[GRASS-SVN] r55505 - grass/trunk/vector/v.external.out
Sat Mar 23 09:56:41 PDT 2013
Author: martinl
Date: 2013-03-23 09:56:41 -0700 (Sat, 23 Mar 2013)
New Revision: 55505
   grass/trunk/vector/v.external.out/link.c
   grass/trunk/vector/v.external.out/main.c
v.external.out: add some verbose messages
Modified: grass/trunk/vector/v.external.out/link.c
--- grass/trunk/vector/v.external.out/link.c	2013-03-23 00:42:48 UTC (rev 55504)
+++ grass/trunk/vector/v.external.out/link.c	2013-03-23 16:56:41 UTC (rev 55505)
@@ -138,6 +138,14 @@
 	G_fatal_error(_("Error writing <%s> file"), filename);
     fclose(fp);
+    if (use_ogr)
+        G_verbose_message(_("Switched to OGR format (%s)"),
+                          G_find_key_value("format", key_val));
+    else
+        G_verbose_message(_("Switched to PostGIS format"));
+    G_free_key_value(key_val);
 char *get_option_pg(char **options, const char *key)
Modified: grass/trunk/vector/v.external.out/main.c
--- grass/trunk/vector/v.external.out/main.c	2013-03-23 00:42:48 UTC (rev 55504)
+++ grass/trunk/vector/v.external.out/main.c	2013-03-23 16:56:41 UTC (rev 55505)
@@ -3,11 +3,12 @@
  * MODULE:       v.external.out
- * AUTHOR(S):    Martin Landa <landa.martin gmail.com> (based on r.external.out code)
+ * AUTHOR(S):    Martin Landa <landa.martin gmail.com>
  * PURPOSE:      Make GRASS write vector maps utilizing the OGR library.
+ *               (Partly based on r.external.out code)
- * COPYRIGHT:    (C) 2010 by Martin Landa and the GRASS Development Team
+ * COPYRIGHT:    (C) 2010-2013 by Martin Landa and the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2).  Read the file COPYING that
@@ -58,9 +59,14 @@
     if (flags.r->answer) {
-	if (G_remove("", "OGR") == 0)
-	    G_remove("", "PG");
-	exit(EXIT_SUCCESS);
+        if (G_remove("", "OGR") == 1) {
+            G_verbose_message(_("Switched from OGR to native format"));
+        else {
+            if (G_remove("", "PG") == 1)
+                G_verbose_message(_("Switched from PostGIS to native format"));
+        exit(EXIT_SUCCESS);
     format = NULL;
@@ -75,7 +81,7 @@
     if (flags.p->answer || flags.g->answer) {
-	print_status(flags.g->answer ? 1 : 0);
+	print_status(flags.g->answer ? TRUE : FALSE);
     exit(EXIT_SUCCESS);
