[GRASS-SVN] r56058 - grass/trunk/lib/temporal/SQL
Wed May 1 11:53:49 PDT 2013
Author: neteler
Date: 2013-05-01 11:53:49 -0700 (Wed, 01 May 2013)
New Revision: 56058
   grass/trunk/lib/temporal/SQL/map_stds_register_table_template.sql
   grass/trunk/lib/temporal/SQL/map_tables_template.sql
   grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql
   grass/trunk/lib/temporal/SQL/raster3d_views.sql
   grass/trunk/lib/temporal/SQL/raster_metadata_table.sql
   grass/trunk/lib/temporal/SQL/raster_views.sql
   grass/trunk/lib/temporal/SQL/sqlite3_delete_trigger.sql
   grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql
   grass/trunk/lib/temporal/SQL/stds_raster3d_register_trigger_template.sql
   grass/trunk/lib/temporal/SQL/stds_raster_register_trigger_template.sql
   grass/trunk/lib/temporal/SQL/stds_tables_template.sql
   grass/trunk/lib/temporal/SQL/stds_vector_register_trigger_template.sql
   grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql
   grass/trunk/lib/temporal/SQL/str3ds_views.sql
   grass/trunk/lib/temporal/SQL/strds_metadata_table.sql
   grass/trunk/lib/temporal/SQL/strds_views.sql
   grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
   grass/trunk/lib/temporal/SQL/stvds_views.sql
   grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql
   grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
   grass/trunk/lib/temporal/SQL/vector_views.sql
svn propset
Property changes on: grass/trunk/lib/temporal/SQL/map_stds_register_table_template.sql
___________________________________________________________________
Added: svn:mime-type
   + text/x-sql
Added: svn:eol-style
   + native
Property changes on: grass/trunk/lib/temporal/SQL/map_tables_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/raster3d_views.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/raster_metadata_table.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/raster_views.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/sqlite3_delete_trigger.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stds_raster3d_register_trigger_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stds_raster_register_trigger_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stds_tables_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stds_vector_register_trigger_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/str3ds_views.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/strds_metadata_table.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/strds_views.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/stvds_views.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
   + text/x-sql
   + native
Property changes on: grass/trunk/lib/temporal/SQL/vector_views.sql
   + text/x-sql
   + native
