgreSQL library" >&5
+echo "configure:7318: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7378,13 +7343,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7382: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7347: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpq  $LIBS"
-#line 7388 "configure"
+#line 7353 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7395,7 +7360,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7414,13 +7379,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7418: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7383: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7424 "configure"
+#line 7389 "configure"
@@ -7431,7 +7396,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7450,13 +7415,13 @@
-echo "configure:7454: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7419: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7460 "configure"
+#line 7425 "configure"
@@ -7467,7 +7432,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7486,13 +7451,13 @@
-echo "configure:7490: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7455: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7496 "configure"
+#line 7461 "configure"
@@ -7503,7 +7468,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7560,13 +7525,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7564: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7529: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7570 "configure"
+#line 7535 "configure"
@@ -7577,7 +7542,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7599,13 +7564,13 @@
-echo "configure:7603: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7568: checking for PQcmdTuples in -lpq" >&5
-#line 7609 "configure"
+#line 7574 "configure"
@@ -7616,7 +7581,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7659,7 +7624,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7663: checking whether to use MySQL" >&5
+echo "configure:7628: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7679,7 +7644,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7683: checking for location of MySQL includes" >&5
+echo "configure:7648: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7705,15 +7670,15 @@
 do
-echo "configure:7709: checking for $ac_hdr" >&5
+echo "configure:7674: checking for $ac_hdr" >&5
-#line 7712 "configure"
+#line 7677 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7717: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7750,7 +7715,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7754: checking for location of MySQL library" >&5
+echo "configure:7719: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7781,13 +7746,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7785: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7750: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7791 "configure"
+#line 7756 "configure"
@@ -7798,7 +7763,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7817,13 +7782,13 @@
-echo "configure:7821: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7786: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7827 "configure"
+#line 7792 "configure"
@@ -7834,7 +7799,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7853,13 +7818,13 @@
-echo "configure:7857: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7822: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7863 "configure"
+#line 7828 "configure"
@@ -7870,7 +7835,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7889,13 +7854,13 @@
-echo "configure:7893: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7858: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7899 "configure"
+#line 7864 "configure"
@@ -7906,7 +7871,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7925,13 +7890,13 @@
-echo "configure:7929: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7894: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7935 "configure"
+#line 7900 "configure"
@@ -7942,7 +7907,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7961,13 +7926,13 @@
-echo "configure:7965: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7930: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7971 "configure"
+#line 7936 "configure"
@@ -7978,7 +7943,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7997,13 +7962,13 @@
-echo "configure:8001: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7966: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8007 "configure"
+#line 7972 "configure"
@@ -8014,7 +7979,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8033,13 +7998,13 @@
-echo "configure:8037: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8002: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8043 "configure"
+#line 8008 "configure"
@@ -8050,7 +8015,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8140,7 +8105,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8144: checking for $ac_word" >&5
+echo "configure:8109: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8189,10 +8154,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8193: checking for mysql_server_init" >&5
+echo "configure:8158: checking for mysql_server_init" >&5
-#line 8196 "configure"
+#line 8161 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -8218,7 +8183,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8270,7 +8235,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8274: checking whether to use SQLite" >&5
+echo "configure:8239: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8290,7 +8255,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8294: checking for location of SQLite includes" >&5
+echo "configure:8259: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8316,15 +8281,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8320: checking for $ac_hdr" >&5
+echo "configure:8285: checking for $ac_hdr" >&5
-#line 8323 "configure"
+#line 8288 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8367,7 +8332,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8371: checking for location of SQLite library" >&5
+echo "configure:8336: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8396,13 +8361,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8400: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8365: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8406 "configure"
+#line 8371 "configure"
@@ -8413,7 +8378,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8432,13 +8397,13 @@
-echo "configure:8436: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8401: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8442 "configure"
+#line 8407 "configure"
@@ -8449,7 +8414,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8468,13 +8433,13 @@
-echo "configure:8472: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8437: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8478 "configure"
+#line 8443 "configure"
@@ -8485,7 +8450,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8504,13 +8469,13 @@
-echo "configure:8508: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8473: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8514 "configure"
+#line 8479 "configure"
@@ -8521,7 +8486,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8590,7 +8555,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8594: checking whether to use FFMPEG" >&5
+echo "configure:8559: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8610,7 +8575,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8614: checking for location of FFMPEG includes" >&5
+echo "configure:8579: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8636,15 +8601,15 @@
 do
-echo "configure:8640: checking for $ac_hdr" >&5
+echo "configure:8605: checking for $ac_hdr" >&5
-#line 8643 "configure"
+#line 8608 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8648: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8680,15 +8645,15 @@
 do
-echo "configure:8684: checking for $ac_hdr" >&5
+echo "configure:8649: checking for $ac_hdr" >&5
-#line 8687 "configure"
+#line 8652 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8657: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8724,15 +8689,15 @@
 do
-echo "configure:8728: checking for $ac_hdr" >&5
+echo "configure:8693: checking for $ac_hdr" >&5
-#line 8731 "configure"
+#line 8696 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8701: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8775,7 +8740,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8779: checking for location of FFMPEG library" >&5
+echo "configure:8744: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8802,13 +8767,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8806: checking for av_free in -lavutil" >&5
+echo "configure:8771: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 8812 "configure"
+#line 8777 "configure"
@@ -8819,7 +8784,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8838,13 +8803,13 @@
-echo "configure:8842: checking for av_free in -lavutil" >&5
+echo "configure:8807: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 8848 "configure"
+#line 8813 "configure"
@@ -8855,7 +8820,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8900,13 +8865,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8904: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8869: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8910 "configure"
+#line 8875 "configure"
@@ -8917,7 +8882,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8936,13 +8901,13 @@
-echo "configure:8940: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8905: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8946 "configure"
+#line 8911 "configure"
@@ -8953,7 +8918,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8998,13 +8963,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9002: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8967: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9008 "configure"
+#line 8973 "configure"
@@ -9015,7 +8980,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:9019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9034,13 +8999,13 @@
-echo "configure:9038: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9003: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9044 "configure"
+#line 9009 "configure"
@@ -9051,7 +9016,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9110,7 +9075,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9114: checking whether to use OpenGL" >&5
+echo "configure:9079: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9144,7 +9109,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9148: checking for location of OpenGL includes" >&5
+echo "configure:9113: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9170,15 +9135,15 @@
 do
-echo "configure:9174: checking for $ac_hdr" >&5
+echo "configure:9139: checking for $ac_hdr" >&5
-#line 9177 "configure"
+#line 9142 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9212,7 +9177,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9216: checking for location of OpenGL library" >&5
+echo "configure:9181: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9241,13 +9206,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9245: checking for glBegin in -lGL" >&5
+echo "configure:9210: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9251 "configure"
+#line 9216 "configure"
@@ -9258,7 +9223,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9277,13 +9242,13 @@
-echo "configure:9281: checking for glBegin in -lGL" >&5
+echo "configure:9246: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9287 "configure"
+#line 9252 "configure"
@@ -9294,7 +9259,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9313,13 +9278,13 @@
-echo "configure:9317: checking for glBegin in -lGL" >&5
+echo "configure:9282: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9323 "configure"
+#line 9288 "configure"
@@ -9330,7 +9295,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9349,13 +9314,13 @@
-echo "configure:9353: checking for glBegin in -lGL" >&5
+echo "configure:9318: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9359 "configure"
+#line 9324 "configure"
@@ -9366,7 +9331,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9428,13 +9393,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9432: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9397: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9438 "configure"
+#line 9403 "configure"
@@ -9445,7 +9410,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9464,13 +9429,13 @@
-echo "configure:9468: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9433: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9474 "configure"
+#line 9439 "configure"
@@ -9481,7 +9446,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9528,10 +9493,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9532: checking for glXCreatePbuffer" >&5
+echo "configure:9497: checking for glXCreatePbuffer" >&5
-#line 9535 "configure"
+#line 9500 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9554,7 +9519,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9591,10 +9556,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9595: checking for glXCreateGLXPixmap" >&5
+echo "configure:9560: checking for glXCreateGLXPixmap" >&5
-#line 9598 "configure"
+#line 9563 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9617,7 +9582,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9660,7 +9625,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9664: checking for location of OpenGL framework" >&5
+echo "configure:9629: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9684,15 +9649,15 @@
 do
-echo "configure:9688: checking for $ac_hdr" >&5
+echo "configure:9653: checking for $ac_hdr" >&5
-#line 9691 "configure"
+#line 9656 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9696: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9661: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9728,10 +9693,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9732: checking for glBegin" >&5
+echo "configure:9697: checking for glBegin" >&5
-#line 9735 "configure"
+#line 9700 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9754,7 +9719,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9791,10 +9756,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9795: checking for gluBeginCurve" >&5
+echo "configure:9760: checking for gluBeginCurve" >&5
-#line 9798 "configure"
+#line 9763 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9817,7 +9782,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9865,7 +9830,7 @@
-echo "configure:9869: checking for location of OpenGL includes" >&5
+echo "configure:9834: checking for location of OpenGL includes" >&5
@@ -9891,15 +9856,15 @@
 do
-echo "configure:9895: checking for $ac_hdr" >&5
+echo "configure:9860: checking for $ac_hdr" >&5
-#line 9898 "configure"
+#line 9863 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9868: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9933,7 +9898,7 @@
-echo "configure:9937: checking for location of OpenGL library" >&5
+echo "configure:9902: checking for location of OpenGL library" >&5
@@ -9958,18 +9923,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9962: checking for OpenGL library" >&5
+echo "configure:9927: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9966 "configure"
+#line 9931 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -9993,18 +9958,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9997: checking for GLU library" >&5
+echo "configure:9962: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10001 "configure"
+#line 9966 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10053,7 +10018,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10057: checking whether to use ODBC" >&5
+echo "configure:10022: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -10072,7 +10037,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10076: checking for location of ODBC includes" >&5
+echo "configure:10041: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10098,15 +10063,15 @@
 do
-echo "configure:10102: checking for $ac_hdr" >&5
+echo "configure:10067: checking for $ac_hdr" >&5
-#line 10105 "configure"
+#line 10070 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10140,7 +10105,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10144: checking for location of ODBC library" >&5
+echo "configure:10109: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10165,13 +10130,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10169: checking for SQLConnect in -lodbc" >&5
+echo "configure:10134: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10175 "configure"
+#line 10140 "configure"
@@ -10182,7 +10147,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10207,13 +10172,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10211: checking for SQLConnect in -liodbc" >&5
+echo "configure:10176: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10217 "configure"
+#line 10182 "configure"
@@ -10224,7 +10189,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10249,11 +10214,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10253: checking for ODBC library" >&5
+echo "configure:10218: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10257 "configure"
+#line 10222 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10261,7 +10226,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10310,7 +10275,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10314: checking whether to use FFTW" >&5
+echo "configure:10279: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10329,7 +10294,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10333: checking for location of FFTW includes" >&5
+echo "configure:10298: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10355,15 +10320,15 @@
 do
-echo "configure:10359: checking for $ac_hdr" >&5
+echo "configure:10324: checking for $ac_hdr" >&5
-#line 10362 "configure"
+#line 10327 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10367: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10332: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10391,15 +10356,15 @@
 do
-echo "configure:10395: checking for $ac_hdr" >&5
+echo "configure:10360: checking for $ac_hdr" >&5
-#line 10398 "configure"
+#line 10363 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10368: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10427,15 +10392,15 @@
 do
-echo "configure:10431: checking for $ac_hdr" >&5
+echo "configure:10396: checking for $ac_hdr" >&5
-#line 10434 "configure"
+#line 10399 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10481,7 +10446,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10485: checking for location of FFTW library" >&5
+echo "configure:10450: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10506,13 +10471,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10510: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10475: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10516 "configure"
+#line 10481 "configure"
@@ -10523,7 +10488,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10548,13 +10513,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10552: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10517: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10558 "configure"
+#line 10523 "configure"
@@ -10565,7 +10530,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10590,13 +10555,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10594: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10559: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10600 "configure"
+#line 10565 "configure"
@@ -10607,7 +10572,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10664,7 +10629,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10668: checking whether to use BLAS" >&5
+echo "configure:10633: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10685,7 +10650,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10689: checking for location of BLAS includes" >&5
+echo "configure:10654: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10705,7 +10670,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10709: checking for location of BLAS library" >&5
+echo "configure:10674: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10731,15 +10696,15 @@
 do
-echo "configure:10735: checking for $ac_hdr" >&5
+echo "configure:10700: checking for $ac_hdr" >&5
-#line 10738 "configure"
+#line 10703 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10774,13 +10739,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10778: checking for dnrm2_ in -lblas" >&5
+echo "configure:10743: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10784 "configure"
+#line 10749 "configure"
@@ -10791,7 +10756,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10810,13 +10775,13 @@
-echo "configure:10814: checking for dnrm2_ in -lblas" >&5
+echo "configure:10779: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10820 "configure"
+#line 10785 "configure"
@@ -10827,7 +10792,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10871,13 +10836,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10875: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10840: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10881 "configure"
+#line 10846 "configure"
@@ -10888,7 +10853,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10903,13 +10868,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10907: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10872: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10913 "configure"
+#line 10878 "configure"
@@ -10920,7 +10885,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10935,13 +10900,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10939: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10904: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10945 "configure"
+#line 10910 "configure"
@@ -10952,7 +10917,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10998,16 +10963,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11002: checking for sgemm in $vlib_flags" >&5
+echo "configure:10967: checking for sgemm in $vlib_flags" >&5
-#line 11004 "configure"
+#line 10969 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -11025,13 +10990,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11029: checking for sgemm_ in -lblas" >&5
+echo "configure:10994: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 11035 "configure"
+#line 11000 "configure"
@@ -11042,7 +11007,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11057,13 +11022,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11061: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11026: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 11067 "configure"
+#line 11032 "configure"
@@ -11074,7 +11039,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11089,13 +11054,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11093: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11058: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 11099 "configure"
+#line 11064 "configure"
@@ -11106,7 +11071,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11140,13 +11105,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11144: checking for acosp in -lsunmath" >&5
+echo "configure:11109: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11150 "configure"
+#line 11115 "configure"
@@ -11157,7 +11122,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11172,13 +11137,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11176: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11141: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11182 "configure"
+#line 11147 "configure"
@@ -11189,7 +11154,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11219,13 +11184,13 @@
 # Generic BLAS library
-echo "configure:11223: checking for sgemm_ in -lblas" >&5
+echo "configure:11188: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11229 "configure"
+#line 11194 "configure"
@@ -11236,7 +11201,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11275,7 +11240,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11279: checking whether to use LAPACK" >&5
+echo "configure:11244: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11300,7 +11265,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11304: checking for location of LAPACK includes" >&5
+echo "configure:11269: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11320,7 +11285,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11324: checking for location of LAPACK library" >&5
+echo "configure:11289: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11346,15 +11311,15 @@
 do
-echo "configure:11350: checking for $ac_hdr" >&5
+echo "configure:11315: checking for $ac_hdr" >&5
-#line 11353 "configure"
+#line 11318 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11358: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11323: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11386,10 +11351,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11390: checking for dsegv_" >&5
+echo "configure:11355: checking for dsegv_" >&5
-#line 11393 "configure"
+#line 11358 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11412,7 +11377,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11439,13 +11404,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11443: checking for desgv_ in -llapack" >&5
+echo "configure:11408: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11449 "configure"
+#line 11414 "configure"
@@ -11456,7 +11421,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11488,13 +11453,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11492: checking for dgesv_ in -llapack" >&5
+echo "configure:11457: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11498 "configure"
+#line 11463 "configure"
@@ -11505,7 +11470,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11524,13 +11489,13 @@
-echo "configure:11528: checking for dgesv_ in -llapack" >&5
+echo "configure:11493: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11534 "configure"
+#line 11499 "configure"
@@ -11541,7 +11506,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11597,7 +11562,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11601: checking whether to use Cairo" >&5
+echo "configure:11566: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11629,7 +11594,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11633: checking for location of cairo includes" >&5
+echo "configure:11598: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11655,15 +11620,15 @@
 do
-echo "configure:11659: checking for $ac_hdr" >&5
+echo "configure:11624: checking for $ac_hdr" >&5
-#line 11662 "configure"
+#line 11627 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11699,7 +11664,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11703: checking for location of cairo library" >&5
+echo "configure:11668: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11719,7 +11684,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11723: checking for cairo linking flags" >&5
+echo "configure:11688: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11735,10 +11700,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11739: checking for cairo_create" >&5
+echo "configure:11704: checking for cairo_create" >&5
-#line 11742 "configure"
+#line 11707 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11761,7 +11726,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11795,10 +11760,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11799: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11764: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11802 "configure"
+#line 11767 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11821,7 +11786,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11854,10 +11819,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11858: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11823: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11861 "configure"
+#line 11826 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11880,7 +11845,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11922,7 +11887,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11926: checking whether to use FreeType" >&5
+echo "configure:11891: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11941,7 +11906,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11945: checking for location of FreeType includes" >&5
+echo "configure:11910: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11967,15 +11932,15 @@
 do
-echo "configure:11971: checking for $ac_hdr" >&5
+echo "configure:11936: checking for $ac_hdr" >&5
-#line 11974 "configure"
+#line 11939 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11979: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12009,7 +11974,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12013: checking for location of FreeType library" >&5
+echo "configure:11978: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12034,13 +11999,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12038: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12003: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 12044 "configure"
+#line 12009 "configure"
@@ -12051,7 +12016,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12092,7 +12057,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12096: checking whether to use NLS" >&5
+echo "configure:12061: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12112,10 +12077,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12116: checking for gettext" >&5
+echo "configure:12081: checking for gettext" >&5
-#line 12119 "configure"
+#line 12084 "configure"
     which can conflict with char gettext(); below.  */
@@ -12138,7 +12103,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12156,13 +12121,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12160: checking for gettext in -lintl" >&5
+echo "configure:12125: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12166 "configure"
+#line 12131 "configure"
@@ -12173,7 +12138,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12208,7 +12173,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12212: checking whether to use C++" >&5
+echo "configure:12177: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12224,7 +12189,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:12228: checking for $ac_word" >&5
+echo "configure:12193: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12253,7 +12218,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12257: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12222: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12264,12 +12229,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12268 "configure"
+#line 12233 "configure"
 #include "confdefs.h"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12295,19 +12260,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12299: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12264: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12304: checking whether we are using GNU C++" >&5
+echo "configure:12269: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12311: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12325,7 +12290,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12329: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12294: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12363,7 +12328,7 @@
    'void exit (int);'
 do
   cat > conftest.$ac_ext <<EOF
-#line 12367 "configure"
+#line 12332 "configure"
 #include <stdlib.h>
 $ac_declaration
@@ -12371,7 +12336,7 @@
 exit (42);
 ; return 0; }
 EOF
-if { (eval echo configure:12375: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12340: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -12381,14 +12346,14 @@
 fi
 rm -f conftest*
-#line 12385 "configure"
+#line 12350 "configure"
 $ac_declaration
 int main() {
 exit (42);
 ; return 0; }
 EOF
-if { (eval echo configure:12392: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12357: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   break
 else
@@ -12417,7 +12382,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12421: checking whether to use openDWG" >&5
+echo "configure:12386: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12437,7 +12402,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12441: checking for location of openDGW includes" >&5
+echo "configure:12406: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12463,15 +12428,15 @@
 do
-echo "configure:12467: checking for $ac_hdr" >&5
+echo "configure:12432: checking for $ac_hdr" >&5
-#line 12470 "configure"
+#line 12435 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12475: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12505,7 +12470,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12509: checking for location of openDWG library" >&5
+echo "configure:12474: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12546,7 +12511,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12550: checking whether to use POSIX threads" >&5
+echo "configure:12515: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12566,7 +12531,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12570: checking for location of POSIX threads includes" >&5
+echo "configure:12535: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12592,15 +12557,15 @@
 do
-echo "configure:12596: checking for $ac_hdr" >&5
+echo "configure:12561: checking for $ac_hdr" >&5
-#line 12599 "configure"
+#line 12564 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12604: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12634,7 +12599,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12638: checking for location of POSIX threads library" >&5
+echo "configure:12603: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12659,10 +12624,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12663: checking for pthread_create" >&5
+echo "configure:12628: checking for pthread_create" >&5
-#line 12666 "configure"
+#line 12631 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12685,7 +12650,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12712,13 +12677,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12716: checking for pthread_create in -lpthread" >&5
+echo "configure:12681: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12722 "configure"
+#line 12687 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12729,7 +12694,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12779,7 +12744,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12783: checking whether to use OpenMP" >&5
+echo "configure:12748: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12800,7 +12765,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12804: checking for location of OpenMP includes" >&5
+echo "configure:12769: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12826,15 +12791,15 @@
 do
-echo "configure:12830: checking for $ac_hdr" >&5
+echo "configure:12795: checking for $ac_hdr" >&5
-#line 12833 "configure"
+#line 12798 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12872,7 +12837,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12876: checking for location of OpenMP library" >&5
+echo "configure:12841: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12897,10 +12862,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12901: checking for GOMP_parallel_start" >&5
+echo "configure:12866: checking for GOMP_parallel_start" >&5
-#line 12904 "configure"
+#line 12869 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12923,7 +12888,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12950,13 +12915,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12954: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12919: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12960 "configure"
+#line 12925 "configure"
@@ -12967,7 +12932,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13046,7 +13011,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13050: checking for special C compiler options needed for large files" >&5
+echo "configure:13015: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13054,7 +13019,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13058 "configure"
+#line 13023 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13070,7 +13035,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13074: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13079,7 +13044,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13083 "configure"
+#line 13048 "configure"
@@ -13095,7 +13060,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13099: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13064: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13115,11 +13080,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13119: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13084: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13123 "configure"
+#line 13088 "configure"
@@ -13135,14 +13100,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13139: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13146 "configure"
+#line 13111 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13160,7 +13125,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13164: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13179,11 +13144,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13183: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13148: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13187 "configure"
+#line 13152 "configure"
@@ -13199,14 +13164,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13203: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13168: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13210 "configure"
+#line 13175 "configure"
 #define _LARGE_FILES 1
@@ -13224,7 +13189,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13228: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13243,25 +13208,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13247: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13212: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13251 "configure"
+#line 13216 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13258: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13265 "configure"
+#line 13230 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13270,7 +13235,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13274: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13239: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13291,25 +13256,25 @@
    fi
-echo "configure:13295: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13260: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13299 "configure"
+#line 13264 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13306: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13271: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13313 "configure"
+#line 13278 "configure"
 #include <stdio.h>
@@ -13318,7 +13283,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13322: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13287: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13341,18 +13306,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13345: checking for fseeko" >&5
+echo "configure:13310: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13349 "configure"
+#line 13314 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13369,10 +13334,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13373: checking if system supports Large Files at all" >&5
+echo "configure:13338: checking if system supports Large Files at all" >&5
-#line 13376 "configure"
+#line 13341 "configure"
 #include <stdio.h>
@@ -13404,7 +13369,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13408: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13373: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13433,7 +13398,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13437: checking whether to use wxWidgets" >&5
+echo "configure:13402: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13454,7 +13419,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13458: checking for $ac_word" >&5
+echo "configure:13423: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13502,7 +13467,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13506: checking wxWidgets version" >&5
+echo "configure:13471: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13525,15 +13490,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13529: checking for $ac_hdr" >&5
+echo "configure:13494: checking for $ac_hdr" >&5
-#line 13532 "configure"
+#line 13497 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13537: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
