[GRASS-SVN] r56185 - grass/trunk/raster/r.drain
svn_grass at osgeo.org
Fri May 10 04:22:56 PDT 2013
Author: huhabla
Date: 2013-05-10 04:22:56 -0700 (Fri, 10 May 2013)
New Revision: 56185
grass/trunk/raster/r.drain/filldir.c
grass/trunk/raster/r.drain/main.c
Dynamic memory allocation for start points. Fixed possible segfault.
Modified: grass/trunk/raster/r.drain/filldir.c
--- grass/trunk/raster/r.drain/filldir.c 2013-05-10 09:50:16 UTC (rev 56184)
+++ grass/trunk/raster/r.drain/filldir.c 2013-05-10 11:22:56 UTC (rev 56185)
@@ -120,7 +120,7 @@
G_percent(1, 1, 1);
advance_band3(fe, bnd);
- build_one_row(i, nl, bnd->ns, bnd, dir, m[i]);
+ build_one_row(nl - 1, nl, bnd->ns, bnd, dir, m[nl - 1]);
write(fd, dir, bufsz);
G_free(dir);
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2013-05-10 09:50:16 UTC (rev 56184)
+++ grass/trunk/raster/r.drain/main.c 2013-05-10 11:22:56 UTC (rev 56185)
@@ -50,7 +50,7 @@
#include "local.h"
/* should probably be updated to a pointer array & malloc/realloc as needed */
-#define MAX_POINTS 1024
+#define POINTS_INCREMENT 1024
/* define a data structure to hold the point data */
struct point
@@ -67,7 +67,9 @@
int fe, fd, dir_fd;
int i, have_points = 0;
int new_id;
- int nrows, ncols, points_row[MAX_POINTS], points_col[MAX_POINTS], npoints;
+ int nrows, ncols;
+ int *points_row = NULL, *points_col = NULL, npoints;
+ int increment_count;
int cell_open(), cell_open_new();
int map_id, dir_id;
char map_name[GNAME_MAX], new_map_name[GNAME_MAX], dir_name[GNAME_MAX];
@@ -220,10 +222,11 @@
ncols = Rast_window_cols();
/* calculate true cell resolution */
- m = (struct metrics *)G_malloc(nrows * sizeof(struct metrics));
- if (m == NULL)
- G_fatal_error(_("Metrics allocation"));
+ m = (struct metrics *)G_malloc(nrows * sizeof(struct metrics));
+ points_row = (int*)G_calloc(POINTS_INCREMENT, sizeof(int));
+ points_col = (int*)G_calloc(POINTS_INCREMENT, sizeof(int));
+ increment_count = 1;
npoints = 0;
if (coordopt->answer) {
for (i = 0; coordopt->answers[i] != NULL; i += 2) {
@@ -241,8 +244,12 @@
points_row[npoints] = start_row;
points_col[npoints] = start_col;
npoints++;
- if (npoints >= MAX_POINTS)
- G_fatal_error(_("Too many start points"));
+ if (npoints == POINTS_INCREMENT * increment_count)
+ increment_count++;
+ points_row = (int*)G_realloc(points_row, POINTS_INCREMENT * increment_count * sizeof(int));
+ points_col = (int*)G_realloc(points_col, POINTS_INCREMENT * increment_count * sizeof(int));
have_points = 1;
@@ -293,8 +300,12 @@
npoints++;
have_points = 1;
Vect_close(&In);
@@ -572,6 +583,10 @@
unlink(tempfile2);
G_free(in_buf);
G_free(out_buf);
+ if(points_row)
+ G_free(points_row);
+ if(points_col)
+ G_free(points_col);
if (costmode == 1) {
close(dir_fd);
