[GRASS-SVN] r56109 - grass/branches/releasebranch_6_4/gui/wxpython/gui_core
svn_grass at osgeo.org
Sat May 4 01:47:49 PDT 2013
Author: hamish
Date: 2013-05-04 01:47:49 -0700 (Sat, 04 May 2013)
New Revision: 56109
grass/branches/releasebranch_6_4/gui/wxpython/gui_core/goutput.py
rename 'Protocol' to 'Log file' and make it append not overwrite (#1936, merge from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/goutput.py 2013-05-04 08:33:18 UTC (rev 56108)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/goutput.py 2013-05-04 08:47:49 UTC (rev 56109)
@@ -265,10 +265,10 @@
self.btnCmdAbort.SetToolTipString(_("Abort running command"))
self.btnCmdAbort.Enable(False)
self.btnCmdProtocol = wx.ToggleButton(parent = self.panelOutput, id = wx.ID_ANY,
- label = _("&Protocol"),
+ label = _("&Log file"),
size = self.btnCmdClear.GetSize())
- self.btnCmdProtocol.SetToolTipString(_("Toggle to save list of executed commands into file; "
- "content saved when switching off."))
+ self.btnCmdProtocol.SetToolTipString(_("Toggle to save list of executed commands into "
+ "a file; content saved when switching off."))
if self.parent.GetName() != 'LayerManager':
self.btnCmdClear.Hide()
@@ -676,7 +676,7 @@
GError(_("Unable to write file '%(path)s'.\n\nDetails: %(error)s") % {'path': path, 'error': e})
finally:
output.close()
- self.parent.SetStatusText(_("Commands output saved into '%s'") % path)
+ self.parent.SetStatusText(_("Command output saved into '%s'") % path)
dlg.Destroy()
@@ -775,12 +775,12 @@
self.progressbar.SetValue(event.value)
def CmdProtocolSave(self):
- """Save commands protocol into the file"""
+ """Save list of manually entered commands into a text log file"""
if not hasattr(self, 'cmdFileProtocol'):
return # it should not happen
try:
- output = open(self.cmdFileProtocol, "w")
+ output = open(self.cmdFileProtocol, "a")
cmds = self.cmdPrompt.GetCommands()
output.write('\n'.join(cmds))
if len(cmds) > 0:
@@ -791,7 +791,7 @@
finally:
output.close()
- self.parent.SetStatusText(_("Commands protocol saved into '%s'") % self.cmdFileProtocol)
+ self.parent.SetStatusText(_("Command log saved to '%s'") % self.cmdFileProtocol)
del self.cmdFileProtocol
def OnCmdProtocol(self, event = None):
@@ -805,10 +805,10 @@
self.cmdPrompt.ClearCommands()
# ask for the file
dlg = wx.FileDialog(self, message = _("Save file as..."),
- defaultFile = "grass_cmd_protocol.txt",
+ defaultFile = "grass_cmd_log.txt",
wildcard = _("%(txt)s (*.txt)|*.txt|%(files)s (*)|*") %
{'txt': _("Text files"), 'files': _("Files")},
- style = wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+ style = wx.SAVE)
if dlg.ShowModal() == wx.ID_OK:
self.cmdFileProtocol = dlg.GetPath()
else:
