[GRASS-SVN] r56081 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Thu May 2 07:32:52 PDT 2013
Author: annakrat
Date: 2013-05-02 07:32:52 -0700 (Thu, 02 May 2013)
New Revision: 56081
grass/trunk/gui/wxpython/xml/toolboxes.xml
wxGUI: temporal toolboxes added
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2013-05-02 11:45:58 UTC (rev 56080)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2013-05-02 14:32:52 UTC (rev 56081)
@@ -1732,5 +1732,187 @@
</module-item>
</items>
</toolbox>
+ <toolbox name="Temporal">
+ <label>Temporal</label>
+ <items>
+ <subtoolbox name="TemporalManageDatasets"/>
+ <subtoolbox name="TemporalManageMapsInDatasets"/>
+ <separator/>
+ <subtoolbox name="TemporalImport"/>
+ <subtoolbox name="TemporalExport"/>
+ <module-item name="t.rast.to.rast3">
+ <label>Convert raster dataset to volume</label>
+ </module-item>
+ <separator/>
+ <subtoolbox name="TemporalExtraction"/>
+ <module-item name="t.vect.db.select">
+ <label>Query vector dataset attribute data</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.rast.colors">
+ <label>Raster dataset color table</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.rast.mapcalc">
+ <label>Raster calculations</label>
+ </module-item>
+ <module-item name="t.rast3d.mapcalc">
+ <label>Raster3D calculations</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.rast.gapfill">
+ <label>Interpolate gaps in raster datasets</label>
+ </module-item>
+ <subtoolbox name="TemporalAggregation"/>
+ <subtoolbox name="TemporalSampling"/>
+ <subtoolbox name="TemporalReportAndStatistics"/>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalManageDatasets">
+ <label>Manage datasets</label>
+ <items>
+ <module-item name="t.create">
+ <label>Create</label>
+ </module-item>
+ <module-item name="t.rename">
+ <label>Rename</label>
+ </module-item>
+ <module-item name="t.remove">
+ <label>Remove</label>
+ </module-item>
+ <module-item name="t.support">
+ <label>Update metadata</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.merge">
+ <label>Merge</label>
+ </module-item>
+ <module-item name="t.shift">
+ <label>Temporally shift</label>
+ </module-item>
+ <module-item name="t.snap">
+ <label>Snap maps of dataset</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.list">
+ <label>List</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalManageMapsInDatasets">
+ <label>Manage maps in datasets</label>
+ <items>
+ <module-item name="t.register">
+ <label>Register maps in datasets</label>
+ </module-item>
+ <module-item name="t.unregister">
+ <label>Unregister maps from datasets</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.rast.list">
+ <label>List raster dataset maps</label>
+ </module-item>
+ <module-item name="t.vect.list">
+ <label>List vector dataset maps</label>
+ </module-item>
+ <module-item name="t.rast3d.list">
+ <label>List raster3D dataset maps</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalReportAndStatistics">
+ <label>Report and statistics</label>
+ <items>
+ <module-item name="t.info">
+ <label>Space time datasets metadata</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.rast.univar">
+ <label>Univariate raster dataset statistics</label>
+ </module-item>
+ <module-item name="t.vect.univar">
+ <label>Univariate vector dataset statistics</label>
+ </module-item>
+ <module-item name="t.rast3d.univar">
+ <label>Univariate raster3D dataset statistics</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.topology">
+ <label>Report temporal topology</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalImport">
+ <label>Import</label>
+ <items>
+ <module-item name="t.rast.import">
+ <label>Import raster dataset</label>
+ </module-item>
+ <module-item name="t.vect.import">
+ <label>Import vector dataset</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalExport">
+ <label>Export</label>
+ <items>
+ <module-item name="t.rast.export">
+ <label>Export raster dataset</label>
+ </module-item>
+ <module-item name="t.rast.out.vtk">
+ <label>Export raster dataset as VTK time series</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.vect.export">
+ <label>Export vector dataset</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalExtraction">
+ <label>Extraction</label>
+ <items>
+ <module-item name="t.rast.extract">
+ <label>Extract subset of raster dataset</label>
+ </module-item>
+ <module-item name="t.vect.extract">
+ <label>Extract subset of vector dataset</label>
+ </module-item>
+ <module-item name="t.rast3d.extract">
+ <label>Extract subset of raster3D dataset</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalAggregation">
+ <label>Aggregation</label>
+ <items>
+ <module-item name="t.rast.neighbors">
+ <label>Neighborhood analysis in raster dataset</label>
+ </module-item>
+ <module-item name="t.rast.series">
+ <label>Aggregation in raster datasets</label>
+ </module-item>
+ <separator/>
+ <module-item name="t.rast.aggregate">
+ <label>Temporal aggregation</label>
+ </module-item>
+ <module-item name="t.rast.aggregate.ds">
+ <label>Temporal aggregation by dataset</label>
+ </module-item>
+ </items>
+ </toolbox>
+ <toolbox name="TemporalSampling">
+ <label>Sampling</label>
+ <items>
+ <module-item name="t.sample">
+ <label>Temporal sampling</label>
+ </module-item>
+ <module-item name="t.vect.what.strds">
+ <label>Query raster dataset by vector points dataset</label>
+ </module-item>
+ <module-item name="t.vect.observe.strds">
+ <label>Observe specific locations in raster dataset</label>
+ </module-item>
+ </items>
+ </toolbox>
</toolboxes>
