[GRASS-SVN] r56265 - in grass-addons/grass7/raster/r.agent: . libagent tests
Wed May 15 07:26:28 PDT 2013
Author: mic
Date: 2013-05-15 07:26:26 -0700 (Wed, 15 May 2013)
New Revision: 56265
   grass-addons/grass7/raster/r.agent/libagent/ant.py
   grass-addons/grass7/raster/r.agent/libagent/anthill.py
   grass-addons/grass7/raster/r.agent/libagent/world.py
   grass-addons/grass7/raster/r.agent/r.agent.aco
   grass-addons/grass7/raster/r.agent/tests/test_ant.py
   grass-addons/grass7/raster/r.agent/tests/test_anthill.py
move inner loop to world and add ant work
Modified: grass-addons/grass7/raster/r.agent/libagent/ant.py
--- grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-15 14:25:44 UTC (rev 56264)
+++ grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-15 14:26:26 UTC (rev 56265)
@@ -33,6 +33,13 @@
         self.goal = []
         self.penalty = 0.0
-    def walk(self):
+    def work(self):
+        Wander around searching for fields of interest, mark the
+        road back home.
+        @return boolean whether still alive
+        # we are all only getting older..
+        if self.age() == False:
+            return False
         pass
Modified: grass-addons/grass7/raster/r.agent/libagent/anthill.py
--- grass-addons/grass7/raster/r.agent/libagent/anthill.py	2013-05-15 14:25:44 UTC (rev 56264)
+++ grass-addons/grass7/raster/r.agent/libagent/anthill.py	2013-05-15 14:26:26 UTC (rev 56265)
@@ -11,6 +11,7 @@
 import error, world, ant
+#from grass.script import core as grass
 from sys import maxsize
 from math import sqrt
 from math import exp
@@ -73,6 +74,16 @@
 #TODO        self.decisionbase = "default"
 #TODO        self.rememberbase = "default"
+    def bear(self):
+        Set a new agent into the world
+        @param int number of cycles the agent has to live
+        @param list coordinates to put the agent on, none for a random position
+        @return agent the newly created agent
+        position = self.sites[randint(0, len(self.sites)-1)]
+        return super(Anthill, self).bear(self.antslife, position)
     def volatilize(self):
         Let the pheromone evaporate over time.
@@ -80,3 +91,21 @@
         self.playground.decaycellvalues(Anthill.RESULT, self.volatilizationtime,
                                             self.minpheromone)
+    def letantsdance(self, rounds):
+        Let the agents do their job. The actual main loop in such a world.
+        while rounds > 0:
+#            grass.info(rounds)
+            if len(self.agents) < self.maxants:
+#                grass.info(len(self.agents))
+                # as there is still space on the pg, produce another ant
+                self.bear()
+            for ant in self.agents:
+                # let all the ants take action
+                ant.work()
+            # let the pheromone evaporate
+            self.volatilize()
+            # count down
+            rounds -= 1
Modified: grass-addons/grass7/raster/r.agent/libagent/world.py
--- grass-addons/grass7/raster/r.agent/libagent/world.py	2013-05-15 14:25:44 UTC (rev 56264)
+++ grass-addons/grass7/raster/r.agent/libagent/world.py	2013-05-15 14:26:26 UTC (rev 56265)
@@ -88,7 +88,8 @@
-        @param list coordinates to put the agent or none for a random position
+        @param agenttype the typ of agent to be spawned
         position = self.findposition(position)
Modified: grass-addons/grass7/raster/r.agent/r.agent.aco
--- grass-addons/grass7/raster/r.agent/r.agent.aco	2013-05-15 14:25:44 UTC (rev 56264)
+++ grass-addons/grass7/raster/r.agent/r.agent.aco	2013-05-15 14:26:26 UTC (rev 56265)
@@ -273,27 +273,11 @@
         mainloops = 1
         nextwrite = rounds
     while mainloops > 0:
-        grass.info(mainloops)
+#        grass.info(mainloops)
         # loop and write out the contents at the end
-        loops = nextwrite
-        while loops > 0:
-            grass.info(loops)
-            # loop without producing output
-            if len(world.agents) < world.maxants:
-                grass.info(len(world.agents))
-                # as there is still space on the pg, produce another ant
-                # at a random site..
-                position = world.sites[randint(0, len(world.sites)-1)]
-                world.bear(world.antslife, position)
-            for ant in world.agents:
-                # let all the ants take action
-                ant.walk()
-            # let the pheromone evaporate
-            world.volatilize()
-            # count down inner
-            loops -= 1
+        world.letantsdance(nextwrite)
         # export the value maps
-        world.writeout()
+#        world.writeout()
 #        print "nrofpaths:", world.nrop
         # count down outer
         mainloops -= 1
Modified: grass-addons/grass7/raster/r.agent/tests/test_ant.py
--- grass-addons/grass7/raster/r.agent/tests/test_ant.py	2013-05-15 14:25:44 UTC (rev 56264)
+++ grass-addons/grass7/raster/r.agent/tests/test_ant.py	2013-05-15 14:26:26 UTC (rev 56265)
@@ -27,5 +27,8 @@
     def test_walk(self):
         pass
+    def test_work(self):
+        pass
 #    def tearDown(self):
Modified: grass-addons/grass7/raster/r.agent/tests/test_anthill.py
--- grass-addons/grass7/raster/r.agent/tests/test_anthill.py	2013-05-15 14:25:44 UTC (rev 56264)
+++ grass-addons/grass7/raster/r.agent/tests/test_anthill.py	2013-05-15 14:26:26 UTC (rev 56265)
@@ -25,7 +25,6 @@
         pass
     def test_bear(self):
-        # gets tested in World
         pass
     def test_move(self):
@@ -40,6 +39,9 @@
         pass
+    def test_letantsdance(self):
+        pass
         pass
