[GRASS-SVN] r56100 - grass/branches/develbranch_6/vector/v.in.ascii
svn_grass at osgeo.org
Fri May 3 12:47:15 PDT 2013
Author: neteler
Date: 2013-05-03 12:47:15 -0700 (Fri, 03 May 2013)
New Revision: 56100
grass/branches/develbranch_6/vector/v.in.ascii/description.html
v.in.ascii manual: typo fixes
Modified: grass/branches/develbranch_6/vector/v.in.ascii/description.html
--- grass/branches/develbranch_6/vector/v.in.ascii/description.html 2013-05-03 19:47:09 UTC (rev 56099)
+++ grass/branches/develbranch_6/vector/v.in.ascii/description.html 2013-05-03 19:47:15 UTC (rev 56100)
@@ -63,9 +63,9 @@
(creating a GRASS vector level 1 vector map) due to memory constraints.
This is done with the <b>-b</b> flag. As only very few vector modules
support points data processing at vector level 1, usually topology is
-required (vector level 2). Therefore it is recommened that the user first
+required (vector level 2). Therefore it is recommended that the user first
try to import the data without creating a database (the <b>-t</b> flag)
-or within a subregion (the <b>-r</b> flag) before resorting the to
+or within a subregion (the <b>-r</b> flag) before resorting to the
disabling of topology.
<p>
