[GRASS-SVN] r55523 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Mar 26 06:49:57 PDT 2013
Author: martinl
Date: 2013-03-26 06:49:56 -0700 (Tue, 26 Mar 2013)
New Revision: 55523
grass/trunk/lib/vector/Vlib/level_two.c
vlib: Vect_get_line_areas() return -1 on error + doxygen update
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2013-03-26 12:44:25 UTC (rev 55522)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2013-03-26 13:49:56 UTC (rev 55523)
@@ -330,13 +330,16 @@
- \brief Get area/isle ids on the left and right
+ \brief Get area id on the left and right side of the boundary
+ Negative area id indicates an isle.
\param Map pointer to Map_info struct
\param line line id
- \param[out] left,right area/isle id on the left and right
+ \param[out] left,right area id on the left and right side
- \return 1
+ \return 1 on success
+ \return -1 on failure (topology not available, line is not a boundary)
int Vect_get_line_areas(const struct Map_info *Map, int line, int *left, int *right)
@@ -344,19 +347,23 @@
check_level(Map);
- if (!Map->plus.Line[line]->topo)
- G_fatal_error(_("Areas not available for line %d"), line);
+ if (!Map->plus.Line[line]->topo) {
+ G_warning(_("Areas not available for line %d"), line);
+ return -1;
- if (Vect_get_line_type(Map, line) != GV_BOUNDARY)
- G_fatal_error(_("Line %d is not a boundary"), line);
+ if (Vect_get_line_type(Map, line) != GV_BOUNDARY) {
+ G_warning(_("Line %d is not a boundary"), line);
+ return -1;
topo = (struct P_topo_b *)Map->plus.Line[line]->topo;
if (left != NULL)
*left = topo->left;
if (right != NULL)
*right = topo->right;
return 1;
