[GRASS-SVN] r55518 - in grass/trunk/temporal: t.rast.univar t.rast3d.univar t.register t.vect.db.select
svn_grass at osgeo.org
Mon Mar 25 12:53:43 PDT 2013
Author: neteler
Date: 2013-03-25 12:53:42 -0700 (Mon, 25 Mar 2013)
New Revision: 55518
grass/trunk/temporal/t.rast.univar/t.rast.univar.py
grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
grass/trunk/temporal/t.register/t.register.py
grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
temporal modules: standardize field separator parameter
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.py
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2013-03-25 14:07:55 UTC (rev 55517)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2013-03-25 19:53:42 UTC (rev 55518)
@@ -27,12 +27,8 @@
#%option G_OPT_T_WHERE
#%end
-#%option
-#% key: fs
-#% type: string
+#%option G_OPT_F_SEP
#% description: Field separator character between the output columns
-#% required: no
-#% answer: |
#%end
#%flag
@@ -58,7 +54,7 @@
where = options["where"]
extended = flags["e"]
header = flags["h"]
- fs = options["fs"]
+ fs = options["separator"]
# Make sure the temporal database exists
tgis.init()
Modified: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
--- grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2013-03-25 14:07:55 UTC (rev 55517)
+++ grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2013-03-25 19:53:42 UTC (rev 55518)
@@ -27,12 +27,8 @@
#%end
-#%option
-#% key: fs
-#% type: string
-#% required: no
-#% answer: |
#%end
#%flag
@@ -58,7 +54,7 @@
header = flags["h"]
tgis.init()
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py 2013-03-25 14:07:55 UTC (rev 55517)
+++ grass/trunk/temporal/t.register/t.register.py 2013-03-25 19:53:42 UTC (rev 55518)
@@ -80,12 +80,8 @@
#% guisection: Time & Date
#%end
-#%option
-#% key: fs
-#% type: string
#% description: Field separator character of the input file
-#% required: no
-#% answer: |
#% guisection: Input
#%end
@@ -108,7 +104,7 @@
maps = options["maps"]
type = options["type"]
file = options["file"]
start = options["start"]
end = options["end"]
unit = options["unit"]
Modified: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2013-03-25 14:07:55 UTC (rev 55517)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2013-03-25 19:53:42 UTC (rev 55518)
@@ -29,12 +29,8 @@
#%option G_OPT_DB_COLUMNS
#%end
-#%option
-#% key: separator
-#% type: string
#% description: Separator character between the output columns
-#% required: no
-#% answer: |
#%end
#%option G_OPT_V_FIELD
