[GRASS-SVN] r56245 - in grass-addons/grass7/raster/r.fuzzy: r.fuzzy.logic r.fuzzy.set r.fuzzy.system
svn_grass at osgeo.org
Mon May 13 18:27:21 PDT 2013
Author: hamish
Date: 2013-05-13 18:27:21 -0700 (Mon, 13 May 2013)
New Revision: 56245
grass-addons/grass7/raster/r.fuzzy/r.fuzzy.logic/main.c
grass-addons/grass7/raster/r.fuzzy/r.fuzzy.set/main.c
grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/main.c
module definition fixes
Modified: grass-addons/grass7/raster/r.fuzzy/r.fuzzy.logic/main.c
--- grass-addons/grass7/raster/r.fuzzy/r.fuzzy.logic/main.c 2013-05-14 01:20:44 UTC (rev 56244)
+++ grass-addons/grass7/raster/r.fuzzy/r.fuzzy.logic/main.c 2013-05-14 01:27:21 UTC (rev 56245)
@@ -44,8 +44,11 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("raster, fuzzy logic");
- module->description = _("xxxx");
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("fuzzy logic"));
+ module->description =
+ _("Performs logical operations on membership images created with "
+ "r.fuzzy or different method. Use families for fuzzy logic.");
par_inputx = G_define_standard_option(G_OPT_R_INPUT);
par_inputx->description = _("x operand (membership map)");
Modified: grass-addons/grass7/raster/r.fuzzy/r.fuzzy.set/main.c
--- grass-addons/grass7/raster/r.fuzzy/r.fuzzy.set/main.c 2013-05-14 01:20:44 UTC (rev 56244)
+++ grass-addons/grass7/raster/r.fuzzy/r.fuzzy.set/main.c 2013-05-14 01:27:21 UTC (rev 56245)
@@ -45,6 +45,12 @@
G_gisinit(argv[0]);
+ module = G_define_module();
+ module->description = _("Calculate membership value of any "
+ "raster map according user's rules.");
par_input = G_define_standard_option(G_OPT_R_INPUT);
par_input->description = _("Raster map to be fuzzified");
Modified: grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/main.c
--- grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/main.c 2013-05-14 01:20:44 UTC (rev 56244)
+++ grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/main.c 2013-05-14 01:27:21 UTC (rev 56245)
@@ -59,8 +59,11 @@
G_gisinit(argv[0]);
+ _("Full fuzzy logic standalone classification system with few fuzzy "
+ "logic families implication and defuzzification and methods.");
file_vars = G_define_standard_option(G_OPT_F_INPUT);
file_vars->key = "maps";
