[GRASS-SVN] r56214 - grass/branches/develbranch_6/scripts/r.in.wms
Sun May 12 05:00:26 PDT 2013
Author: hamish
Date: 2013-05-12 05:00:26 -0700 (Sun, 12 May 2013)
New Revision: 56214
   grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
   grass/branches/develbranch_6/scripts/r.in.wms/wms.download
rewrite eval loop to be safe for spaces in path names; minor indent sanitation
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms	2013-05-12 11:40:23 UTC (rev 56213)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms	2013-05-12 12:00:26 UTC (rev 56214)
@@ -458,9 +458,9 @@
 #### Exit if there is no map
 # It would be a good idea to test if the map already exists here too
-if [ -z "${GIS_OPT_OUTPUT}" ] ; then
-	g.message -e "No output map specified"
-	exit 1;
+if [ -z "$GIS_OPT_OUTPUT" ] ; then
+    g.message -e "No output map specified"
+    exit 1
 fi
 REQUEST=""
@@ -530,20 +530,23 @@
 # Job 2: make list of files
-CONTENTS=`cat "$REQUESTFILE"`
 FILES=""
 COUNT=0
-for line in $CONTENTS ; do
-	eval "$line"
-	if [ $COUNT -eq 0 ] ; then
-		FILES="$OUTPUT_FILE"
-	else
-		FILES="$FILES,$OUTPUT_FILE"
-	fi
-	COUNT=`expr $COUNT + 1`
-done
+while read line ; do
+    if [ -z "$line" ] ; then
+	continue
+    fi
+    eval "$line"
+    if [ "$COUNT" -eq 0 ] ; then
+	FILES="$OUTPUT_FILE"
+    else
+	FILES="$FILES,$OUTPUT_FILE"
+    fi
+    COUNT=`expr "$COUNT" + 1`
+done < "$REQUESTFILE"
 addflag GDALWARP c 1
 addflag GDALWARP k "$GIS_FLAG_K"
 addflag GDALWARP p "$GIS_FLAG_P"
Modified: grass/branches/develbranch_6/scripts/r.in.wms/wms.download
--- grass/branches/develbranch_6/scripts/r.in.wms/wms.download	2013-05-12 11:40:23 UTC (rev 56213)
+++ grass/branches/develbranch_6/scripts/r.in.wms/wms.download	2013-05-12 12:00:26 UTC (rev 56214)
@@ -91,9 +91,9 @@
 exitprocedure()
-	g.message -e 'User break!'
-	rm -f "$TEMPFILE"*
-	exit 1
+    g.message -e 'User break!'
+    rm -f "$TEMPFILE"*
+    exit 1
 trap "exitprocedure" 2 3 15
@@ -114,20 +114,23 @@
 # Download the tiles!!
 GetTiles() {
-  g.message "Downloading tiles"
+    g.message "Downloading tiles"
-  # init POST-data vs. GET URL method variable
-  if [ "$GIS_FLAG_G" -eq 0 ] ; then
-     POST_DATA_OK=1
-  else
-     POST_DATA_OK=0
-  fi
+    # init POST-data vs. GET URL method variable
+    if [ "$GIS_FLAG_G" -eq 0 ] ; then
+	POST_DATA_OK=1
+    else
+	POST_DATA_OK=0
+    fi
-  CONTENTS=`cat "$REQUESTFILE"`
+    NUMBER_OF_TILES=0
-  NUMBER_OF_TILES=0
-  for line in $CONTENTS ; do
+    while read line ; do
 	g.message -d message="wget command: [$line]" debug=2
+	    continue
+	fi
 	eval "$line"
 	emptyness=`file "$OUTPUT_FILE" | grep empty$`
@@ -137,18 +140,18 @@
 	else
 	   GetData
 	   if [ $? -ne 0 ] ; then
-              NUMBER_OF_TILES=`expr $NUMBER_OF_TILES + 1`
+		NUMBER_OF_TILES=`expr $NUMBER_OF_TILES + 1`
            fi
 	fi
-  done
+    done < "$REQUESTFILE"
-  if [ $NUMBER_OF_TILES -ne 0 ] ; then
-    g.message -w "$NUMBER_OF_TILES failed to download"
-    return 1
-  else
-    g.message "All tiles downloaded successfully"
-    return 0
-  fi
+    if [ "$NUMBER_OF_TILES" -ne 0 ] ; then
+	g.message -w "$NUMBER_OF_TILES tiles failed to download"
+	return 1
+    else
+	g.message "All tiles downloaded successfully"
+	return 0
+    fi
