[GRASS-SVN] r55528 - in grass/trunk: raster/r.cost raster/r.gwflow raster/r.to.rast3 raster/r.to.rast3elev raster3d/r3.cross.rast raster3d/r3.to.rast vector/v.delaunay vector/v.hull vector/v.voronoi
svn_grass at osgeo.org
Tue Mar 26 13:28:19 PDT 2013
Author: annakrat
Date: 2013-03-26 13:28:19 -0700 (Tue, 26 Mar 2013)
New Revision: 55528
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.gwflow/r.gwflow.html
grass/trunk/raster/r.to.rast3/r.to.rast3.html
grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html
grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
grass/trunk/raster3d/r3.to.rast/r3.to.rast.html
grass/trunk/vector/v.delaunay/v.delaunay.html
grass/trunk/vector/v.hull/v.hull.html
grass/trunk/vector/v.voronoi/v.voronoi.html
add missing quotes to html tags attribute values (to render images in wxGUI man properly)
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/raster/r.cost/r.cost.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -78,8 +78,8 @@
<br>
Knight's move example:
<center>
-<img src=rcost_knightsmove.png border=1><br>
-<table border=0 width=590>
+<img src="rcost_knightsmove.png" border="1"><br>
+<table border="0" width="590">
<tr><td><center>
<i>Flat cost surface without (left pane) and with the knight's move (right pane).
The default is to grow the cost outwards in 8 directions.
Modified: grass/trunk/raster/r.gwflow/r.gwflow.html
--- grass/trunk/raster/r.gwflow/r.gwflow.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/raster/r.gwflow/r.gwflow.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -7,8 +7,8 @@
<p>This module is sensitive to mask settings. All cells which are outside the mask
are ignored and handled as no flow boundaries.
<p><center>
-<img src=r_gwflow_concept.png border=0><br>
-<table border=0 width=700>
+<img src="r_gwflow_concept.png" border="0"><br>
+<table border="0" width="700">
<tr><td><center>
<i>Workflow of r.gwflow</i>
</center></td></tr>
Modified: grass/trunk/raster/r.to.rast3/r.to.rast3.html
--- grass/trunk/raster/r.to.rast3/r.to.rast3.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/raster/r.to.rast3/r.to.rast3.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -5,8 +5,8 @@
the 2d resolution will be adjust to the 3d resolution.
<center>
-<img src=r.to.rast3.png border=0><br>
+<img src="r.to.rast3.png" border="0"><br>
<tr><td><center>
<i>How r.to.rast3 works</i>
</center></td></tr>
Modified: grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html
--- grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -5,8 +5,8 @@
<center>
-<img src=r.to.rast3elev.png border=0><br>
+<img src="r.to.rast3elev.png" border="0"><br>
<tr><td><center>
<i>How r.to.rast3elev works</i>
</center></td></tr>
Modified: grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
--- grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -7,8 +7,8 @@
cross section output map cell, otherwise the NULL value is set.
<center>
-<img src=r3.cross.rast.png border=0><br>
+<img src="r3.cross.rast.png" border="0"><br>
<tr><td><center>
<i>How r3.cross.rast works</i>
</center></td></tr>
Modified: grass/trunk/raster3d/r3.to.rast/r3.to.rast.html
--- grass/trunk/raster3d/r3.to.rast/r3.to.rast.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/raster3d/r3.to.rast/r3.to.rast.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -7,8 +7,8 @@
3D raster map for the output maps, independently from the current region settings.
<center>
-<img src=r3.to.rast.png border=0><br>
+<img src="r3.to.rast.png" border="0"><br>
<tr><td><center>
<em>How r3.to.rast works</em>
</center></td></tr>
Modified: grass/trunk/vector/v.delaunay/v.delaunay.html
--- grass/trunk/vector/v.delaunay/v.delaunay.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/vector/v.delaunay/v.delaunay.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -6,8 +6,8 @@
<br>
Delaunay triangulation and Voronoi diagram example:
<center>
-<img src=v_voronoi_delaunay.png border=1><br> <!-- installed by v.voronoi -->
+<img src="v_voronoi_delaunay.png" border="1"><br> <!-- installed by v.voronoi -->
<tr><td><center>
<i>Delaunay Triangulation (left pane), Voronoi diagram (center pane),
and both (right pane)</i>
Modified: grass/trunk/vector/v.hull/v.hull.html
--- grass/trunk/vector/v.hull/v.hull.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/vector/v.hull/v.hull.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -11,8 +11,8 @@
composed of triangular faces.
<center>
-<img src=v_hull.png border=1><br>
+<img src="v_hull.png" border="1"><br>
<tr><td><center>
Fig: Convex hull polygon created with <em>v.hull</em>
</center></td></tr>
Modified: grass/trunk/vector/v.voronoi/v.voronoi.html
--- grass/trunk/vector/v.voronoi/v.voronoi.html 2013-03-26 19:15:41 UTC (rev 55527)
+++ grass/trunk/vector/v.voronoi/v.voronoi.html 2013-03-26 20:28:19 UTC (rev 55528)
@@ -8,8 +8,8 @@
<br>
Voronoi diagram and Delaunay triangulation example:
<center>
<tr><td><center>
