[GRASS-SVN] r56162 - grass/trunk/gui/wxpython/location_wizard
svn_grass at osgeo.org
Wed May 8 04:29:01 PDT 2013
Author: hamish
Date: 2013-05-08 04:29:01 -0700 (Wed, 08 May 2013)
New Revision: 56162
grass/trunk/gui/wxpython/location_wizard/wizard.py
fix for traceback when specifying by proj4 terms (#1849) and when ellipsoid is used instead of datum (#1967), merge from devbr6
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2013-05-08 11:05:01 UTC (rev 56161)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2013-05-08 11:29:01 UTC (rev 56162)
@@ -21,14 +21,15 @@
- wizard::LocationWizard
- wizard::WizardWithHelpButton
-(C) 2007-2012 by the GRASS Development Team
+(C) 2007-2013 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@author Michael Barton
@author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
+ at author Hamish Bowman (planetary ellipsoids)
import os
import locale
@@ -746,7 +747,7 @@
paramSBSizer.Fit(self.panel)
self.panel.SetSizer(self.prjParamSizer)
- if event.GetDirection():
+ if event.GetDirection():
self.prjParamSizer.Clear(True)
self.paramSBox.SetLabel(_(" Enter parameters for %s projection ") % self.projdesc)
self.pparam = dict()
@@ -761,7 +762,7 @@
# default values
if param['type'] == 'bool':
param['value'] = 0
- elif param['type'] == 'zone':
+ elif param['type'] == 'zone':
param['value'] = 30
param['desc'] += ' (1-60)'
else:
@@ -1081,6 +1082,8 @@
and self.ellipse not in self.parent.planetary_ellipsoids:
event.Veto()
+ #print self.ellipse, self.ellipsedesc, self.ellipseparams
self.proj4params = ''
self.GetNext().SetPrev(self)
self.parent.datumpage.datumparams = ''
@@ -1106,6 +1109,7 @@
self.ellipsedesc = self.parent.planetary_ellipsoids[self.ellipse][0]
self.ellipseparams = self.parent.planetary_ellipsoids[self.ellipse][1]
nextButton.Enable(True)
def OnSearch(self, event):
"""!Search ellipsoid by desc"""
@@ -1386,7 +1390,7 @@
if not self.epsgcode:
event.Veto()
return
- else:
+ else:
# check for datum transforms
ret = RunCommand('g.proj',
read = True,
@@ -1441,7 +1445,7 @@
self.tcode.SetValue('')
self.searchb.SetValue('')
self.OnBrowseCodes(None)
- else:
+ else:
try:
self.epsgcode, self.epsgdesc, self.epsgparams = \
self.epsglist.Search(index=[0,1,2], pattern=value)
@@ -1559,7 +1563,7 @@
if dlg.ShowModal() == wx.ID_OK:
dtrans = dlg.GetTransform()
- if len(dtrans) == 0:
+ if dtrans == '':
dlg.Destroy()
event.Veto()
return _('Datum transform is required.')
@@ -1674,18 +1678,23 @@
epsgcode = self.parent.epsgpage.epsgcode
datum = self.parent.datumpage.datum
dtrans = self.parent.datum_trans
global coordsys
+ #print coordsys,proj4string
if coordsys in ('proj', 'epsg'):
if coordsys == 'proj':
+ addl_opts = {}
+ if len(datum) > 0:
+ addl_opts['datum'] = '%s' % datum
+ addl_opts['datumtrans'] = dtrans
ret, projlabel, err = RunCommand('g.proj',
flags = 'jf',
proj4 = proj4string,
- datum = datum,
- datum_trans = dtrans,
location = location,
getErrorMsg = True,
- read = True)
+ read = True,
+ **addl_opts)
elif coordsys == 'epsg':
flags = 'jf',
@@ -1709,6 +1718,7 @@
projdesc = self.parent.projpage.projdesc
ellipsedesc = self.parent.ellipsepage.ellipsedesc
datumdesc = self.parent.datumpage.datumdesc
+ #print projdesc,ellipsedesc,datumdesc
self.ldatabase.SetLabel(database)
self.llocation.SetLabel(location)
self.llocTitle.SetLabel(self.parent.startpage.locTitle)
@@ -1865,7 +1875,7 @@
self.grassdatabase = self.startpage.grassdatabase
self.georeffile = self.filepage.georeffile
# FIXME here was code for setting default region, what for is this if:
- # if self.altdb == False:
+ # if self.altdb == False:
else: # -> error
self.wizard.Destroy()
