[GRASS-SVN] r56098 - grass/trunk/vector/v.in.ascii
svn_grass at osgeo.org
Fri May 3 12:45:57 PDT 2013
Author: neteler
Date: 2013-05-03 12:45:57 -0700 (Fri, 03 May 2013)
New Revision: 56098
grass/trunk/vector/v.in.ascii/v.in.ascii.html
v.in.ascii manual: typo fixes
Modified: grass/trunk/vector/v.in.ascii/v.in.ascii.html
--- grass/trunk/vector/v.in.ascii/v.in.ascii.html 2013-05-03 09:36:10 UTC (rev 56097)
+++ grass/trunk/vector/v.in.ascii/v.in.ascii.html 2013-05-03 19:45:57 UTC (rev 56098)
@@ -40,9 +40,9 @@
topology support (vector level 1) due to memory constraints. This is
done with the <b>-b</b> flag. As only very few vector modules support
points data processing at vector level 1, usually topology is required
-(vector level 2). Therefore it is recommened that the user first try
+(vector level 2). Therefore it is recommended that the user first try
to import the data without creating a database (the <b>-t</b> flag) or
-within a subregion (the <b>-r</b> flag) before resorting the to
+within a subregion (the <b>-r</b> flag) before resorting to the
disabling of topology.
<p>If old version is requested, the <b>output</b> files
