[GRASS-SVN] r55508 - grass/branches/releasebranch_6_4/visualization/nviz
svn_grass at osgeo.org
Sun Mar 24 03:24:27 PDT 2013
Author: neteler
Date: 2013-03-24 03:24:27 -0700 (Sun, 24 Mar 2013)
New Revision: 55508
grass/branches/releasebranch_6_4/visualization/nviz/description.html
fix multi parameter
Modified: grass/branches/releasebranch_6_4/visualization/nviz/description.html
--- grass/branches/releasebranch_6_4/visualization/nviz/description.html 2013-03-24 08:55:37 UTC (rev 55507)
+++ grass/branches/releasebranch_6_4/visualization/nviz/description.html 2013-03-24 10:24:27 UTC (rev 55508)
@@ -18,44 +18,44 @@
<h2>SYNOPSIS</h2>
<b>nviz</b><br>
<b>nviz help</b><br>
-<b>nviz</b> [-<b>q</b>] [<b>elevation</b>=<em>string</em>] [<b>color</b>=<em>string</em>] [<b>vector</b>=<em>string</em>] [<b>points</b>=<em>string</em>] [<b>volume</b>=<em>string</em>] [<b>path</b>=<em>string</em>] [<b>script</b>=<em>string</em>] [<b>state</b>=<em>string</em>] [--<b>verbose</b>] [--<b>quiet</b>]
+<b>nviz</b> [-<b>q</b>] [<b>elevation</b>=<em>name</em>[,<i>name</i>,...]] [<b>color</b>=<em>name</em>[,<i>name</i>,...]] [<b>vector</b>=<em>name</em>[,<i>name</i>,...]] [<b>points</b>=<em>name</em>[,<i>name</i>,...]] [<b>volume</b>=<em>name</em>[,<i>name</i>,...]] [<b>path</b>=<em>string</em>] [<b>script</b>=<em>string</em>] [<b>state</b>=<em>string</em>] [--<b>verbose</b>] [--<b>quiet</b>]
<h3>Flags:</h3>
<dl>
-<dt><b>-q</b></DT>
-<dd>Quickstart - Do not load any data</DD>
+<dt><b>-q</b></dt>
+<dd>Quickstart - Do not load any data</dd>
-<dt><b>--verbose</b></DT>
-<dd>Verbose module output</DD>
-<dt><b>--quiet</b></DT>
-<dd>Quiet module output</DD>
+<dt><b>--verbose</b></dt>
+<dd>Verbose module output</dd>
+<dt><b>--quiet</b></dt>
+<dd>Quiet module output</dd>
</dl>
<h3>Parameters:</h3>
<dl>
-<dt><b>elevation</b>=<em>string</em></DT>
-<dd>Raster file(s) for elevation</DD>
+<dt><b>elevation</b>=<em>name</em>[,<i>name</i>,...]</dt>
+<dd>Raster file(s) for elevation</dd>
-<dt><b>color</b>=<em>string</em></DT>
-<dd>Raster file(s) for color</DD>
+<dt><b>color</b>=<em>name</em>[,<i>name</i>,...]</dt>
+<dd>Raster file(s) for color</dd>
-<dt><b>vector</b>=<em>string</em></DT>
-<dd>Vector lines/areas overlay file(s)</DD>
+<dt><b>vector</b>=<em>name</em>[,<i>name</i>,...]</dt>
+<dd>Vector lines/areas overlay file(s)</dd>
-<dt><b>points</b>=<em>string</em></DT>
-<dd>Vector points overlay file(s)</DD>
+<dt><b>points</b>=<em>name</em>[,<i>name</i>,...]</dt>
+<dd>Vector points overlay file(s)</dd>
-<dt><b>volume</b>=<em>string</em></DT>
-<dd>Name of existing 3d raster map</DD>
+<dt><b>volume</b>=<em>name</em>[,<i>name</i>,...]</dt>
+<dd>Name of existing 3d raster map</dd>
-<dt><b>path</b>=<em>string</em></DT>
-<dd>Set alternative panel path</DD>
+<dt><b>path</b>=<em>string</em></dt>
+<dd>Set alternative panel path</dd>
-<dt><b>script</b>=<em>string</em></DT>
-<dd>Execute script file at startup</DD>
+<dt><b>script</b>=<em>string</em></dt>
+<dd>Execute script file at startup</dd>
-<dt><b>state</b>=<em>string</em></DT>
-<dd>Load previosly saved state file</DD>
+<dt><b>state</b>=<em>string</em></dt>
+<dd>Load previosly saved state file</dd>
</dl>
@@ -66,5 +66,6 @@
<a href="nviz/index.html">NVIZ Tutorial</a>.
<hr>
<p><a href="index.html">Main index</a> - <a href="full_index.html">Full index</a>
+<P>© 1999-2013 <a href="http://grass.osgeo.org">GRASS Development Team</a></p>
</body>
</html>
