[GRASS-SVN] r56113 - grass-addons/grass6/raster/r.mess
svn_grass at osgeo.org
Sat May 4 02:46:20 PDT 2013
Author: pvanbosgeo
Date: 2013-05-04 02:46:19 -0700 (Sat, 04 May 2013)
New Revision: 56113
grass-addons/grass6/raster/r.mess/r.mess
bug fixes; in R script, replace system calls by execGRASS calls; add check for required package (spgrass) and automatic install in temp directory if not present.
Modified: grass-addons/grass6/raster/r.mess/r.mess
--- grass-addons/grass6/raster/r.mess/r.mess 2013-05-04 09:45:57 UTC (rev 56112)
+++ grass-addons/grass6/raster/r.mess/r.mess 2013-05-04 09:46:19 UTC (rev 56113)
@@ -22,7 +22,7 @@
# improvements. Suggestions for improvements are most
# welcome. In the meantime, use it at your own risk
-# COPYRIGHT: (C) 2012 Paulo van Breugel
+# COPYRIGHT: (C) 2013 Paulo van Breugel
# http://ecodiv.org
# http://pvanb.wordpress.com/
@@ -82,7 +82,7 @@
#% type: string
#% description: Precision of your input layers values
#% key_desc: string
-#% answer: 0.001
+#% answer: 0.0001
#% required: yes
#%end
@@ -122,13 +122,13 @@
fi
## check for awk
-if [ ! -x "`which awk`" ] ; then
+if [ ! -x "$(which awk)" ] ; then
g.message -e "<awk> required, please install <awk> or <gawk> first"
exit 1
fi
## check for R
-if [ ! -x "`which R`" ] ; then
+if [ ! -x "$(which R)" ] ; then
g.message -e "<R> required, please install <R> first"
exit 1
fi
@@ -160,12 +160,12 @@
##fix this path
if [ -z "$PROCESSDIR" ] ; then
- PROCESSDIR="$HOME"
+ PROCESSDIR="$HOME"
fi
#fix this path
if [ -z "$LOGDIR" ] ; then
- LOGDIR="$HOME"
+ LOGDIR="$HOME"
fi
LOGFILE="$LOGDIR/r.mess.log"
@@ -228,15 +228,15 @@
oIFS=$IFS
IFS=,
for nvar in $INMAPS ; do
- arrIN=${OUTMAPS}_`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`
- g.findfile element=cell file=${arrIN} > /dev/null
+ arrTEST=${OUTMAPS}_`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`
+ g.findfile element=cell file=${arrTEST} > /dev/null
if [ $? -eq 0 ] ; then
- g.message -e 'The output map '${arrIN}' already exists'
+ g.message -e 'The output map '${arrTEST}' already exists'
exit 1
fi
done
IFS=$oIFS
-unset arrIN
+unset arrTEST
# test for missing input raster maps
oIFS=$IFS
@@ -260,8 +260,14 @@
cat > $1 << "EOF"
options(echo = FALSE)
-require(spgrass6)
+# Install (if not present) and load required packages
+tmp.pack <- tempdir()
+if (!"spgrass6" %in% installed.packages()){
+ install.packages("spgrass6", dep=TRUE, repos='http://star-www.st-andrews.ac.uk/cran/', tmp.pack)
+ require(spgrass6, lib.loc=tmp.pack)
+}else{require(spgrass6)}
# Check grass version
grassversion <- as.numeric(system("g.version | cut -c7", intern=T))
@@ -277,6 +283,7 @@
rtl <- argus[10] # raster or vector layer
digits <- as.numeric(argus[9]) # Precision
rdigits <- nchar((1/digits)-1)
+options(echo=TRUE, digits=rdigits+1, scipen=rdigits+1)
# Create the r.mapcalc expressions to calculate the mess for the
@@ -299,7 +306,7 @@
# unique value is needed.
# One option is to convert the floating layers to integer layers after
# multiplying first with a number equal to the reciprocal of the value
- # given under the digits option
+ # given under the digits option. This may deal better with rounding errors too.
fft <- system("g.findfile --quiet element=cell file=MASK", ignore.stdout = TRUE)
if(fft==0){
@@ -310,12 +317,12 @@
# make compatible for both v6.4 and 7
if(grassversion==7){
- system(paste("r.mask raster=", vtl, sep=""))
+ execGRASS("r.mask", raster=vtl)
}else{
- system(paste("r.mask input=", vtl, sep=""))
+ execGRASS("r.mask", input=vtl)
- system(paste("r.out.xyz input=", ipl[i], " output=", flnm1, " --overwrite", sep=""))
+ execGRASS("r.out.xyz", input=ipl[i], output=flnm1, flags="overwrite")
system(paste("awk -F \"|\" '{print $3}' ", flnm1, " > ", flnm2, sep=""))
spld <- scan(file=flnm2)
#unlink(c(flnm1, flnm2))
@@ -325,7 +332,7 @@
a <- table(spld)
envmin <- min(spld)
envmax <- max(spld)
- Drange <- system(paste("r.info -r --verbose map=", ipl[i], sep=""), intern=T)
+ Drange <- execGRASS("r.info", flags=c("r", "verbose"), map=ipl[i], intern=T)
Dmin <- as.numeric(sub("min=", "", Drange[1]))
Dmax <- as.numeric(sub("max=", "", Drange[2]))
system("g.remove -f rast=MASK")
@@ -345,9 +352,10 @@
# Create the recode layer and calculate the IES
- system(paste("r.recode input=", ipl[i], " output=", tml[i], " rules=", tmp.rule, sep=""))
- system(paste("r.mapcalc '", opi[i], " = if(", tml[i], "==0, (float(", ipl[i], ")-", envmin, ")/(", envmax, "-", envmin, ") *100.0, if(", tml[i], "<=50, 2 * ", tml[i], ", if(", tml[i], "<100.0, 2 * (100.0- ", tml[i], "), (", envmax, "- float(", ipl[i], "))/(", envmax, "-", envmin, ") * 100.0)))'", sep=""))
- system(paste("g.remove rast=", tml[i], sep=""))
+ execGRASS("r.recode", input=ipl[i], output=tml[i], rules=tmp.rule)
+ calcc <- paste(opi[i], " = if(", tml[i], "==0, (round(", ipl[i], "/",digits,")-", round(envmin/digits), ")/(", round(envmax/digits), "-", round(envmin/digits), ") *100.0, if(", tml[i], "<=50, 2 * ", tml[i], ", if(", tml[i], "<100.0, 2 * (100.0- ", tml[i], "), (", round(envmax/digits), "- round(", ipl[i], "/", digits, "))/(", round(envmax/digits), "-", round(envmin/digits), ") * 100.0)))", sep="")
+ execGRASS("r.mapcalc", expression=calcc, flags="overwrite")
+ execGRASS("g.remove", rast=tml[i])
unlink(tmp.rule)
@@ -356,7 +364,7 @@
# Reference distribution layer is vector
- system(paste("v.extract -t input=", vtl, " type=point output=tmpMESS976543210", sep=""))
+ execGRASS("v.extract", flags="t", input=vtl, type=point, output=tmpMESS976543210)
system(paste("v.db.addtable tmpMESS976543210 columns='", paste(ipn, " double precision", collapse=","), "'", sep=""))
@@ -402,9 +410,10 @@
write.table(xy2, file=tmp.rule, quote=F, row.names=F, col.names=F)
unlink(tmp.rule)
@@ -421,7 +430,8 @@
if(argus[6]==1){
system(paste("r.series output=", opc, "_MoD input=", paste(opi, collapse=","), " method=min_raster", sep=""))
- nuv <- cbind(seq(from=0, to=length(ipn)-1, by = 1), ipn)
+ nuvto <- length(ipn)-1
+ nuv <- cbind(seq(from=0, to=nuvto, by=1), ipn)
reclvar <- apply(nuv,1,function(x){paste(x[1],x[2], sep=":")})
tmpclas <- tempfile(pattern = "classification.rules.")
sink(tmpclas)
@@ -471,5 +481,3 @@
