[GRASS-SVN] r56270 - grass-addons/grass7/raster/r.shalstab
svn_grass at osgeo.org
Wed May 15 15:14:26 PDT 2013
Author: kikapu
Date: 2013-05-15 15:14:25 -0700 (Wed, 15 May 2013)
New Revision: 56270
Removed:
grass-addons/grass7/raster/r.shalstab/r.shalstab.py
temporary remove
Deleted: grass-addons/grass7/raster/r.shalstab/r.shalstab.py
--- grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2013-05-15 21:33:30 UTC (rev 56269)
+++ grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2013-05-15 22:14:25 UTC (rev 56270)
@@ -1,187 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.shalstab
-# VERSION: 0.1 Beta
-# AUTHOR(S): Andrea Filipello & Daniele Strigaro
-# PURPOSE: A model based on the algorithm developet by Montgomery and Dietrich (1994)
-# COPYRIGHT: (C) 2013 by Andrea Filipello & Daniele Strigaro
-# andrea.filipello at gmail.com; daniele.strigaro at gmail.com
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: A model for shallow landslide susceptibility
-#% keywords: raster, critical rainfall, landslide
-#%end
-#%option
-#% key: dem
-#% type: string
-#% gisprompt: old,raster,raster
-#% key_desc: dem
-#% description: Name of dem
-#% required: yes
-#%end
-#%option
-#% key: phy
-#% type: string
-#% key_desc: phy
-#% description: Soil friction angle (angle)
-#% required: yes
-#%end
-#%option
-#% key: c_soil
-#% type: string
-#% key_desc: c_soil
-#% description: Soil cohesion (N/m^2)
-#% required: yes
-#%end
-#%option
-#% key: root
-#% type: string
-#% key_desc: root
-#% description: Root cohesion k (N/m^2)
-#% required: no
-#%end
-#%option
-#% key: gamma
-#% type: string
-#% key_desc: gamma
-#% description: Soil density(angle)
-#% required: yes
-#%end
-#%option
-#% key: z
-#% type: string
-#% key_desc: z
-#% description: Vertical thickness of soil (m),
-#% required: yes
-#%end
-#%option
-#% key: k
-#% type: string
-#% key_desc: k
-#% description: hydraulic conductivity (m/h)
-#% required: yes
-#%end
-#%option
-#% key: gamma_wet
-#% type: string
-#% key_desc: gamma_wet
-#% description: Wet soil density (kg/m^3); default: 2100
-#% required: no
-#%end
-# output
-#%option
-#% key: susceptibility
-#% type: string
-#% gisprompt: new,cell,raster
-#% key_desc: susceptibility
-#% description: Output: name of landslide susceptibility map (from 1 to 7)
-#% required : yes
-#%end
-#%option
-#% key: critic_rain
-#% type: string
-#% key_desc: critical rain
-#% description: Output: name of critical rainfall map (mm/day)
-#% required : yes
-#%END
-import sys
-import os
-try:
- import grass.script as grass
-except:
- try:
- from grass.script import core as grass
- except:
- sys.exit( "grass.script can't be imported.")
-if not os.environ.has_key("GISBASE"):
- print "You must be in GRASS GIS to run this program."
- sys.exit(1)
-def main():
- r_elevation = options['dem'].split('@')[0]
- mapname = options['dem'].replace("@"," ")
- mapname = mapname.split()
- mapname[0] = mapname[0].replace(".","_")
- c_soil = options['c_soil']
- phy = options['phy']
- gamma = options['gamma']
- gamma_wet = options['gamma_wet']
- z = options['z']
- #b = options['b']
- k = options['k']
- root = options['root']
- susceptibility = options['susceptibility']
- critic_rain = options['critic_rain']
- if root == '':
- root = 0
- if gamma_wet == '':
- gamma_wet = 2100
- #calcola slope
- # bash r.slope.aspect elevation=$dem slope=slopes --o format=degrees prec=float min_slp_allowed=0.0
- grass.run_command('r.slope.aspect', elevation = r_elevation, slope = 'slopes', min_slp_allowed = 0.0, overwrite = 'True') #format = 'degrees', precision = float,
- # Calcolo soil transmissivity T (m^2/day)
- # bash r.mapcalc "T=$k*24*$z*cos(slopes)"
- grass.mapcalc("T=$k*24*$z*cos(slopes)",
- k = k,
- z = z)
- # Calcolo coesione (dimensionless)
- #r.mapcalc "C=($root+$c_soil)/($z*cos(slopes)*9.81*$gamma_wet)"
- grass.mapcalc("C=($root+$c_soil)/($z*cos(slopes)*9.81*$gamma_wet)",
- root = root,
- c_soil = c_soil,
- z = z,
- gamma_wet = gamma_wet)
- # Calcolo contribution area
- # bash r.watershed -f elev=$dem accum=rwater.accum
- grass.run_command('r.watershed', elevation = r_elevation, accumulation = 'accum')
- # bash r.mapcalc "A=rwater.accum*((ewres()+nsres())/2)*((ewres()+nsres())/2)"
- grass.mapcalc("A=accum*((ewres()+nsres())/2)*((ewres()+nsres())/2)")
- # Calcolo 1(m/day)
- # basc r.mapcalc "i_crit_m=T*sin(slopes)*$b/A*($gamma/1000*(1-(1-C/(sin(slopes)*cos(slopes)))*tan(slopes)/tan($phy)))"
- grass.mapcalc("i_crit_m=T*sin(slopes)*((ewres()+nsres())/2)/A*($gamma/1000*(1-(1-C/(sin(slopes)*cos(slopes)))*tan(slopes)/tan($phy)))",
- phy = phy,
- gamma = gamma)
- # Calcolo pioggia critica (mm/ora) e riclassifico
- # bash r.mapcalc "i_cri_mm=i_crit_m*24000"
- grass.mapcalc("i_cri_mm=i_crit_m*24000")
- reclass_rules = "0 thru 50 = 0\n50 thru 100 = 3\n100 thru 200 = 4\n200 thru 400 = 5\n400 thru 999 = 6"
- grass.write_command('r.reclass', input = 'i_cri_mm', output = 'i_recl', overwrite = 'True', rules = '-', stdin = reclass_rules)
- grass.mapcalc("copia_reclass=i_recl+0")
- grass.run_command('r.null', map = 'copia_reclass', null = 0)
- # bash r.null map=copia_reclass null=0
- grass.mapcalc("Stable=if (i_cri_mm>1000, 7, 0)")
- grass.mapcalc("Unstable=if (i_cri_mm<0, 1, 0)")
- grass.mapcalc("Icritica=copia_reclass+Unstable+Stable")
- colors_rules = "1 255:85:255\n2 255:0:0\n3 255:170:0\n4 255:255:0\n5 85:255:0\n6 170:255:255\n7 255:255:255"
- grass.write_command('r.colors', map = 'Icritica', rules = '-', stdin = colors_rules, quiet=True)
- # bash r.neighbors input=Icritica method=average size=3 output=I_cri_average
- grass.run_command('r.neighbors', input = 'Icritica', method = 'average', size = 3, output = 'I_cri_average')
- # rinomina
- grass.run_command('g.rename', rast = ("I_cri_average", susceptibility))
- grass.run_command('g.rename', rast = ("i_cri_mm", critic_rain))
- # Rimuovi
- grass.run_command('g.remove',rast=("A","copia_reclass","i_crit_m","i_recl","accum","slopes","Stable","T","Unstable","C"))
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
