[GRASS-SVN] r56236 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Mon May 13 03:35:03 PDT 2013
Author: mmetz
Date: 2013-05-13 03:35:02 -0700 (Mon, 13 May 2013)
New Revision: 56236
grass/trunk/lib/vector/diglib/linecros.c
diglib: fix find intersection
Modified: grass/trunk/lib/vector/diglib/linecros.c
--- grass/trunk/lib/vector/diglib/linecros.c 2013-05-13 10:29:46 UTC (rev 56235)
+++ grass/trunk/lib/vector/diglib/linecros.c 2013-05-13 10:35:02 UTC (rev 56236)
@@ -137,6 +137,26 @@
register double d, r1, r2;
double t;
+ if (ax1 > ax2 || (ax1 == ax2 && ay1 > ay2)) {
+ t = ax1;
+ ax1 = ax2;
+ ax2 = t;
+ t = ay1;
+ ay1 = ay2;
+ ay2 = t;
+ if (bx1 > bx2 || (bx1 == bx2 && by1 > by2)) {
+ t = bx1;
+ bx1 = bx2;
+ bx2 = t;
+ t = by1;
+ by1 = by2;
+ by2 = t;
d = D;
if (d) {
@@ -160,16 +180,6 @@
/* Collinear vertical */
if (ax1 == ax2) {
- if (ay1 > ay2) {
- t = ay1;
- ay1 = ay2;
- ay2 = t;
- if (by1 > by2) {
- t = by1;
- by1 = by2;
- by2 = t;
if (ay1 > by2)
return 0;
if (ay2 < by1)
@@ -200,26 +210,6 @@
return -1;
else {
- if (ax1 > ax2) {
- /* need to swap both coords */
- t = ax1;
- ax1 = ax2;
- ax2 = t;
- t = ay1;
- ay1 = ay2;
- ay2 = t;
- if (bx1 > bx2) {
- t = bx1;
- bx1 = bx2;
- bx2 = t;
- t = by1;
- by1 = by2;
- by2 = t;
if (ax1 > bx2)
return 0;
if (ax2 < bx1)
