[GRASS-SVN] r56078 - grass/branches/releasebranch_6_4/gui/wxpython/psmap
svn_grass at osgeo.org
Thu May 2 03:05:08 PDT 2013
Author: annakrat
Date: 2013-05-02 03:05:07 -0700 (Thu, 02 May 2013)
New Revision: 56078
grass/branches/releasebranch_6_4/gui/wxpython/psmap/frame.py
wxGUI/composer: attempt to fix generating PDF on Windows (merge from develbranch, r56077)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/psmap/frame.py
--- grass/branches/releasebranch_6_4/gui/wxpython/psmap/frame.py 2013-05-02 09:38:22 UTC (rev 56077)
+++ grass/branches/releasebranch_6_4/gui/wxpython/psmap/frame.py 2013-05-02 10:05:07 UTC (rev 56078)
@@ -222,15 +222,16 @@
def OnPDFFile(self, event):
"""!Generate PDF from PS with ps2pdf if available"""
- try:
- p = grass.Popen(["ps2pdf"], stderr = grass.PIPE)
- p.stderr.close()
+ if not sys.platform == 'win32':
+ try:
+ p = grass.Popen(["ps2pdf"], stderr = grass.PIPE)
+ p.stderr.close()
+ except OSError:
+ GMessage(parent = self,
+ message = _("Program ps2pdf is not available. Please install it first to create PDF."))
+ return
- except OSError:
- GMessage(parent = self,
- message = _("Program ps2pdf is not available. Please install it first to create PDF."))
- return
filename = self.getFile(wildcard = "PDF (*.pdf)|*.pdf")
if filename:
self.PSFile(filename, pdf = True)
@@ -294,14 +295,30 @@
return
if event.userData['pdfname']:
+ if sys.platform == 'win32':
+ command = ['gswin32c',
+ '-P-', '-dSAFER',
+ '-dCompatibilityLevel=1.4',
+ '-q', '-P-',
+ '-dNOPAUSE', '-dBATCH',
+ '-sDEVICE=pdfwrite',
+ '-dPDFSETTINGS=/prepress', '-r1200',
+ '-sstdout=%stderr',
+ '-sOutputFile=%s' % event.userData['pdfname'],
+ '-P-', '-dSAFER',
+ '-c', '.setpdfwrite', '-f',
+ event.userData['filename']]
+ else:
+ command = ['ps2pdf', '-dPDFSETTINGS=/prepress', '-r1200',
+ event.userData['filename'], event.userData['pdfname']]
try:
- proc = grass.Popen(['ps2pdf', '-dPDFSETTINGS=/prepress', '-r1200',
- event.userData['filename'], event.userData['pdfname']])
+ proc = grass.Popen(command)
ret = proc.wait()
if ret > 0:
- message = _("ps2pdf exited with return code %s") % ret)
+ message = _("%(prg)s exited with return code %(code)s") % {'prg': command[0],
+ 'code': ret})
except OSError, e:
GError(parent = self,
