[GRASS-SVN] r56064 - grass/branches/develbranch_6/gui/wxpython/docs
svn_grass at osgeo.org
Wed May 1 17:52:44 PDT 2013
Author: hamish
Date: 2013-05-01 17:52:44 -0700 (Wed, 01 May 2013)
New Revision: 56064
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
slight further tweak
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2013-05-02 00:39:29 UTC (rev 56063)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2013-05-02 00:52:44 UTC (rev 56064)
@@ -23,12 +23,12 @@
GRASS_GUI: wxpython
</pre></div>
-The GUI can be quit by selecting the 'File -> Exit' menu item.
+The GUI can be quit by selecting the 'File -> Exit GUI' menu item.
<!-- is → allowed? -->
On MS Windows when GRASS is launched without an interactive command line
this will end the entire GRASS session. In other cases the terminal
window will remain running; type <tt>exit</tt> at the command prompt
-to shut down the GRASS engine.
+to end the GRASS session.
<p>
The GUI can be restarted from the GRASS command line prompt by typing
