[GRASS-SVN] r55501 - in grass/branches/releasebranch_6_4: db/drivers/mysql lib/arraystats lib/nviz lib/vector/neta lib/vector/vedit vector/v.net.visibility
Fri Mar 22 12:28:16 PDT 2013
Author: neteler
Date: 2013-03-22 12:28:16 -0700 (Fri, 22 Mar 2013)
New Revision: 55501
   grass/branches/releasebranch_6_4/db/drivers/mysql/describe.c
   grass/branches/releasebranch_6_4/lib/arraystats/class.c
   grass/branches/releasebranch_6_4/lib/nviz/draw.c
   grass/branches/releasebranch_6_4/lib/nviz/position.c
   grass/branches/releasebranch_6_4/lib/vector/neta/articulation_point.c
   grass/branches/releasebranch_6_4/lib/vector/neta/bridge.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/render.c
   grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c
   grass/branches/releasebranch_6_4/vector/v.net.visibility/data_structures.c
Don't use // comments (C89 compatibility) (partial backport of r55499)
Modified: grass/branches/releasebranch_6_4/db/drivers/mysql/describe.c
--- grass/branches/releasebranch_6_4/db/drivers/mysql/describe.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/db/drivers/mysql/describe.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -204,8 +204,8 @@
 	break;
     case MYSQL_TYPE_DATETIME:
-	//*sqltype = DB_SQL_TYPE_DATETIME;
-	//*sqltype |= DB_DATETIME_MASK;
+	/* *sqltype = DB_SQL_TYPE_DATETIME; */
+	/* *sqltype |= DB_DATETIME_MASK; */
 	*sqltype = DB_SQL_TYPE_TIMESTAMP;
 	break;
Modified: grass/branches/releasebranch_6_4/lib/arraystats/class.c
--- grass/branches/releasebranch_6_4/lib/arraystats/class.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/arraystats/class.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -337,12 +337,12 @@
 		dmax = d;
 		nmax = k;
-	    nd--;		//A VERIFIER!
+	    nd--;		/* A VERIFIER! */
 	    if (x[nf] != x[nd]) {
 		if (nd != 0)
 		    co[j] = (xn[nf] - xn[nd]) / (x[nf] - x[nd]);
 		else
-		    co[j] = (xn[nf]) / (x[nf]);	//A VERIFIER!
+		    co[j] = (xn[nf]) / (x[nf]);	/* A VERIFIER! */
 	if (i == 1)
Modified: grass/branches/releasebranch_6_4/lib/nviz/draw.c
--- grass/branches/releasebranch_6_4/lib/nviz/draw.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/nviz/draw.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -120,7 +120,7 @@
 int Nviz_draw_all_vect()
-    // GS_set_cancel(0);
+    /* GS_set_cancel(0); */
     /* in case transparency is set */
     GS_set_draw(GSD_BOTH);
@@ -133,7 +133,7 @@
     GS_set_draw(GSD_BACK);
     return 1;
@@ -353,14 +353,14 @@
 void Nviz_set_2D(int width, int height)
-    glEnable(GL_BLEND); // images are transparent
+    glEnable(GL_BLEND); /* images are transparent */
     glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
     glMatrixMode(GL_PROJECTION);
     glLoadIdentity();
     glOrtho(0, width, 0, height, -1, 1);
-    // set coordinate system from upper left corner
+    /* set coordinate system from upper left corner */
     glScalef(1, -1, 1);
     glTranslatef(0, -height, 0);
Modified: grass/branches/releasebranch_6_4/lib/nviz/position.c
--- grass/branches/releasebranch_6_4/lib/nviz/position.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/nviz/position.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -125,8 +125,8 @@
     *x = realto[0];
     *y = realto[1];
     *z = realto[2];
-    // old nviz code is more complicated and it doesn't work properly,
-    // no idea why
+    /* old nviz code is more complicated and it doesn't work properly, */
+    /* no idea why */
     return 1;
@@ -146,8 +146,8 @@
     realto[1] = y;
     realto[2] = z;
     GS_set_focus(realto);
-    // no idea why
+    /* no idea why */
     return 1;
Modified: grass/branches/releasebranch_6_4/lib/vector/neta/articulation_point.c
--- grass/branches/releasebranch_6_4/lib/vector/neta/articulation_point.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/vector/neta/articulation_point.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -100,7 +100,7 @@
 			min_tin[node_id] = min_tin[to];
 		    current_edge[node_id] = dglEdgeset_T_Next(&current[node_id]);	/*proceed to the next edge */
-		for (; current_edge[node_id]; current_edge[node_id] = dglEdgeset_T_Next(&current[node_id])) {	//try next edges
+		for (; current_edge[node_id]; current_edge[node_id] = dglEdgeset_T_Next(&current[node_id])) {	/* try next edges */
 		    dglInt32_t *to =
 			dglEdgeGet_Tail(graph, current_edge[node_id]);
 		    if (to == parent[node_id])
Modified: grass/branches/releasebranch_6_4/lib/vector/neta/bridge.c
--- grass/branches/releasebranch_6_4/lib/vector/neta/bridge.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/vector/neta/bridge.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -98,7 +98,7 @@
+		for (; current_edge[node_id]; current_edge[node_id] = dglEdgeset_T_Next(&current[node_id])) {	/*try next edges */
 		    dglInt32_t *to =
 		    dglInt32_t edge_id =
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/render.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/render.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/render.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -98,7 +98,7 @@
     /* draw lines inside of current display region */
-    nfeat = Vect_select_lines_by_box(Map, box, GV_POINTS | GV_LINES,	// fixme
+    nfeat = Vect_select_lines_by_box(Map, box, GV_POINTS | GV_LINES,	/* fixme */
 				     list);
     G_debug(1, "Vedit_render_map(): region: w=%f, e=%f, s=%f, n=%f nlines=%d",
 	    box->W, box->E, box->S, box->N, nfeat);
@@ -190,7 +190,7 @@
 	else if (state.type == GV_CENTROID) {
 	    int cret = Vect_get_centroid_area(Map, line);
-	    if (cret > 0) {	// -> area
+	    if (cret > 0) {	/* -> area */
 		obj->type = TYPE_CENTROIDIN;
 		draw = draw_flag & DRAW_CENTROIDIN;
@@ -342,7 +342,7 @@
     narrows = 0;
     size = 5;
-    limit = 5;			// 5px for line segment
+    limit = 5;			/* 5px for line segment */
     dist = Vect_line_length(state.Points);
     G_debug(5, "  draw_line_dir() line=%d", line);
@@ -368,13 +368,13 @@
 	    draw_arrow(x0, y0, x1, y1, angle, size, line, list);
-	    if (narrows > 1e2)	// low resolution, break
+	    if (narrows > 1e2)	/* low resolution, break */
 		break;
 	    narrows++;
-	// draw at least one arrow in the middle of line
+	/* draw at least one arrow in the middle of line */
 	if (narrows < 1) {
 	    dist /= 2.;
 	    if (Vect_point_on_line(state.Points, dist,
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/zbulk.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -55,7 +55,6 @@
     Points_se = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
-    //cv = (dbCatValArray *) G_malloc (sizeof (dbCatValArray));
     db_CatValArray_alloc(&cv, List->n_values);
     cv.ctype = DB_C_TYPE_DOUBLE;
     cv.n_values = 0;
Modified: grass/branches/releasebranch_6_4/vector/v.net.visibility/data_structures.c
--- grass/branches/releasebranch_6_4/vector/v.net.visibility/data_structures.c	2013-03-22 18:54:56 UTC (rev 55500)
+++ grass/branches/releasebranch_6_4/vector/v.net.visibility/data_structures.c	2013-03-22 19:28:16 UTC (rev 55501)
@@ -76,7 +76,7 @@
     int j;
     if (l < r) {
-	// divide and conquer
+	/* divide and conquer */
 	j = partition(a, l, r);
 	quickSort(a, l, j - 1);
 	quickSort(a, j + 1, r);
