[GRASS-SVN] r56144 - in grass/trunk/lib/python/pygrass: raster vector
svn_grass at osgeo.org
Mon May 6 06:58:55 PDT 2013
Author: zarch
Date: 2013-05-06 06:58:55 -0700 (Mon, 06 May 2013)
New Revision: 56144
grass/trunk/lib/python/pygrass/raster/abstract.py
grass/trunk/lib/python/pygrass/vector/abstract.py
Fix exist method of vector and raster classes and fix the with statement when try to open a map that does not exist
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py 2013-05-06 12:33:11 UTC (rev 56143)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py 2013-05-06 13:58:55 UTC (rev 56144)
@@ -188,8 +188,11 @@
self.info = Info(self.name, self.mapset)
def __enter__(self):
- self.open('r')
- return self
+ if self.exist():
+ self.open('r')
+ return self
+ else:
+ raise ValueError("Raster not found.")
def __exit__(self, exc_type, exc_value, traceback):
self.close()
@@ -303,8 +306,8 @@
if self.name:
if self.mapset == '':
mapset = functions.get_mapset_raster(self.name, self.mapset)
- self.mapset = mapset
- return True
+ self.mapset = mapset if mapset else ''
+ return True if mapset else False
return bool(functions.get_mapset_raster(self.name, self.mapset))
else:
return False
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2013-05-06 12:33:11 UTC (rev 56143)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2013-05-06 13:58:55 UTC (rev 56144)
@@ -91,8 +91,11 @@
self.layer = layer
- self.open('r')
- return self
+ if self.exist():
+ self.open('r')
+ return self
+ else:
+ raise ValueError('Vector not found.')
self.close()
@@ -263,14 +266,14 @@
def exist(self):
"""Return if the Vector exists or not"""
- if self._name:
- self.mapset = functions.get_mapset_vector(self._name, self.mapset)
+ if self.name:
+ if self.mapset == '':
+ mapset = functions.get_mapset_vector(self.name, self.mapset)
+ return bool(functions.get_mapset_vector(self.name, self.mapset))
else:
return False
- if self.mapset:
- return True
- else:
- return False
def is_open(self):
"""Return if the Vector is open"""
