[GRASS-SVN] r56253 - in grass/branches/releasebranch_6_4: gui/wxpython/location_wizard lib/python
svn_grass at osgeo.org
Tue May 14 17:26:34 PDT 2013
Author: hamish
Date: 2013-05-14 17:26:34 -0700 (Tue, 14 May 2013)
New Revision: 56253
grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py
grass/branches/releasebranch_6_4/lib/python/core.py
datum and datum transform fixes needed for proj 4.8.0 (#1849, backport from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py
--- grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py 2013-05-14 14:44:32 UTC (rev 56252)
+++ grass/branches/releasebranch_6_4/gui/wxpython/location_wizard/wizard.py 2013-05-15 00:26:34 UTC (rev 56253)
@@ -21,7 +21,7 @@
- wizard::LocationWizard
- wizard::WizardWithHelpButton
-(C) 2007-2011 by the GRASS Development Team
+(C) 2007-2013 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -891,7 +891,7 @@
def OnPageChanging(self, event):
self.proj4params = ''
proj = self.parent.projpage.p4proj
if event.GetDirection():
if self.datum not in self.parent.datums:
event.Veto()
@@ -902,7 +902,8 @@
read = True,
proj4 = '%s' % proj,
datum = '%s' % self.datum,
- datumtrans = '-1')
+ datumtrans = '-1',
+ flags = 't')
# wx.Messagebox('here')
if ret != '':
dtrans = ''
@@ -993,7 +994,7 @@
TitledPage.__init__(self, wizard, _("Specify ellipsoid"))
self.parent = parent
self.ellipse = ''
self.ellipsedesc = ''
self.ellipseparams = ''
@@ -1341,12 +1342,13 @@
if not self.epsgcode:
event.Veto()
return
- else:
+ else:
# check for datum transforms
ret = RunCommand('g.proj',
read = True,
epsg = self.epsgcode,
+ flags = 't')
if ret != '':
dtrans = ''
@@ -1494,11 +1496,19 @@
- # check for datum tranforms
+ self.custom_dtrans_string = ''
+ if self.customstring.find('+datum=') < 0:
+ self.GetNext().SetPrev(self)
+ return
+ # check for datum tranforms
+ # FIXME: -t flag is a hack-around for trac bug #1849
ret, out, err = RunCommand('g.proj',
read = True, getErrorMsg = True,
proj4 = self.customstring,
+ flags = 't')
if ret != 0:
wx.MessageBox(parent = self,
message = err,
@@ -1506,15 +1516,14 @@
style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
event.Veto()
return
if out:
dtrans = ''
# open a dialog to select datum transform number
dlg = SelectTransformDialog(self.parent.parent, transforms = out)
if dlg.ShowModal() == wx.ID_OK:
dtrans = dlg.GetTransform()
- if len(dtrans) == 0:
+ if dtrans == '':
dlg.Destroy()
event.Veto()
return _('Datum transform is required.')
@@ -1522,9 +1531,22 @@
dlg.Destroy()
event.Veto()
self.parent.datumtrans = dtrans
+ # prepare +nadgrids or +towgs84 terms for Summary page. first convert them:
+ ret, projlabel, err = RunCommand('g.proj',
+ flags = 'jft',
+ proj4 = self.customstring,
+ datumtrans = dtrans,
+ getErrorMsg = True,
+ read = True)
+ # splitting on space alone would break for grid files with space in pathname
+ for projterm in projlabel.split(' +'):
+ if projterm.find("towgs84=") != -1 or projterm.find("nadgrids=") != -1:
+ self.custom_dtrans_string = ' +%s' % projterm
+ break
def GetProjstring(self, event):
@@ -1633,17 +1655,21 @@
global coordsys
if coordsys in ('proj', 'epsg'):
if coordsys == 'proj':
+ addl_opts = {}
+ if len(datum) > 0:
+ addl_opts['datum'] = '%s' % datum
+ addl_opts['datumtrans'] = dtrans
flags = 'jf',
proj4 = proj4string,
- datum = datum,
- datumtrans = dtrans,
location = location,
getErrorMsg = True,
- read = True)
+ read = True,
+ **addl_opts)
elif coordsys == 'epsg':
- flags = 'jf',
+ flags = 'jft',
epsg = epsgcode,
@@ -1653,8 +1679,8 @@
finishButton = wx.FindWindowById(wx.ID_FORWARD)
if ret == 0:
if datum != '':
- projlabel = projlabel + ' ' + 'datum=%s' % datum
- self.lproj4string.SetLabel(projlabel.replace(' ', os.linesep))
+ projlabel = projlabel + '+datum=%s' % datum
+ self.lproj4string.SetLabel(projlabel.replace(' +', os.linesep + '+'))
finishButton.Enable(True)
else:
GError(err, parent = self)
@@ -1684,7 +1710,8 @@
self.lproj4string.SetLabel("")
elif coordsys == 'custom':
label = _("custom")
- self.lproj4string.SetLabel(('%s' % self.parent.custompage.customstring.replace(' ', os.linesep)))
+ combo_str = self.parent.custompage.customstring + self.parent.custompage.custom_dtrans_string
+ self.lproj4string.SetLabel(('%s' % combo_str.replace(' +', os.linesep + '+')))
self.lprojection.SetLabel(label)
def OnFinish(self, event):
@@ -1984,10 +2011,15 @@
datumtrans = self.datumtrans,
desc = self.startpage.locTitle)
+ addl_opts = {}
+ if self.datumtrans is not None:
+ addl_opts['datumtrans'] = self.datumtrans
grass.create_location(dbase = self.startpage.grassdatabase,
location = self.startpage.location,
proj4 = self.custompage.customstring,
- desc = self.startpage.locTitle)
+ desc = self.startpage.locTitle,
+ **addl_opts)
elif coordsys == "epsg":
if not self.epsgpage.epsgcode:
return _('EPSG code missing.')
@@ -2038,12 +2070,12 @@
ellipse = self.ellipsepage.ellipse
ellipsedesc = self.ellipsepage.ellipsedesc
ellipseparams = self.ellipsepage.ellipseparams
# creating PROJ.4 string
proj4string = '%s %s' % (proj, proj4params)
# set ellipsoid parameters
if ellipse != '':
proj4string = '%s +ellps=%s' % (proj4string, ellipse)
@@ -2053,14 +2085,14 @@
else:
item = ' +' + item
proj4string = '%s %s' % (proj4string, item)
# set datum transform parameters if relevant
if datumparams:
for item in datumparams:
proj4string = '%s +%s' % (proj4string,item)
proj4string = '%s +no_defs' % proj4string
return proj4string
def OnHelp(self, event):
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2013-05-14 14:44:32 UTC (rev 56252)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2013-05-15 00:26:34 UTC (rev 56253)
@@ -1070,6 +1070,7 @@
gisdbase = None
if epsg or proj4 or filename or wkt:
gisdbase = gisenv()['GISDBASE']
+ # FIXME: changing GISDBASE mid-session is not background-job safe
run_command('g.gisenv',
set = 'GISDBASE=%s' % dbase)
if not os.path.exists(dbase):
@@ -1084,6 +1085,7 @@
if epsg:
ps = pipe_command('g.proj',
quiet = True,
+ flags = 't',
epsg = epsg,
stderr = PIPE,
@@ -1091,6 +1093,7 @@
elif proj4:
quiet = True,
+ flags = 't',
proj4 = proj4,
stderr = PIPE,
