[GRASS-SVN] r56260 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Wed May 15 05:45:09 PDT 2013
Author: jradinger
Date: 2013-05-15 05:45:08 -0700 (Wed, 15 May 2013)
New Revision: 56260
grass-addons/grass7/raster/r.fidimo/r.fidimo.html
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
changed the term permeability to passability
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.html
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.html 2013-05-15 11:06:59 UTC (rev 56259)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.html 2013-05-15 12:45:08 UTC (rev 56260)
@@ -33,9 +33,9 @@
<dl>
<dt><b>barriers</b></dt>
<dd>Name of input barrier text-file indicating the geographical position
-and permeabilty of barriers e.g. weirs. The file should contain the
-X and Y coordinate and a value for permeability (0-1 where 0 is
-non-permeable and 1 is 100% passable). The values must be |-separated:
+and passability of barriers e.g. weirs. The file should contain the
+X and Y coordinate and a value for passability (0-1 where 0 is
+impassable and 1 is 100% passable). The values must be |-separated:
</dd>
</dl>
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-05-15 11:06:59 UTC (rev 56259)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-05-15 12:45:08 UTC (rev 56260)
@@ -41,12 +41,12 @@
#% guisection: Stream parameters
#%end
#%option
-#% key: permeability_col
+#% key: passability_col
#% type: string
#% required: no
#% multiple: no
#% key_desc: name
-#% description: Column name indicating permeability value (0-1) of barrier
+#% description: Column name indicating passability value (0-1) of barrier
#%End
#%Flag
@@ -221,12 +221,12 @@
# check if barrier file exists in current mapset (Problem when file in other mapset!!!!)
if not grass.find_file(name = input_barriers, element = 'vector')['file']:
grass.fatal(_("Barriers map not found in current mapset"))
- # check if permeability_col is provided and existing
- if not options['permeability_col']:
- grass.fatal(_("Please provide column name that holds the barriers' permeability values ('permeability_col')"))
- if not options['permeability_col'] in grass.read_command("db.columns", table=input_barriers).split('\n'):
- grass.fatal(_("Please provide correct column name that holds the barriers' permeability values ('permeability_col')"))
- permeability_col = options['permeability_col']
+ # check if passability_col is provided and existing
+ if not options['passability_col']:
+ grass.fatal(_("Please provide column name that holds the barriers' passability values ('passability_col')"))
+ if not options['passability_col'] in grass.read_command("db.columns", table=input_barriers).split('\n'):
+ grass.fatal(_("Please provide correct column name that holds the barriers' passability values ('passability_col')"))
+ passability_col = options['passability_col']
@@ -740,7 +740,7 @@
# Loop over the affected barriers (from most downstream barrier to most upstream barrier)
# Initally affected = all barriers where density > 0
- barriers_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, new_X, new_Y, dist, %s FROM barriers_%d WHERE dist > 0 ORDER BY dist" % (permeability_col,os.getpid())).split("\n")[:-1] # remove last (empty line)
+ barriers_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, new_X, new_Y, dist, %s FROM barriers_%d WHERE dist > 0 ORDER BY dist" % (passability_col,os.getpid())).split("\n")[:-1] # remove last (empty line)
barriers_list = list(csv.reader(barriers_list,delimiter="|"))
#if affected barriers then define the last loop (find the upstream most barrier)
@@ -753,7 +753,7 @@
new_X = float(l[1])
new_Y = float(l[2])
dist = float(l[3])
- permeability = float(l[4])
+ passability = float(l[4])
coors_barriers = str(new_X)+","+str(new_Y)
grass.debug(_("Starting with calculating barriers-effect (coors_barriers: "+coors_barriers+")"))
@@ -783,7 +783,7 @@
grass.fatal(_("Error with upstream density/barriers. The error occurs for coors_barriers (X,Y): "+coors_barriers))
- density_for_downstream = sum_upstream_barrier_density*(1-permeability)
+ density_for_downstream = sum_upstream_barrier_density*(1-passability)
# barrier_effect = Length of Effect of barriers (linear decrease up to max (barrier_effect)
@@ -829,12 +829,12 @@
grass.run_command("r.null", map="density_"+str(cat), null="0")
grass.run_command("r.null", map="downstream_barrier_density_tmp_%d" % os.getpid(), null="0")
- grass.mapcalc("$density_point = if(isnull($upstream_barrier), $downstream_barrier_density+$density_point, $upstream_barrier_density*$permeability)",
+ grass.mapcalc("$density_point = if(isnull($upstream_barrier), $downstream_barrier_density+$density_point, $upstream_barrier_density*$passability)",
density_point = "density_"+str(cat),
upstream_barrier = "upstream_barrier_tmp_%d" % os.getpid(),
downstream_barrier_density = "downstream_barrier_density_tmp_%d" % os.getpid(),
upstream_barrier_density = "upstream_barrier_density_tmp_%d" % os.getpid(),
- permeability=permeability,
+ passability=passability,
overwrite = True)
if dist == last_barrier :
@@ -842,9 +842,9 @@
else:
grass.run_command("r.null", map="density_"+str(cat), setnull="0")
- #If the barrier in the loop was impermeable (permeability=0)
+ #If the barrier in the loop was impermeable (passability=0)
#than no more upstream barriers need to be considered --> break
- if permeability == 0:
+ if passability == 0:
break
