[GRASS-SVN] r56173 - grass/branches/develbranch_6/gui/wxpython/location_wizard
svn_grass at osgeo.org
Thu May 9 05:50:57 PDT 2013
Author: hamish
Date: 2013-05-09 05:50:56 -0700 (Thu, 09 May 2013)
New Revision: 56173
grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
slight return; pass through datum transform opt (if applicable) for custom proj4 string method
Modified: grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
--- grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py 2013-05-09 11:34:08 UTC (rev 56172)
+++ grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py 2013-05-09 12:50:56 UTC (rev 56173)
@@ -1496,39 +1496,54 @@
def OnPageChanging(self, event):
if event.GetDirection():
- if self.customstring.find('+datum=') >= 0:
- # check for datum tranforms
- # FIXME: -t flag is a hack-around for trac bug #1849
- ret, out, err = RunCommand('g.proj',
- read = True, getErrorMsg = True,
- proj4 = self.customstring,
- datumtrans = '-1',
- flags = 't')
- if ret != 0:
- wx.MessageBox(parent = self,
- message = err,
- caption = _("Error"),
- style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
- event.Veto()
- return
- if out:
- dtrans = ''
- # open a dialog to select datum transform number
- dlg = SelectTransformDialog(self.parent.parent, transforms = out)
- if dlg.ShowModal() == wx.ID_OK:
- dtrans = dlg.GetTransform()
- if dtrans == '':
- dlg.Destroy()
- event.Veto()
- return _('Datum transform is required.')
- else:
+ if self.customstring.find('+datum=') < 0:
+ self.GetNext().SetPrev(self)
+ return
+ # check for datum tranforms
+ # FIXME: -t flag is a hack-around for trac bug #1849
+ print "...here3 [%s]\n" % self.customstring
+ ret, out, err = RunCommand('g.proj',
+ read = True, getErrorMsg = True,
+ proj4 = self.customstring,
+ datumtrans = '-1',
+ flags = 't')
+ if ret != 0:
+ wx.MessageBox(parent = self,
+ message = err,
+ caption = _("Error"),
+ style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ event.Veto()
+ return
+ if out:
+ dtrans = ''
+ # open a dialog to select datum transform number
+ dlg = SelectTransformDialog(self.parent.parent, transforms = out)
+ if dlg.ShowModal() == wx.ID_OK:
+ dtrans = dlg.GetTransform()
+ if dtrans == '':
dlg.Destroy()
event.Veto()
- self.parent.datumtrans = dtrans
+ else:
+ dlg.Destroy()
+ event.Veto()
+ return _('Datum transform is required.')
+ self.parent.datumtrans = dtrans
+# TODO: add +nadgrids or +towgs84 terms to Summary page.
+# first get them:
+# ret, projlabel, err = RunCommand('g.proj',
+# flags = 'jf',
+# proj4 = self.customstring,
+# datumtrans = dtrans,
+# getErrorMsg = True,
+# read = True)
+# print "... [%s]\n" % projlabel
+# self.customstring = projlabel
+# possibly a better way to do it: split() the result, pick out str.find(+nad,+towgs) and
+# manually add them as + a second string to the list in the print.
@@ -1993,10 +2008,15 @@
datumtrans = self.datumtrans,
desc = self.startpage.locTitle)
elif coordsys == 'custom':
+ addl_opts = {}
+ if self.datumtrans is not None:
+ addl_opts['datumtrans'] = self.datumtrans
grass.create_location(dbase = self.startpage.grassdatabase,
location = self.startpage.location,
proj4 = self.custompage.customstring,
- desc = self.startpage.locTitle)
+ desc = self.startpage.locTitle,
+ **addl_opts)
elif coordsys == "epsg":
if not self.epsgpage.epsgcode:
return _('EPSG code missing.')
@@ -2047,12 +2067,12 @@
ellipse = self.ellipsepage.ellipse
ellipsedesc = self.ellipsepage.ellipsedesc
ellipseparams = self.ellipsepage.ellipseparams
# creating PROJ.4 string
proj4string = '%s %s' % (proj, proj4params)
# set ellipsoid parameters
if ellipse != '':
proj4string = '%s +ellps=%s' % (proj4string, ellipse)
@@ -2062,14 +2082,14 @@
else:
item = ' +' + item
proj4string = '%s %s' % (proj4string, item)
# set datum transform parameters if relevant
if datumparams:
for item in datumparams:
proj4string = '%s +%s' % (proj4string,item)
proj4string = '%s +no_defs' % proj4string
return proj4string
def OnHelp(self, event):
